The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Originally posted by petar113507 View PostAllright.
I couldn't resist.
Just one more post.
Russell's periodic table of elements.
This one looks different.
This one is from the book "The Universal One"
And I never realized that that book would have so many clues to the golden tractate....
This picture shows the noble gases transitions path. Into what exactly it is transitioning, I do not know -- but those lines weren't there in the older tables -- and I can't think that's an accident.
==Romo(think singing bowl )
Each Element within it exist the resonance of the elements in "lower planes" thus Multi-Phonic.
Fractal ResonanceLast edited by MonsieurM; 10-05-2011, 11:24 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
ZPE
your second coil:
The golden ratio — an exact 'magic' number often claimed to be observed when taking ratios of distances in ancient and modern architecture, sculpture and painting — has been spotted in a magnetic compound.
Tachionator
I originally began this project to demonstrate the possibility of perpetual motion while studying at Purdue University in May of 2002.
Researchers have continued to be interested in this device because it defies natural laws of physics and is unexplainable by conventionally excepted electromagnetic theory. Modern science says it is impossible, but Edward Leedsklanin's theory says it is simple, natural, and that it's workings are misunderstood because there are some important aspects of modern science being taught in schools that are wrong.
Perhaps more intriguing than the ability to store energy indefinitely, the Perpetual Motion Holder can act like a living thing; and because it operates on the principles of a theory with a sound base of understanding, Leedskalnin is able to use this device as a real working depiction of the atom and the earth. Throughout his writings Leedskalnin subtly points to a lack in a base understanding in all branches of science, but is quite thorough in his disparaging of J.J. Thomson's electron invention.
now this is what happens inside these magnets (principle of correspondence:
Last edited by MonsieurM; 10-06-2011, 02:05 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Iv been wondering for awhile now what the E Field will do to water,
what if we took a plastic bunt pan like the wife makes cakes in put a coil in the center where it will be out of the water, then pulsed the coil with hv from a nst.Half of the Answer is knowing the right Question
Nobel Prize in Chemistry for dogged work on 'impossible' quasicrystals | Science | The Guardian
A scientist whose work was so controversial he was ridiculed and asked to leave his research group has won the Nobel Prize in Chemistry.
Daniel Shechtman, 70, a researcher at Technion-Israel Institute of Technology in Haifa, received the award for discovering seemingly impossible crystal structures in frozen gobbets of metal that resembled the beautiful patterns seen in Islamic mosaics (also known as Fractal ).
Originally posted by Dave45 View PostHey MM what do you think, high voltage coils on both sides of rotor-magnet motor, the rotor would be running in the E field of the hv coils
I bet she'd rock“Signs and symbols rule the world, not words nor laws.” -Confucius.
also, i found this posted by sucahyo from http://www.energeticforum.com/renewa...yramid-14.html , Walter Russell Drawings
Yep by changing wiring on hv coils you could have nn,ss,ns, I believe this would work, its setup just like the Testica electrostatic generator.
I know the spelling is wrong my Swedish is a little off, I think it is in Sweden
cant remember.
DaveHalf of the Answer is knowing the right Question
Originally posted by MonsieurM View PostYou have to make sure that both magnet emit opposite vortexhow about this
Originally posted by shawnnweed View Post
I can see what you mean. Actually two golden mean vorteces, placed in opposite rotation would eventually form an oblong circle like the one posted. Which of course would form a nearly perfect circle.and together they form:
It is also called a Fermat's Spiral -- from Wolfram MathWorld
The Fermat Spiral Also respects 936
Fermat's spiral (also known as a parabolic spiral) follows the equation
in polar coordinates (the more general Fermat's spiral follows r 2 = a 2θ.) It is a type of Archimedean spiral.[1]
In disc phyllotaxis (sunflower, daisy), the mesh of spirals occurs in Fibonacci numbers because divergence (angle of succession in a single spiral arrangement) approaches the golden ratio. The shape of the spirals depends on the growth of the elements generated sequentially. In mature-disc phyllotaxis, when all the elements are the same size, the shape of the spirals is that of Fermat spirals—ideally. That is because Fermat's spiral traverses equal annuli in equal turns. The full model proposed by H Vogel in 1979[2] is
where θ is the angle, r is the radius or distance from the center, and n is the index number of the floret and c is a constant scaling factor. The angle 137.508° is the golden angle which is approximated by ratios of Fibonacci numbers.[3]
this must be where you got your inspiration
Last edited by MonsieurM; 10-06-2011, 12:07 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
The MiraCoil displays the very Principles expressed by Nikola Tesla and Dr. Walter Russell: "The Man Who Tapped The Secrets of The Universe" and Author of "The Universal One" and "A New Concept of the Universe". These principles enable us to produce and radiate very Coherent Energy Fields.
We use this Coherent Electromagnetic Field as one would use a racetrack. Instead of using a car, we are directing Electrons through a Coil which incorporates the clockwise movement of Gravity and the counter-clockwise movement of Radiation. Between these two counter-rotational fields exist the junctions of rest and healing. The healing benefits of Standing waves or Scaler waves are produced.Our MiraCoils come with clear Quartz Crystal Tubes so you can place Inert Gas Devices or different materials (flower essences, star elixirs, gems, precious metals etc.) into the core of the coils and have that essence radiated into the body along with your personal tones. Playing your Personal Tone Tape through the MiraCoil system will guarantee greater results. Speaker systems are limited to moving air and creating mechanical pressure on the body while the MiraCoil operates on the electromagnetic frequency level, (the world of cells).
see also: http://www.energeticforum.com/160281-post811.html
Last edited by MonsieurM; 10-06-2011, 12:49 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by MonsieurM View Postwhyhow about this
you got itand together they form:
