The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Enki is the Sumerian god of the sweet fertilising waters of the deep, patron of all crafts, magick and wisdom, later known as Ea by the Babylonians and Assyrians. Together with Anu, the Skyfather, Enlil, Lord Air/Wind, and Ninhursag-Ki, He is one of the ruling deities of Mesopotamia, the god who is friendlier to humankind and who interacts with Goddesses (and the Feminine) with graciousness unmatched in world myth and religion. Enki΄s name can either be taken to mean Lord Earth, but KI also stands for Below in regard to the cosmic structure prevailing in Ancient Mesopotamia, where An (Sky and Skyfather) is the Above
Enki΄s sacred number is 40, and His atrological region is 12 degrees south in the sky (includes Pisces and Aquarius)
Signs and symbols rule the world, not words nor laws. -Confucius.
Enki is usually pictured with two streams, the Euphrates and the Tigris rivers flowing out of his shoulders, or from a vase he holds. We could very well say that He holds a Grail that overflows with plenty, the Sumerian way! One of his epithets is the Productive Manager of the Soil, reflecting His leading role in fructifying and fertilising the land. Water, by the way, means also semen in Sumerian.
In view of these factors, a biblical relationship is evident. The mention of the Tigris, Euprates, Karon and Wadi Baton Rivers correspond precisely with those mentioned in Gen. 2:1014 as being in the immediate vicinity of the Garden of Eden. The Tigris is called Hiddekel in the Bible. Based on lingering tradition, the Karon and Wadi Baton correspond to the Pison and Gihon. According to a Smithsonian magazine article of several years ago, two huge dried-up riverbeds are clearly visible from satellite pictures.
and showed the map which caught my Attention , after some tweeking , i got this result let me know what you think...interesting isn't it
Leedskalnin Perpetual Motion Holder Demonstrated With One Coil - YouTube
watch this vid, when he removes the bar the light lights.
Whats happening
The magnetic field is moving through the metal, looped
The electric field is orbiting the coil
when the mag field is broken the electric field collapses into the coil windings.
This would work on the TPU , Two coils wound on a toroid once charged they would create the same fields as the pmh, then wind another coil over the other coils and run a small current through them the electric field will enter the small voltage wire through attraction, and boost the voltage and current, overunity, the low voltage may need to oscillate.
As long as the toroid isnt broken as in the pmh the electric field will just keep drawing in the aether
12And I beheld when he had opened the sixth seal, and, lo, there was a great earthquake; and the sun became black as sackcloth of hair, and the moon became as blood;
13And the stars of heaven fell unto the earth, even as a fig tree casteth her untimely figs, when she is shaken of a mighty wind.
14And the heaven departed as a scroll when it is rolled together; and every mountain and island were moved out of their places.
15And the kings of the earth, and the great men, and the rich men, and the chief captains, and the mighty men, and every bondman, and every free man, hid themselves in the dens and in the rocks of the mountains;
16And said to the mountains and rocks, Fall on us, and hide us from the face of him that sitteth on the throne, and from the wrath of the Lamb:
17For the great day of his wrath is come; and who shall be able to stand?
Not to sidetrack you guys, but I think SM was using Leedskalnin's pmh in his TPU.
I'll be back with more
Hello Dave, good to read you and no you are not side tracking the discussion as long as we are talking about 6 3 9 ; which is to be found all over nature
you are using the principle used in a sitar and sympathetic chords
since we are talking about Resonance, it maybe good to brush up on musical resonance.....so i found this book; which i am reading now....(mentions resonance in a bell )
This volume is designed to set forth in the simplest possible
manner, the fundamental facts concerning present practice in
electrical power transmission.
Busy men have little time txy spend in discussing theories of
which the practical results are known, or in following the
derivation of formula) which no one disputes. The author has
therefore endeavored, in introducing such theoretical consid-
erations as are necessary, to explain them in the most direct
way practicable; using proximate methods of proof when pre-
cise and general ones would lead to mathematical complica-
tions without altering the conclusion for the purpose in hand,
and stating only the results of investigation when the processes
are undesfrably complicated.
Now, if this pendulum be given a twist it will oscillate at
constant frequency imtil the friction gradually brings it to
rest with oscillations of steadily decreasing amplitude. If,
however, at the end of each complete swing it should receive a
slight push, its oscillations would continue and would increase
in amplitude up to a limit set by the frictional resistance.
The condition for such permanent increase of amplitude is
that the frequency of the pushes must coincide with the period
of the pendulum. In the electrical case, resonance thus
156 ELECTRIC TRANSMISSION OF POWER,
occurs when the frequency and the time constant of the cir-
cuit are equal. Further, maintaining our auxiliary pushes at
their original frequency, suppose / to be decreased by taking
weight off A progressively. As the time constant of the
pendulum thus diminished a point would be found, and that
very soon, at which resonance would cease, and the same
result would follow increase of /, so that when the circuit
begins to get out of tune the resonance soon becomes rather
trivial. If, however, the pushes were supplemented by others
of 3, 5, 7, etc., times the frequency, corresponding to the
harmonics found in an ordinary alternating circuit, new points
of resonance would appear when the period of A assumed
corresponding values.
As to the magnitude of the resonant effect, in the torsional
pendulum case the amplitude evidently increases with the
strength of the pushes, their absolute frequency, which mea-
sures the energy supplied, and the moment of inertia of A^
which stores this energy. It decreases in virtue of the fric-
tional resistance. Corresponding reasoning holds in the elec-
trical case, and to a first approximation the E. M. F. in a
completely resonant circuit is
in which E is the impressed E. M. F. concerned, L the induc-
tance in henrys, R the resistance in ohms, and n the frequency.
In case of resonance with harmonics, n and E refer to the
frequency and magnitude of the harmonic implicated, and E'
becomes a resonant component of the E. M. F. wave. This
subject will be discussed more at length in Chapter XIII.
We have now glanced at the most striking characteristics
of alternating currents those concerned with the phenomena
of inductance and capacity.
It rcmains to note very briefly some other physical proper-
ties that are of practical importance.
The most important single property of alternating current
is the ease with which it can be changed inductively from one
voltage to another. If a circuit carrying such a current is put
in inductive relation with another circuit as in Fig. 4, Chapter
I, the electro-magnetic stresses set up by the first circuit can be
utilized to produce alternating current of any desired voltage
in the second circuit. The details of the operation will be
taken up later; suffice it to say here that it is essentially the
transformation of the electro-magnetic energy due to one
circuit into electrical energy in another circuit.
Alternating currents can be regulated in amount by putting
inductance in the circuit without losing more than a very
trifling amount of energy. This very property, however, is
troublesome when an alternating current is used for magnetiz-
ing purposes. It is very difficult to get a large current to flow
around a magnet core because of the high inductance, and even
then the magnetic and other losses in the core are serious imless
great care is taken. These difficulties have stood in the way
of getting a good alternating motor until within the past few
years, and even now such motors have to be designed and con-
structed with the greatest care to avoid trouble from induc-
tance and iron losses. For some classes of work, such as teleg-
raphy and electrolytic operations, the alternating current is
ill suited save under special conditions and with special appar-
atus. For the general purposes of electrical power transmis-
sion it is singularly well fitted, from the great ease with which
transfonnations of voltage can be made, certain very valuable
properties of the modem alternating motor, and the great
simplicity and efficiency with which regulation can be efifected.
The only inconvenience attending transmission by alter-
nating current is that incurred when direct current must for
one reason, or another, be supplied. This is in a fair way to
be greatly reduced by both increasing use of alternating cur-
rent in distribution, and by improvement in apparatus for
obtaining direct current from an alternating source.
One of the Chapter covered is:
Properties of Direct and Alternating Current Arcs . . . 592
