The Golden Tractate of Hermes Trismegistus applied to electromagnetism
  • while doing some research i stumbled on this:
    MultiPhysics Simulation of Direct Double Helix Magnets for Charged Particle Applications : Electro- & Magnetostatics : 6450 - COMSOL
    Resistive heating distribution in the direct double helix (DDH) magnet - the heat load is the highest where the current density is large.
    P. J. Masson1 , and R. B. Meinke1
    1 Advanced Magnet Lab, Palm Bay, Florida, USA
    Charged particle beam manipulation requires magnetic dipoles for steering and quadrupoles for focusing. Conventional magnets are currently used leading to very large and heavy systems. Miniaturization of the optic magnets would enable the development of more affordable systems and potentially portable devices. The Advanced Magnet Lab, Inc. has developed a revolutionary magnet topology and packaging allowing for a significant increase of performance in field generation and field homogeneity. COMSOL Multiphysics was used to visualize the current distribution in the magnet and to simulate the heat transfer in steady state operation.
    a type of caduceus if you prefer
    ..............also from http://www.energeticforum.com/renewa...h-other-2.html
    Originally posted by Vortex View Post
    amigo WOW
    Seems you guys over looked this.
    This is amazing stuff, live, real time videos of MOVING Magnetic Flux fields.
    Not a computer simulation.
    Image taken via a Flux Resonator of a circular magnet
    Magnetic Warp (Circles) - YouTube
    • He has a very interesting channel, Dave you should check it out
      SirZerp's Channel - YouTube
      This investigation describes and demonstrates a novel technique for the visualization of magnetic fields. Two ferrofluid Hele-Shaw cells have been constructed to facilitate the imaging of magnetic field lines. We deduce that magnetically induced photonic band gap arrays similar to electrostatic liquid crystal operation are responsible for the photographed images and seek to mathematically prove the images are of exact dipole nature. This is the ring magnet circles version. All Rights Reserved M. Snyder 12/24/2008
      • cool tube site, this one looks like the caduceus coil winding, also notice the lines run at a 60 degree angle.
        Magnetic Warp (France Diagram) - YouTube
        I found 369, need to check it out more will get back to ya if I find confirmation
        30 degrees
        60 degrees
        90 degrees
          30 degrees
          60 degrees
          90 degrees
          Thanks Dave
          here is the pic:
          -------from: http://www.energeticforum.com/renewa...-magnet-6.html
          I found a representation of 369, may not be what Tesla was talking about but I'll put it out there.
          In Willy's thread we talked about VOP (velocity of propagation) but something has bothered me for a long time the AOP (angle of propagation). Through different sources that I cant recall at the moment have stated that the electron or particle has a 60 degree propagation as it moves forward, this is its spin angle.
          I took a pvc pipe marked 60 degrees on the pipe, but its almost impossible to wind, but if we take a ribbon conductor( the circumference determines width) we can wind 60 degree's and cover the whole area of the pipe.
          Here's the 369
          If we cut the ribbon conductor off perpendicular to the pipe the angle at the end of the ribbon conductor is 30 degree's 60 degree's and 90 degree's.
          Im sure there is a relation to phi here somewhere, the AOP may not be exactly 60 degrees but a variant.
          I think useing the 60 degree winding the whole area of the ribbon conductor will funnel into the 30 degree point, in other words the particles will not be throne from their natural aop as they enter the wire attached to the tip of the ribbon conductor, this should be amplification.
          I'll try to make a drawing in paint.
          dave
          • Hey MM this is exciting the AOP is 51.83, I used my handy protractor to get the angle from the pic you posted, check this out
            Triangles and Phi, the Golden Ratio
              We gonna make it flow like water down a drain
              We learn more everyday
              Awesome find Dave ...another dimension found
              COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
              An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways
              . a harmonic cascade effect[/QUOTE]
              • Anyways -- I think the crystal we're trying to grow is a coaxial waveguide to translate ultraviolet photons into electric charge. Looks kinda like either our DNA, or a Quartz crystal...
                I found this: Compton scattering - Wikipedia, the free encyclopedia
                In physics, Compton scattering is a type of scattering that X-rays and gamma rays (both photons with different energy ranges) undergo in matter. The inelastic scattering of photons in matter results in a decrease in energy (increase in wavelength) of an X-ray or gamma ray photon, called the Compton effect. Part of the energy of the X/gamma ray is transferred to a scattering electron, which recoils and is ejected from its atom (which becomes ionized), and the rest of the energy is taken by the scattered, "degraded" photon. Inverse Compton scattering also exists, in which a charged particle transfers part of its energy to a photon.
                • following up
                  The effect is important because it demonstrates that light cannot be explained purely as a wave phenomenon. Thomson scattering, the classical theory of an electromagnetic wave scattered by charged particles, cannot explain low intensity shifts in wavelength. (Classically, light of sufficient intensity for the electric field to accelerate a charged particle to a relativistic speed will cause radiation-pressure recoil and an associated Doppler shift of the scattered light,[2] but the effect would become arbitrarily small at sufficiently low light intensities regardless of wavelength.) Light must behave as if it consists of particles to explain the low-intensity Compton scattering. Compton's experiment convinced physicists that light can behave as a stream (like a river stream )of particle-like objects (quanta) whose energy is proportional to the frequency.
                  as Dave puts it
                  • Notre Dame Rose Window
                    note the similarities
                    • oh yea
                      • indeed .....that image is perfect match
                        you inspired me
                        • also found this here: one of my favorite site for coils
                          Orgone Generators
                          3. Coils)
                          When you cut a piece of wire to a specific length known as the "cubit" length, that wire will resonate or act as a transformer to special cosmic energies and draw that energy into the wire. There are many different "cubit' lengths used by advanced civilations down through the ages. In a phone conversation with Slim Spurling in February of 2005, Slim mentioned that he found that the ancient Egyptian Royal cubit (524mm +/- 2mm) to be more useful for bio-physical energies and Hans Becker's "Lost" cubit (596.6714mm or 23.491") more useful for emotional and mental energies. Since I'm adding at least two coils to the larger orgone generators, I've decided to make one coil based on the Royal cubit length and the second coil based on Hans Becker's Lost cubit length. I designate a multible of the original cubit unit by use of the letter "X". For example, a 3X Lost Cubit coil equals 3 x 596.6714mm or 1790.01mm. Any multible length of the cubit unit will produce the desired results. You can also use a 1/2, 1/3, or 1/4 fraction of the cubit length to give you a similar resonant effect, but usually not as stong as the whole cubit unit length. Depending on the gauge of the wire used, I can usually fit a double or triple multible cubit into the TB or HHg. When you coil the wire, you force the orgone energy into a spiral movement. If the coil is laid out in a flat plane, the energy will spread both laterally and vertically. If you stretch the coil into the vertical plane, you have a vertical cone shaped spiral which drives the energy towards the tip of the spiral in a vortex fashion. For the HHg's, I add both a wide cone-shaped spiral coil that encloses the 5 crystals as well as a flat plane coil (sometimes called a 'pancake' coil) placed at the bottom of the HHg. For TB's, I add a single flat coil at the bottom. The two coils shown on the right are wrapped in a configuration known as a SBB coil, or Saint Buster's Button coil , a name coined by Don Croft
                          remember the mobius Caduceus coil....
                          • a necessary repost http://www.energeticforum.com/renewa...netism-28.html
                            Originally posted by petar113507 View Post
                            I agree. It's time we understood our souls -- our body's recording system. It also relates to the "golden tractate" in that the substance/form which we are looking to create/produce, seems to be like quite the turbo supplement for our soul's unfolding....
                            Further clues that it is about the noble gasses somehow. I don't know how exactly, but they keep popping up everywhere that I look. I can only share what I know -- I hope this makes things "click" for you.
                            Russell's law of crystalization embodying a different facet of its "fractal" meaning:
                            I wanted to better understand this, and so I seek. I am seeking, and so I am finding it. I've also been curious as to what russell meant by thinking in light -- being able to think in the "universal language".
                            I've been recalling when I was younger -- learning to use both sides of our body is not remarkably difficult to learn how to use in conjunction. It requires a little bit of co-ordination.
                            What the heck does that even mean? I've almost forgotten how I got co-ordinated in this body.
                            I remember seeing a baby oogling at his hands, and as he marveled at them -- how they worked -- how he could seemingly only have one side flexing according to his desire at once. Eventually he learned how to move both, of course -- but I'd actually forgotten what it was like to be dumbfounded and in awe at how my hands worked!
                            If our bodies are electric puppets -- the tesla coil analogy brought up the idea
                            How big is that field? I mean -- if what I regard as "me" as outside my body....
                            How was that baby moving its arms? It was learning -- adapting -- localizing more acute records of how his "mind" was piloting his body. And how does a baby moving its body have "harmony"? Isn't harmony a superimpositon of different frequencies?
                            And then Russell, again...
                            Oh, how you tickle my brain into remembering old, and new things....
                            And so -- our piloting mechanism is above our bodies. When concentrate that "field" inside our bodies, we are "awake". The abillity of that field to command our bodies in different ways is a matter of very precise, fine signaling.
                            And so, I look to the sky. Many "common sayings" hold a lot of truth to them, if you consider them in this light.
                            "that idea came out of the blue" (Think -- where did that idea's form ACTUALLY come from? Someone was probably being pretty honest in their sensing of how the idea came to them.... )
                            "they were giving me weird vibes" (How can you feel the "vibrations" piloting their decision making mechanism -- by interference with "your" body's piloting field)
                            "You seem kinda spacey" (Your awareness is not concentrated to a sufficient density in your body for you to be "present")
                            When I saw the Russell picture -- I was immedeately reminded of the concept of the "unconcious mind". I don't know about it being unconscious at all -- I think that's a bad word. Perhaps "Inner self" is a better word for the all-intelligent taproot of consciousness extended to each of us. Regardless, I have asked "it" to give me positive signals (tingles down my spine -- rushes of energy) when it detects something that is useful to me.
                            (I've learned It likes to work with you -- as it has been working with you whether you like it or not.... Might as well try to speak the same language as it)
                            So, I asked "myself" what it meant when you "decentrate" your awareness out of your body when you meditate -- I got a simple picture. That field would retract itself from your sensed body, much like a pilot can step out of the cockpit of an airplane....
                            Ever seen anyone fall unconscious?
                            Ever done it yourself?
                            Did you notice any colors upon the exiting of your body or a "flash" before?
                            I've been thinking about harmony -- and music -- how what everything that we do is also apart of "the music of the spheres" (keeley) It's pretty wild. It makes me see how everything is really beautiful...
                            Think of the incredible tenuity which your consciousness (that feild) posesses to be able to relax back into a "0" or "null" form (to have a blank mind, or still mind), and then spring into a form, to assume an image in your imagination -- then back to rest again. That happening every time your neurons fire and form a thought -- is pretty amazing.
                            It's your own cosmic themesong, playing right into your antennae...
                            I find myself writing another long winded post -- So I'll wind around to some of the points I wanted to originally go over...
                            Why is "all mankind one"??
                            Well, our senses might not have grasped it yet -- but those sparks above us are definitely apart of our piloting mechanism. Are we really selfish enough to think that ALL those sparks in the sky are JUST for a SINGLE human? That's insanity to think that way.
                            If you can see the sparks -- I'll show you subjectively. If not, bear with me for a moment... The range within which we can see those "sparks" also somehow has to do with internal voltage pressure -- like the anti gravity conditioned field/chemically accelerated reaction zone -- "making invisible light, visible".
                            If you can focus real close to your body -- maybe seeing the white sparks within five feet of your hands -- try to jerk your fingers around a little bit in abrupt impulses.
                            (Hint: It's easy to see them up close on a cloudy day, when they're hiding from the sun)
                            Relax your muscles in between each impulse -- you might be able to see that your muscular twitches make the white sparks "dance" about quite well. If you flex different muscles hard enough -- you can get them to dance above their normal "agitation movement rate" by your "invisible body" -- its signaling intereference from quite a distance away....
                            The sky is the limit...
                            Dually noted -- if you can make the sparks dance around -- isn't water attracted to the sparks (or the sparks to the water?)?
                            If you've found you can move them -- you might be able to move water with that "energy", or with those "sparks".....
                            I figure, everyone should be able to -- as soon as they realize their body made up of a large percentage water.... With that in mind -- how do you already translate an impulse out of your body, into a body movement?
                            You'd have to move the water outside your body in the same way you'd move your body itself -- same type of impulse from your consciousness.
                            "As above, so below -- As within, so without"
                            Listening to me describe this, Reminds me of hearing about "fly ash".
                              [QUOTE=Farmhand;159392]
                              Uploaded with ImageShack.us
                              This is a Paw Paw flower. It looks like a propeller.
                              This is a potato flower, it looks like an antenna of some kind.
                              [URL=http://imageshack.us/photo/my-images/189/potatoflower.jpg/][
                              • follow up on the Fulcanelli research:
                                But, returning to our discussion: After Canseliet's visit to the Enclave of the Alchemists, apparently somewhere in the Pyrenees, Gerard Heym said that he only had vague recollections of his experiences in Spain, as though some form of hypnosis had been used on him to make him forget the details of what he had seen and been told.
                                One friend of Canseliet, who wished to remain anonymous, said that this meeting was "in another dimension... a point where such meetings are possible." The story was that Canseliet "received a summons," of some sort; perhaps telepathic, and traveled to Seville where he was met and taken by a long, roundabout route, to a large mountain chateau which proved to be an enclave of alchemists - a colony! He said that Fulcanelli appeared to have undergone a curious form of transformation so that he had characteristics of both male and female - he was androgynous. At one point, Canseliet said, Fulcanelli actually had the complete characteristics of a woman. Some of the more obscure alchemical literature does point to this androgyny. The adept going through the transformation supposedly loses all hair, teeth and nails and grows new ones. The skin becomes younger, smoother and the face takes on asexual characteristics.
                                This reminds me of what the Cassiopaeans had once said about transitioning to 4th density:
                                Now read the following: World Mysteries - Global Warming
                                Evidence of Atlantis can be found in the Pyrenees and Morocco, and in British Honduras, Yucatan, and America
                                After reading this...listen to the following....
                                Coast To Coast AM - 28.11.2011 - 3/4 - Stargates & the Light Body - YouTube
