The Golden Tractate of Hermes Trismegistus applied to electromagnetism
In a Rodin coil, there are four electrodes, 2 positive 2 negative; each running + in opposite direction and thus the third emf (the gap) is created thanks to 2 pulsed Dc running in opposite directions
we may have to play on the timing of both pulsed dc, do you want them running at the same time,slight delay etc...
I really wouldn't see the point in having two different sets of wiring. We could braid the posative & negative wire with the pulsed dc wrap it in one direction and then double back and rap it in the other direction just like a caduceus coil. Then we could flip the torriod upside down, from as it is in the picture, so that it works the same as in the video and pulls up from the bottom and pushes out from the top. This would be my suggestion.
Sorry, i was tired yesterday, scratch my last post.... but your idea is probably on the good track...let me think about it
Signs and symbols rule the world, not words nor laws. -Confucius.
Then i guess the best approach before we start on the Rodin Coil, would be to test the Pulsed DC on a simple Caduceus Coil for the purpose of observing the effects produced...just take a magnet and coil a caduceus coil around it ; connect it to a pulsed dc generator
Providing a high enough frequency pulsed DC supply for our CS Generator isn't that complicated. Here's an example of a working model I put together in a few minutes, using an "Experimenter's Socket" and a few components, all available from Radio Shack. Note that this circuit is being powered by 2 9-volt rechargable batteries in this photo.
The core of the circuit is the versatile 555 timer IC, an 8 pin DIP IC that's widely available.
The 'Experimenter's Socket" has rows of holes radiating out from each IC pin, giving 5 contact holes in each row that are internally connected together. You insert the IC into the center of the socket board, straddleing the gap in the center, then insert components one by one, until all parts are in place. This circuit also requires 3 "jumper wires", shown in red, blue, and black. These each connect points in the circuit that need to be connected together.
Below the Experimenter's Socket is shown a Radio Shack printed circuit board to match the Socket's layout, for those who want to solder together a permanent version of the circuit. Note that 18 volts is the maximum that the 555 IC will tolerate, which is plenty for generating Colloidal Silver.
If it works for colloidal silver; it should work for the caduceus coil
thank you for the attachments of the caduceus coil. WOW the coil itself can levitate. Time diferential displacements. my goodness this is one mean coil.
superconductivity:
there is water in the air, i don't think the magnet is in a vacuum sealed environment see video:
The golden ratio an exact 'magic' number often claimed to be observed when taking ratios of distances in ancient and modern architecture, sculpture and painting has been spotted in a magnetic compound.
The qualities of a high-temperature superconductor a compound in which electrons obey the spooky laws of quantum physics, and flow in perfect synchrony, without friction appear linked to the fractal arrangements of seemingly random oxygen atoms....
...Those atoms werent thought to matter, especially not in relation to the behavior of individual electrons, which exist at a scale thousands of times smaller. The findings, published Aug. 12 in Nature, are a physics equivalent of discovering a link between two utterly separate dimensions. (obviously they know nothing about the Fractal Universe Theory pfff.... )
Helical gears offer a refinement over spur gears. The leading edges of the teeth are not parallel to the axis of rotation, but are set at an angle. Since the gear is curved, this angling causes the tooth shape to be a segment of a helix. Helical gears can be meshed in a parallel or crossed orientations. The former refers to when the shafts are parallel to each other; this is the most common orientation. In the latter, the shafts are non-parallel, and in this configuration are sometimes known as "skew gears".
The angled teeth engage more gradually than do spur gear teeth causing them to run more smoothly and quietly. With parallel helical gears, each pair of teeth first make contact at a single point at one side of the gear wheel; a moving curve of contact then grows gradually across the tooth face to a maximum then recedes until the teeth break contact at a single point on the opposite side. In spur gears teeth suddenly meet at a line contact across their entire width causing stress and noise. Spur gears make a characteristic whine at high speeds. Whereas spur gears are used for low speed applications and those situations where noise control is not a problem, the use of helical gears is indicated when the application involves high speeds, large power transmission, or where noise abatement is important. The speed is considered to be high when the pitch line velocity exceeds 25 m/s
