a couple of interesting vid:
Powering a Thyratron Tube - YouTube
btw: a Thyratron Tube is like a plasma antenna
Plasma antenna - Wikipedia, the free encyclopedia
---------------from Evolution of the E.V. Gray Circuit Topology -- by Mark McKay vs. Thyratron
---------------and
The Nazi Bell Experiment.AVI - YouTube
]A plasma antenna is a type of radio antenna currently in development in which plasma is used instead of the metal elements of a traditional antenna.[1] A plasma antenna can be used for both transmission and reception.[2] Although plasma antennas have only become practical in recent years, the idea is not new; a patent for an antenna using the concept was granted to J Hettinger in 1919.[3]
Triode vs. Thyratron
John Bedini maintains that the E.V. Gray “Triode” was actually a high current thyratron operating in Class C mode possibly with a grounded grid. The commutater achieved the gross switching control and the thyratron was simply over-voltaged to fire like a flash tube. The intent was to provide a low resistance forward current path and then a high resistance reverse path. The advantage of a thyratron is that its heated cathode provides a fast reverse recovery time, when compared to solid-state diodes. The down side is the huge energy investment needed to supply the thyratron heater. But, it is not nearly as bad as the energy required to operate a triode in the same current range. For a standard triode the maximum forward pulse current is directly proportional to the heater wattage. This determines the number of free electrons in the space charge. In a mercury gas filled thyratron positive and negative current carriers are created in abundance when the switching “arc” is established. The maximum pulse current is more limited by the tube’s heat dissipation and the mechanical strength of its internal elements. Short-term reverse currents are inhibited due to the inertial mass of the moving positive mercury ions. For the same size of tube a thyratron can handle 1000 time more current than a triode. So there are some sound engineering reasons to believe that a thyratron might have been used
---------------and
This is a simulation of the basic principles of the Nazi Bell Project, in which the anti-gravity effect rolls an important place in the development of it.
The actions of the 3 main fields (electric, magnetic and electro-magnetic) generate the antigravity effect, which can be applicable to any device, spacecraft or flying saucer.
Due to the weight of the Mini-Bell used in this experiment I could not obtain more elevation of the bell. The experiments will continue until I could obtain a controllable altitude of the Mini-Bell in an open space.
Many of the UFO sightings for saucers could use this form of propulsion which has not chemical components, it is silent and easy to implement.
Anti-Gravity Theory (English)
The practical way to shield an object from gravity is to produce vortex propulsion with the use of two counter-rotate oscillation of an ionic-colloidal plasma. Cold Ionization is obtained partially by the help of the Alfa radiation action of the isotope americium-241 and mainly subjecting the ionic-colloidal plasma to a strong Electric Field. In addition an Electromagnetic Field and a Magnetic Field are also used. The Electromagnetic Field is used to control the plasma resonant frequency. The Magnetic Field is used to concentrate or focus the counter-rotate oscillation in an allocated space. The Electric Field is the main responsible for the ionization.
