The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • Slovenia just posted an important information on Peter Davey 's Patent, i took the liberty of capturing the info concerning the sonic boiler:
    and compare it with a slice view of the Moe Joe Cell
    http://www.energeticforum.com/renewa...tml#post155601
    I would still mix iron and copper for each electrode ...I have been desperately searching for metal made eggs ...I really want to experience with two metal eggs instead of concentric spheres
      petar113507 has provided us with some good insight in his post:
      http://www.energeticforum.com/149708-post95.html
      , and as recommend by him, i looked for posts made by Powerme, seeing that it was going to be a tedious work, i actually found a compilation of all his post: it's in pdf:
      Power1.pdf - 429 Kb
      Looks like we are pretty much on the same page
      Guys read page one of power1 document, pulsed DC/AC maybe the way to go ....
      • I would still mix iron and copper for each electrode ...I have been desperately searching for metal made eggs ...I really want to experience with two metal eggs instead of concentric spheres
        [/QUOTE]
        I will help you search
        • Thanks Shawn , much appreciated
          About power1 doc , i found a 45khz transducer here:
          http://www.axtal.de/data/SCTB_RKMA100.pdf
            for some reason yet unknown to me I was unable to read the above download(power 1 doc). However I take it that the gentleman discovered that at 45 kilo hertz or 45,000 rotations per second that a certain amount of pressure would be exerted on the crystal which could be then be tranformed into a certain type of voltage(dc or ac) or pulse rate(ie pulsed dc) through a transducer?
            • is it the transducer doc that did not work or the power1.pdf
              • Originally posted by shawnnweed View Post
                I would like to relate a post made by Power1 in relations to Crystal Ball power Cell/Peter Davey design
                What is a transducer?. It is just
                a structured lattice of crystals tuned to a particular frequency
                . You can buy or make your own
                very easily. So why would you waste your time and efforts wandering far off topic with
                distractions and speculations, all were working with here is Waves. Learn to know what
                waves is, build different coils and observe. Learn the phases of elements, know their
                properties. Combine different element to achieve desired property. Everything has already
                been researched and published. I've already told you to oscillate DC with a toroid, with your
                output AC, you amplify the frequency with a crysta
                l. DC is pulsed at desired frequency/
                oscillation, the lattice of the transducer crystals steps up oscillation and this allows atomizing
                of water into fine molecules
                Wave frequency in the water needs to be 43khz +.
                now we know how to break water...43 khz is needed
                Current nuclear is no match for water nuclear, it is more powerful,
                abundant in supply very low cost and safe.
                see: http://www.energeticforum.com/149089-post157.html
                • Shawn, let's tackle the idea of AC coupled with Pulsed DC in a Rodin coil...just for a start...how would we go about it
                  and here is the video i meant for you to see
                  A challenge for Rodin Coil Builders - YouTube
                  watch the whole vid
                  Torus Fun (Sacred Geometry by ieoie) - YouTube
                  • Pulsed DC - Wikipedia, the free encyclopedia
                    Pulsed DC or PDC is the form of wave produced from a half-wave rectifier or a full-wave rectifier. Full wave rectified ac is more commonly known as Rectified AC. PDC has some characteristics of both alternating current (AC) and direct current (DC) waveforms. The voltage of a DC wave is roughly constant, whereas the voltage of an AC waveform continually varies between positive and negative values. Like an AC wave, the voltage of a PDC wave continually varies, but like a DC wave, the sign of the voltage is constant.
                    Principle of polarity:if it can decrease, it can also increase
                    Pulsed DC may also be generated for purposes other than rectification. It is often used to reduce electrical arcs when generating thin carbon films, [1] and for increasing yield in semiconductor fabrication by reducing electrostatic build-up. [2] It is also generated by the voltage regulators in some automobiles, e.g., the classical air-cooled Volkswagen Beetle.
                    I guess you are right Shawn , Pulsed Dc gives us the best of both world
                    Rodin Coil has definitely found its match: Pulsed Dc
                    Or as you put it:
                    As a matter of fact I think that pulsed DC is a physical representation of the ether channel. .
                    It is the best match to a physical representation of what constitutes Matter; ie: Rodin Coil
                    and this is exactly what I keep on finding in all the research i posted, be it antigravitation, transmutation, sonofusion etc....It is always High Frequency Pulsed Energy
                    • So we probably need a set up between the secondary coil and The Rodin Coil to turn the current from Dc to pulsed Dc or amplify the pulse...or is the secondary Already doing pulsed DC which i think it does see illustration of a normal Tesla Coil
                      So I guess Tesla Knew about this too, considering the set up, What do you think?
                        watch the whole vid
                        my goodness. This guy has some imaginaiton. That's one heck of a challenge. I'm not sure a master torroid builder could accomplish this. But I Imagine he was thinking right up the same alley as I was only he thought of literally physically combining the torroids to form one massive stacked torroid. Although I really not sure if its necessary. once the field of each individual torroid are in synchronization with the other the overlapping fileds should become sympathetic to one another and self resonate therefore causing the many to act as one single torroid without ever having to physically combine them. The only one benefit i can see is not having to use multiple power sources. And besides I'm really not sure it's safe to build a black hole that big. I do hope everyone realizes that inplaying with torroids we are basically playing with blackhole technology just on a micro level.
                        • or a white hole principle of polarity
                          White hole - Wikipedia, the free encyclopedia
                          A white hole, in general relativity, is a hypothetical region of spacetime which cannot be entered from the outside, but from which matter and light may escape. In this sense it is the reverse of a black hole,
                            Tesla knew this and so did Francis Wilkinson. Wilkinson just went with a simpler set up very similar to our own.
                              how is it that I am the cup half empty kind of a guy and you are the cup half full kind of guy.
                                watch the whole vid
                                But to answer this question I would personally keep the wires insulated so that the two different current never come into contact with one another, we want the effect not the dramatic light show. And secondly I would probably run them in opposite directions for the first test. FOr what reason my mind keeps wantng me to run them in opposite directions i do not know. I might have sublimally picked up on something i read. cadeous coil?
