The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • interesting effect rodin coil with plasma ball
    "Tuna Can" Rodin Coil meets Plasma Ball - YouTube
    this one is for you shawn about your overlapping vortex
      Let me show you something, look closely at the peter Davey set up compare it with the Ankh set up
      all the element present in the Ankh Set up are present in the Peter Davey setup
      the Egg
      The Coil / Ring (i would recommend quartz ring coated with mica or ceramic coil )
      a Pole
      Water
      It's all about Perspective...Principle of Mentalism
      this was posted here :http://www.energeticforum.com/155286-post12.html
      find the egg ...the ball could also work coupled with Peter Davey's set up to make it complete
        a 10 sec vid of a water vortex to give you an idea on salt water and UV production in a egg quartz container....
        the vortex will give you the UV harmonic frequencies (reason: not all pieces of salt are of the same size,temperature, position etc... )....
        Vortex of swirling blue water
        and add to it the following:
        Stanford researchers use river water and salty ocean water to generate electricity
        as it circulates "nano effect" + piezoelectricity and pyroelectricity starts to take place, and the water becomes structured as it vortexes, and the process of dissolution of salt produces UV
        Note:
        Dave the same can be done with Methane + water + Quartz
        about this idea, i just posted a link here http://www.energeticforum.com/agricu...tml#post155370
        Agricultural homeopathy
        The use of homeopathic remedies for raising crops.
        Scientific Research: Plant Studies
        Scientific Research: Plant Studies | Avilian
        Now take the sphere you saw in the super efficient heater fill it with normal water, take a quartz container (egg is fav choice for now ) fill it with your fertilizer +water create a vortex inside quartz container....the normal water surrounding the quartz container will have acquired the properties of the water contained in the quartz egg
        watch the vid 40 sec : Golden Mean Egg Vortex - YouTube
        spatula shape
        see also:http://www.energeticforum.com/152853-post118.html
        • the beauty of this setup is that you can use a magnetic stirrer, watch the following vid
          Homemade Magnetic stirrer - YouTube
          note: this set up is also good for water desinfection (use copper for the ball )
          once again all the element present in the Ankh Set up are present in the Peter Davey setup
          the Egg
          a Pole
          Water one of its properties is memory
          the ball
          • Device for purifying a flow of liquid by means of ultraviolet radiation Claus Buchwald
            The device for purifying a flow of liquid by means of ultraviolet radiation, includes an elongated ultraviolet lamp; a generally tubular inner casing surrounding substantially the lamp, the casing being made of a material that allows transmission of ultraviolet radiation, the casing having an aperture at each end thereof from which the electrical terminals of the lamp protrude; and a generally tubular outer casing surrounding the inner casing and forming with it a flow passage, the outer casing being provided at substantially each of its ends with inlet and outlet for the flow of liquid. Two connectors are disposed respectively at both ends of the device for securing the lamp and the inner casing with respect to the outer casing. Each connector includes an annular liquid-tight removable seal disposed between inner and outer casings; an opaque electrical socket having a central cavity for receiving the corresponding terminal of the lamp; and a fixing device for securing the correspon...
            Inventor: Claus Buchwald
            uv light disinfection quartz - Google Search
            http://rexresearch.com/rahn/rahn3.pdf on page 5
            The same authors found that even the dissolution of NaCl
            in water produces & growth-stimulating radiation
            (Table 14) This
            energy emission occurs only during the act oI dissolving ; it- ceases
            completely when all the salt i8 in solution' No effect is noticeable
            when sugar is dissolved in water, or when palmitic acid is dissolved
            in alcohol. Wolff and Ras concluded therefore that the process
            of dissociation of salt into ions is the source of ultraviolet
            now try this with dead sea salt which is used to create ORMUS solution
            How to make Ormus - YouTube
            • Copper-silver ionization as a disinfectant
              When was the disinfection mechanism of copper and silver discovered?
              Archeological excavations show, that people have been using copper for more than 11.000 years and have been using silver for more than 5000 years. Copper can be easily extracted and processed. More dan 7000 years ago people developed a copper extraction mechanism for copper ores. The Roman empire gained most of its copper from Cyprus, the isle that gave copper its name.
              Nowadays copper is mainly extracted form ores, such as cuprite (CuO2), tenorite (CuO), malachite (CuO3·Cu(OH)2), chalcocite (Cu2S), covelite (CuS) and bornite (Cu6FeS4). Large deposits of copper ores have been found throughout the US, Chili, Zambia, Zaïre, peru and Canada.
              Silver can be obtained from pure deposits, from silver ores such as argenite (Ag2S) and horn silver (AgCl) and combined with ore deposites that contain lead, gold or copper.
              Both copper and silver have been applied for centuries because of their biocidal mechanism. The Vickings used copper strings on their ships to prevent the growth of algae and shells. Modern ships still use the same technology.
              Most anti-fouling paints contain copper, reducing the number of marine species growing on the walls of ships. Because of this measure, ships can reach their destination faster.
              Nomads used silver coins to improve drinking water quality. Well water containing copper and silver coins is very bright, due to the biocidal affect of these metals.
              Since 1869 various publications have appeared on disinfection properties of silver. Some European and Russian villages have been using silver for drinking water treatment for many years.
              Copper-silver ionization was developed in both Europe and the United States in the 1950’s.
              What are the applications of copper-silver ionization?
              Copper-silver ionization is suitable for a large number of applications. It became of interest when NASA used copper-silver ionization for drinking water prodcution aboard Apollo space ships in 1960. The ion generator that was used, was the size of a matchbox.
              Because of copper-silver ionization, drinking water could be produced safely in space without the use of chlorine.
                the Egg
                a Pole
                the ball
                about the magnetic stirrer creating a vortex (see video)
                as salt dissolve in water it generates UV light but also the vortex:
                info on vortex and its properties:
                found it here : Nassim Haramein Vortices « Ciencia holÃ*stica para el cambio de conciencia.
                We find that the vortex has a rhythm of its own. It shrinks in diameter and increases in length at one moment, at the next it expands in diameter and shrinks in length. It continues this oscillation in a periodic manner just like a pendulum or the mainspring of a watch.
                According the Dr. Schwenk the vortex has other properties that suggest that it may have cosmic connections: If a small floating object with a fixed pointer is lowered into a vortex, it will circle around and around wi t h the pointer always pointing in the direction in which it was originally aimed. It acts just like a compass needle! It will always be directed toward some point in infinite space. According to Schwenk this shows that a vortex is a l w a y s oriented as if it were held in place by invisible cosmic threads.
                The velocity of fluid at any point in a vortex is equal to a physical constant divided by the radius from the suction center. That is to say that velocity increases as the radius gets smaller. In a perfect vortex, as the radius approaches zero its fluid velocity will approach infinity. As infinite velocity is impossible in the physical universe, something has to give. In the case of water the molecules begin to dissociate into a vapor. This dissociation is accompanied by the generation of high voltage electricity. We have measured charges as high as 12,000 volts in the exact center of a liquid vortex! The pressure in the center of a vortex is theoretically infinitely negative. In this condition, space would be turned inside out.
                Viktor Schauberger, the German Forestmeister observed the liquid vortex in nature. He spent a lifetime observing the flow of mountain streams in the virgin forests of Bavaria and Austria. The world is in great debt to this pioneer. He observed many phenomena associated with the liquid vortex. These phenomena include: energy discharges such as halos, and ball type lightning; levitation – in which heavy egg shaped stones float on the top of a vortex;
                Schauberger and his son Walter who is also a pioneer in this area of investigation developed, egg shaped vortex reaction chambers. These chambers are called implosion chambers as the energy developed is centripetal rather than centrifugal. He maintained that centripetal energy is the basis of life whereas centrifugal energy is the basis of decay and destruction.
                note :
                A magnetic stirrer or magnetic mixer is a laboratory device that employs a rotating magnetic field to cause a stir bar (also called "flea", a magnetic bar ) immersed in a liquid to spin very quickly, thus stirring it. The rotating field may be created either by a rotating magnet or a set of stationary electromagnets, placed beneath the vessel with the liquid. Magnetic stirrers often include a hot plate or some other means for heating the liquid.
                between the two magnets is the second egg and your "rodin coil"
                to dope the water a bit with energy, you could add colloidal gold with the dead sea salt
                see IndianaBoys experiment
                • the tesla egg with the quartz/neo ball should look like the moe joe cell (of course respecting the golden egg ratio)
                  Moe Joe uses Bismuth core , i would use a quartz high frequency Transducer to cause the water to turn into HHO
                  would you believe me if i told you that i had this image stuck in my mind for quite a while; and that is the Moe Joe Cell was incomplete...the missing part was a multi layered egg shell (copper ying, iron yang )
                  Inspired by the pioneering work of Dr. Kervran, Dr. George Ohsawa sought to transmute sodium into potassium in vitro. The method revealed itself to him in a symbolic dream. Thus inspired, Dr. Ohsawa and Michio Kushi, et al., constructed an experimental electric discharge tube with copper (Yin) and iron (Yang) electrodes (and the egg is created )
                  Yin and Yang in Chinese Mythology
                  The Pangu* legend
                  In the beginning there was nothing in the universe except a formless chaos. The chaos began to coalesce into a cosmic egg for eighteen thousand years. Within it, the perfectly opposed principles of yin and yang became balanced and Pangu, emerged from the egg.
                    we both know that when you wrap a copper coil around an iron core and apply electricity you get an electromagnet. I do not see why it would not work in the same fashion. You are wrapping copper around iron and when you place that in a vortex of water or another vortex of electromagnetism it should generate electricity and would most likely be more stable than the natural copper and magnet eddy currents I was suggesting. It would require testing but I think this might be one heck of an upgrade.
                    • MonsieurM,
                      I have just realized something startling. Alternating current is causing a vortex that pushes away from the center. Notice in the first video when he turned the roddin coil on the ball shot out from underneath it. This is because the vortex was pushing away from center. The same thing is happening from above as well the vortex is pushing objects away from the center. But DC is way different.
                      Rodin Coil Effects 5.1 - Neosphere Levitation - YouTube
                      Ball shoots out from underneath bottom using ac current/ball is spinning.
                      Rodin Leve-Sphere Spinner Double Pulse Motor (TEST31) - YouTube
                      Ball is being pushed away from center from above using AC because ball is spinning at high velocity.
                      This absolutely confirms that Alternating current causes two vortexes the cross and push out from center.
                      However DC current is completely different it pulls toward center from the bottom.
                      Strange Spin with Direct Dc and The Rodin Coil with no pulsing. (TEST 28) - YouTube
                      watch how the ball is caught in the vortex while it sits on the table then is pulled off the table (vice shooting out from under as in the ac video) and toward the center of the coil. Also note that the ball does not spin or orbit and therefore has a tendency not to center it self but be pulled toward a side and rest against it.
                      I can not find a video of anyone using DC and where the ball is above but if i had to venture a guess I would say that it is pushing away from center from above. Hence this is why he described the coil as in imploding / exploding machine. We should definitely consider using DC or even pulsed DC for this and not AC.
                      if I am right about this then you could stack the torroids and place a glass cylinder / tube down the center to keep the ball centered and it should pass the ball from bottom to top without stopping.
                      • I agree with you on trying out the DC Approach, but I would not rule An AC/DC coupling out, as long as no one has tested AC/DC on Rodin Coil i'll keep it for now...
                        Why?
                        When AC is Parallel to DC (as in the video) what you actually get is a rapid cycling between DC to DC (when AC current is in the same direction ) and Counter DC to DC (when AC current is in the opposite direction). And I suspect that a counter emf happen when the AC current switches direction when in parallel to DC...
                        note: DC current could be Pulsed when in parallel to AC current
                        all i know, is that Rodin Coil has not been tested on a AC/DC coupling with dc running in one direction and AC running in the opposite direction
                        I'll check Searl experiment to see how he did it
                        a different current application is necessary if you want to pass a ball through a stack of Rodin coils
                        I think AC/DC maybe good for the Ankh set up but not so good for the stacked coil set up
                        • Originally posted by shawnnweed View Post
                          MonsieurM,
                          It will be then just a matter of right timing for the ball to gain speed and pass through the stacked coils
                            I had that thought as well turning on the upper a split second before turning off the lower one. Plus the old addage of an object in motion tends to stay in motion i.e slingshotting the ball past the center. But then I realized that the upper torroid should resonate with the lower because their vorteces are pulling in the same direction and not against each other. Once the ball passes the center of the first torroid then it should be pushed and pulled at an eccelerating rate through the tube.
                              Why?
                              I see what you mean. Will definately require testing but i think you are right when you say pulsed DC and AC are a perfect match. As a matter of fact I think that pulsed DC is a physical representation of the ether channel. This could most likely be the greatest discovery for the roddin coil. You know how they say keep a spacing available on the torroid for the ether channel. I bet this would be a perfect place to rap a third wire for pulsed DC. I would really like to see what happens then.
                              • if you place your stacked Rodin coils in a circle you end up with a CERN looking set up that may create a vortex in its center too...due to the emf timing
