Now you are going to ask yourself "what about the violet color people saw, it cannot be water? "
Kirlian Photography of
water samples on photographic film©:
1 drop - tap water,
2 mountain water drop,
Teteven, Bulgaria,
3 drop - seawater,
Hammamet, Tunisia,
4 drop - karst and mineral water,
Zlatna Panega, Bulgaria,;
Dr. Ignatov©, Dipl.Eng. Yatsevich©, 2010
1 drop - tap water,
Teteven, Bulgaria,
3 drop - seawater,
Hammamet, Tunisia,
"In the Kirlian effect, which is a high-frequency electric discharge in gas, the color of light depends only on gas. It does not depend on the electrodes. It is apparent that the color Kirlian aura carries biological information from the object itself. The observed phenomenon cannot be described and explained from the point of view of the modern physical notions for the color of the light of gas discharge. The fact that different colors are being observed, apparently confirms the opportunity for selective influence on the researched object. The methodic and the results of Dr. Ignat Ignatov are a novelty, because local energy states of the researched object are displayed depending on the colors in his electric aura. This, as a fact, presents new possibilities for the research and characterization of the qualities and properties in a biological and physical aspect of the object. New opportunities are found for the characterization of the biological properties of objects after a certain influence. Dr. Ignatov’s methodic for Color Kirlian spectral analysis can be defined. New notions for color vision are possible to be discovered. It is not clear whether the green color that we see is an averaged effect between the yellow and the blue color, or in some cases it corresponds to a wave length corresponding to the green color of the spectrum (Marinov, Ignatov, 2008)"
