  • Does this sound interesting Petar ...Aluminum
    Alum ( /ˈæləm/) is both a specific chemical compound and a class of chemical compounds. The specific compound is the hydrated potassium aluminium sulfate (potassium alum) with the formula KAl(SO4)2·12H2O. The wider class of compounds known as alums have the related empirical formula, AB(SO4)2·12H2O.
    Industrial uses
    Potassium alum is the common alum of commerce, although soda alum, ferric alum, and ammonium alum are manufactured.
    Alum is also used in purification of drinking water in industries. In a holding tank, some alum (phitkari) is added to the water so that the negatively charged light colloidal parts stick together, lighten, and float above (flocculate) when alum makes the colloidal particles neutralized by loading its aluminum ions with the colloidal parts. The heavy colloidal parts are then easily separated from the tank prior to further filtration and disinfection of the water.
    [edit]
    Cosmetic
    Alum in block form (usually potassium alum) is used as a blood coagulant.[citation needed]
    Styptic pencils containing aluminium sulfate or potassium aluminium sulfate are used as astringents to prevent bleeding from small shaving cuts.
    Alum was used as a base in skin whiteners and treatments during the late 16th century. A recipe for one such compound was given thus:
    "For the Freckles which one getteth by the heat of the Sun: Take a little Allom beaten small, temper amonst it a well brayed white of an egg, put it on a milde fire, stirring it always about that it wax not hard, and when it casteth up the scum, then it is enough, wherewith anoint the Freckles the space of three dayes: if you will defend your self that you get no Freckles on the face, then anoint your face with the whites of eggs." —Christopher Wirzung, General Practise of Physicke, 1654.
    Alum may be used in depilatory waxes used for the removal of body hair, or applied to freshly waxed skin as a soothing agent.
    In the 1950s, men sporting crewcut or flattop hairstyles sometimes applied alum to their front short hairs as an alternative to pomade[citation needed]. When the hair dried, it would stay up all day.
    Alum's antibacterial properties contribute to its traditional use as an underarm deodorant.[citation needed] It has been used for this purpose in Europe; Mexico; Thailand, where it is called Sarn-Som; throughout Asia; and in the Philippines, where it is called Tawas. Today, potassium alum is sold commercially for this purpose as a "deodorant crystal," often in a protective plastic case.
    [edit]
    Medicinal
    Alum is used in many subunit vaccines as an adjuvant to enhance the body's response to immunogens. Such vaccines include hepatitis A, hepatitis B, and DTaP.
    Alum in powder or crystal form, or in styptic pencils, is sometimes applied to cuts to prevent or treat infection.
    Powdered alum is commonly cited as a home remedy for canker sores.
    Preparations containing alum are used by pet owners to stem bleeding associated with animal injuries caused by improper nail clipping.
    Alum is listed as an ingredient of some brands of toothpaste or toothpowder.
    Alum powder dissolved in five parts water has been used to shrink hemorrhoids and stop them from bleeding.
    [edit]
    Culinary
    Alum powder, found in the spice section of many grocery stores, may be used in pickling recipes as a preservative to maintain fruit and vegetable crispness.
    Alum is used as the acidic component of some commercial baking powders.
    Alum was used by bakers in England during the 1800s to make bread whiter.[1] The Sale of Food and Drugs Act 1875 prevented this and other adulterations.[2]
    [edit]
    Flame retardant
    Solutions containing alum may be used to treat cloth, wood, and paper materials to increase their resistance to fire.
    Alum is also a component of foamite.
    Alum is also used in fire extinguishers to smother chemical and oil fires.
    [edit]
    Chemical flocculant
    Alum is used to clarify water by neutralizing the electrical double layer surrounding very fine suspended particles, allowing them to flocculate (stick together). After flocculation, the particles will be large enough to settle and can be removed.
    Alum may be used to increase the viscosity of a ceramic glaze suspension; this makes the glaze more readily adherent and slows its rate of sedimentation.
    Alum is an ingredient in some recipes for homemade modeling compounds intended for use by children. (These are often called "play clay" or "play dough" for their similarity to "Play-Doh", a trademarked product marketed by American toy manufacturer Hasbro).
    maybe this is the other moon stone Hermes was refering to also (Moonstone + Alum ) for the Crystal Battery
    • follow up:
      Chrome alum - Wikipedia, the free encyclopedia
      Chromium alum crystallizes in regular octahedra with flattened corners and is very soluble in water. The solution reddens litmus and is an astringent. Aqueous solutions are dark violet and turns green when it is heated above 50°C
      Follow the Colors they lead you to Green
        In Pythagorian Numerology
        ENNEAGRAM Corresponds to :
        555513214 = 31 = HM 4
        4 - High Priestess
        some of you guys maybe interested in this
        Georgia Guidestones - Wikipedia, the free encyclopedia
        The Georgia Guidestones is a large granite monument in Elbert County, Georgia, USA. A message comprising ten guides is inscribed on the structure in eight modern languages, and a shorter message is inscribed at the top of the structure in four ancient languages' scripts: Babylonian, Classical Greek, Sanskrit, and Egyptian hieroglyphs.
        Author: R.C. Christian
        let's have a look at the Pythagorian value:
        2 + 3 + 3 + 5 + 2 + 1 + 3 + 4 + 1 + 1 + 5 = 30 = HM 3
        3 - Emperor
        Motto:
        Potens Pater conservator orbis (Mighty Father, preserver of the world)
        Deities:
        Zeus, Jupiter.
        Dice:
        1+3 = Love+Male (Water); 2+2 = Couple+Male (Fire).
        Astragali:
        1+3+3 = Love+Ruler+Male.
        Greek Letter = Delta:
        Dike = justice, judgement, right; Dunastes = ruler, master.
        Trigram:
        III Name: Ch'ien = the Creative. Image: Heaven, Sky. The Father, associated with strength, creativity, firmness, endurance, purity and the word. South in the Earlier Heaven
        Description
        The Emperor is a mature man, robust in stature and grave in countenance. His coal-black, wavy hair frames a broad forehead over deep-set eyes; his thick beard is finely curled. Draped around his legs and over his left shoulder, leaving his chest bare and his right arm free, is a deep red himation (mantle), decorated with green foliage and seven golden flowers. He wears a wreath of twelve oak leaves on his head and sandals on his feet.
        The Emperor's bronze throne, which is richly ornamented with gold, ivory and ebony, and decorated with golden rams' heads, is on a rugged mountaintop surrounded by clouds. His right hand aims a glowing golden keraunos toward the ground; this is a stylized thunderbolt with a central orb, two points in opposite directions, and four "tongues of flames" around each point. His left hand holds a tall (3 m.) sceptre surmounted by a golden orb and an eagle with spread wings. A red eagle stands to the left by his feet.
        Verse
        The Mighty Father makes the laws that bind
        The elements, the plants, and every kind
        Of beast - but people too. He strives to feed
        The folk, defending them by word and deed.
        Observe the judgements fathered by his mind!
        Interpretation
        The Emperor represents the characteristically masculine aspects of consciousness, solar illumination, which demands clarity, but may be harsh and withering. He is the archetypal pater familias, the head of the clan, with both authority over the group and responsibility for its welfare. It is his burden to set down laws and maintain order, both within and without. Further, he is the executive, for he must ensure that his plans, laws and judgements are translated into action.
        The Emperor is the source of conscious spiritual and moral principles, in contrast to the High Priest, who is the source of spiritual and moral intuitions; they are the light and dark sides of the Eternal Masculine, the bright sun and the dark sun, the conscious and subconscious masculine minds. However, the Emperor and High Priest are further apart, and do not cooperate so well as their female counterparts, the Empress and High Priestess. Therefore the Emperor's himation covers his left side, to show his habitual repression of the subconscious, and that he may tend to dogmatism, rigidity and self-righteousness if his rule is not tempered by his co-regents, the Empress, Priest and Priestess.
        The Emperor does not, like the Empress, flow with nature; his fiery spirit leads him to impose his will on nature and to force her to conform to his artificial standards of order. As a consequence he is fundamentally alienated from the dark, Titanic forces of nature, and therefore vulnerable to their attack. Inevitably the Emperor will grow old and sick and require rejuvenation at the hands of the Empress, Priest and Priestess (see VI.Love and VII.Temperance).
        The character of the Emperor corresponds to the Tetrad, which is the reduced isopsephos of two of his titles: O KRONIDHS (Ho Kronides, The Son of Kronos, i.e. Zeus) = 532, reducing to 2-3+5 = HM 4; and QEOS O ANDRWN KAI QEWN PATHR (Theos Ho Andron kai Theon Pater, God the Father of Men and Gods, i.e. Zeus) = 2743, reducing to 3-4+7-2 = HM 4. The Tetrad is the principle of stability, tranquility, of four-square, solid structure; the Pythagoreans call it Justice and Perfect Harmony. (TA 27-9; see also the meanings of Delta, above, and the Fours in the Minor Arcana)
        • also found this from ATS , it mentions a triangle on the sun ( artefact found by Nassim Haramein .. )
          Ancient STARGATE Artifacts (Klaus Dona & Nassim Haramein) & Mayan 2012 (ILLUMINATION) - YouTube
          in the vid they mention the more Ancient The more Precise ..... you can add ....The Fractal is
          Here is a nice Fractal Animation...you should check it out:
          2010: A Mandelbrot Odyssey (FractalNet HD) - YouTube
          the music complements
          it very nicely
          • Let us mix the Esoteric with Science
            as you may have noticed HM 4 keeps on popping its head quite a bit ... so one more would not hurt:
            If you look at the following Table you see 4 Quarter which represent the Male Female Cycle...yet if you look closer each male and each Female are not quite Identical ( for one you have different elements on different quarters )
            so we can conceive due to their differences that each quarter can be represented by the 4 Tarot Cards:
            5 - High Priest
            4 - High Priestess
            2 - Empress
            3 - Emperor
            Arthur C Clarke - Fractals - The Colors Of Infinity - YouTube
            well worth it
            • Magnet Electrolysis Water Vortex
              Acidulated water, and magnets....
              • Originally posted by petar113507 View Post
                Thank you petar113507 , quite amazing an idea on the set up
                the user has a very nice playlist... he made a vid I have been looking for quite some time to share with you ...you should check it out
                Water Standing Wave - YouTube
                resembles this (from a previous post )
                10$ Dan Winter Imploder - YouTube
                • Earlier I posted on the Hindu Temples and Fractals .... but i also forgot to mention in light of Harmonic math:
                  The word Vimana means also : well proportioned
                  I have been looking for a picture of Hindu Sculptures with measurements unfortunately no luck so far....they all point to this book : Indian sculpture & iconography: forms & measurements - V. Ganapathi - Google Livres
                  as we need only one picture ....
                  anyway if you happen to be in a University .... you can access the university library and probably access the book too ... i believe there is a gold mine of info in there that could benefit us all
                  while we are on vimanas:
                  Arthur C. Clarke's Mysterious World: Strange Skies (1980) - YouTube
                  remember all the weird objects seen around the sun lately UFO/ Lense effect ...etc ; there is an interesting bit about the sun in the vid (12 min ) about the Legend of Vulcan also Check out 19 min .... talks about triple junction on pisces
                  • It just dawned on me :
                    while reading through the http://www.energeticforum.com/renewa...-true-122.html thread
                    why was it so hard to understand Don Smith (at my level ) while Tesla's inventiveness so Clear to understand ( from a non initiate that is )
                    which lead me to think that the more time flowed the more likely Patents were Censored
                    which is actually the case...National Security oblige (ie Military )
                    and the defense budget over time ....has grown as well ....
                    epiphany .....
                    • If it is ok with you Guys (Petar , Blackchisel97 ):
                      Was aked about Harmonic Math and its various uses , thought would be useful to you how i think it works (fractal ...so it is not restricted to this one answer ) :
                      MonsieurM, How do you use your Harmonic math? I've followed you in many aspects, but I seem to be a bit lost in the math you have usually...
                      I think it might help me somehow with russell's posters... I'll try to outline something useful in russell's posters before I ask for anything further.
                      Just a moment,
                      ==Romo
                      It comes as an "instinctual reflex" (whenever i see numbers i reduce and if a pattern appears ) .... the idea is that Math as we know it is just the Male Component (expansion ) of the True Math .....the Female Component of it is Reduction ie Harmonic Math
                      for instance if you take the example of Tesla Circuit and you know his Math is correct.....if you reduce his numbers .... you'll also see that in the female pole perspective his Reduced Math is also Correct
                      and after that you let you instinct lead you in the Harmonic / Reduced Math
                      if Normal Math is rational ....Harmonic Math is Instinctual
                      ps: This Instinct like any other needs to be bridled ... for you will go through a phase when certain numbers will pop all around you ... learn to smile at it and go along you exploration of this new world , don't make a fixation on it ( it just is ) ....Tesla fell into an obsession with the number 3
                      • wouldn't an Alchemist (ie Kybalion ) Agree with him:
                        Nikola Tesla - Wikipedia, the free encyclopedia
                        Field theories
                        When he was 81, Tesla stated he had completed a "dynamic theory of gravity".[89] He stated that it was "worked out in all details" and that he hoped to soon give it to the world.[90] The theory was never published.
                        The bulk of the theory was developed between 1892 and 1894, during the period that he was conducting experiments with high frequency and high potential electromagnetism and patenting devices for their use. Reminiscent of Mach's principle, Tesla stated in 1925 that:
                        There is no thing endowed with life—from man, who is enslaving the elements, to the nimblest creature—in all this world that does not sway in its turn. Whenever action is born from force, though it be infinitesimal, the cosmic balance is upset and the universal motion results.
                        Tesla was critical of Einstein's relativity work, calling it:
                        ...[a] magnificent mathematical garb which fascinates, dazzles and makes people blind to the underlying errors. The theory is like a beggar clothed in purple whom ignorant people take for a king ... its exponents are brilliant men but they are metaphysicists rather than scientists ...[91]
                        Tesla also argued:
                        I hold that space cannot be curved, for the simple reason that it can have no properties. It might as well be said that God has properties. He has not, but only attributes and these are of our own making. Of properties we can only speak when dealing with matter filling the space. To say that in the presence of large bodies space becomes curved is equivalent to stating that something can act upon nothing. I, for one, refuse to subscribe to such a view
                        and my Favorite:
                        "If your hate could be turned into electricity, it would light up the whole world."
                        ------------------one more thing:
                        Was Nikola Tesla A UFO Contactee?
                        In the more than 60 years since his death, Nikola Tesla has never ceased to be a fascinating, mysterious figure dwelling somewhere outside the borders of history as it is understood by the unseeing masses. While we as a 21st century civilization continue to reap the benefits of his outsized genius, Tesla has yet to be given the recognition he deserves as a major architect of the relatively technologically comfortable age we live in.
                        Still, there are those of us who do give Tesla his due, belatedly but sincerely. This article will deal with an aspect of Tesla’s genius that has gotten short shrift even from those of us who revere his name: UFO contact.
                        And that theory is nowhere better espoused than in "The Lost Journals of Nikola Tesla" by Tim R. Swartz. Swartz’s bestselling classic has recently been updated and reissued by Global Communications and is worth a new look whether you’ve read the first edition or not.
                        "Tesla was born in Yugoslavia," Swartz said, "in what is now Croatia, at midnight between July 9 and July 10 in 1856. He had that spark of genius right from the very beginning. There are a couple of people, I think, throughout our history, that you could classify as a ‘super genius.’ That’s the best word I can think of. Most people would agree that Einstein was one of our greatest geniuses. Maybe Leonardo da Vinci. And Nikola Tesla should fit right up there with those guys, because he just seemed to have this mind that was open to the universe.
                        "I suppose that’s a rather esoteric way of looking at it," he continued, "but he had the ability to visualize his ideas to such a point that he could actually ‘see’ what he was visualizing in three dimensions. As he put it, ‘It seemed to hang in the air right in front of my eyes.’"
                        This also begs the question: Did aliens have some kind of part in leading Tesla to create what he did? It is argued in the controversial book "The Day After Roswell," by the late Colonel Philip Corso and his collaborator Bill Birnes, that recovered alien technology was reverse engineered and used to lay the groundwork for numerous inventions, including fiber optics and much else in the way of technology we take for granted today. One sometimes wonders if the aliens more likely are implanting the seeds for, or even directly "inspiring," through some process of implanted thoughts, some of the marvels of the current age (some call her the Virgin ).
                        "There are many who believe," Beckley said, "that Tesla was actually a ‘star child’ of sorts, that he was born on another planet and left on the doorstep of his adoptive parents. This speculative theory was first offered in a long out-of-print book by Margaret Storm and a later tome by Commander X titled ‘Nikola Tesla: Free Energy and the White Dove.
                        Number 3
                        • STYX come sail away- lyrics - YouTube
                          Come Sail Away lyrics
                          Songwriters: Deyoung, Dennis;
                          I'm sailing away
                          Set an open course for the Virgin Sea
                          'Cause I've got to be free
                          Free to face the life that's ahead of me
                          On board, I'm the captain
                          So climb aboard
                          We'll search for tomorrow on every shore
                          And I'll try, oh Lord, I'll try to carry on
                          I look to the sea
                          Reflections in the waves spark my memory
                          Some happy, some sad
                          I think of childhood friends and the dreams we had
                          We lived happily forever
                          So the story goes
                          But somehow we missed out on the pot of gold
                          But we'll try best that we can to carry on
                          A gathering of Angels appeared above my head
                          They sang to me this song of hope and this is what they said
                          They said, "Come sail away, come sail away, come sail away with me lads
                          Come sail away, come sail away, come sail away with me baby
                          Come sail away, come sail away, come sail away with me"
                          I thought that they were Angels, but to my surprise
                          We climbed aboard their starship, we headed for the skies
                          Singing, come sail away, come sail away, come sail away with me lads
                          • In regards to the mention of Tesla:
                            Tesla's book "My Inventions" reads more as a "Life of Tesla" if one does not step back and notice that there are some really odd stories told. What makes them odd is that from a conditioned perspective most would probably finish the book with disappointment in that there is nothing mentioned that has not previously been mentioned in many other patents, articles and books.
                            If it is read with a "Hermetic Eye" it becomes a completely different book. Here are some examples of odd stories that are in a book about the inventions created by a person.
                            Interested people have often asked me how and when I began to invent. This I can only answer from my present recollection in the light of which, the first attempt I recall was rather ambitious for it involved the invention of an apparatus and a method. In the former I was anticipated, but the later was original. It happened in this way. One of my playmates had come into the possession of a hook and fishing tackle which created quite an excitement in the village, and the next morning all started out to catch frogs. I was left alone and deserted owing to a quarrel with this boy. I had never seen a real hook and pictured it as something wonderful, endowed with peculiar qualities, and was despairing not to be one of the party. Urged by necessity, I somehow got hold of a piece of soft iron wire, hammered the end to a sharp point between two stones, bent it into shape, and fastened it to a strong string. I then cut a rod, gathered some bait, and went down to the brook where there were frogs in abundance. But I could not catch any and was almost discouraged when it occurred to me dangle the empty hook in front of a frog sitting on a stump. At first he collapsed but by and by his eyes bulged out and became bloodshot, he swelled to twice his normal size and made a vicious snap at the hook. Immediately I pulled him up. I tried the same thing again and again and the method proved infallible. When my comrades, who in spite of their fine outfit had caught nothing, came to me, they were green with envy. For a long time I kept my secret and enjoyed the monopoly but finally yielded to the spirit of Christmas. Every boy could then do the same and the following summer brought disaster to the frogs.
                            The "Hermetic Eye" will show flow and control of energy and possibly applicable design considerations.
                            One evening, in the winter of 1885, Mr. Edison, Edward H. Johnson, the President of the Edison Illuminating Company, Mr. Bachelor, Manager of the works, and myself, entered a little place opposite 65 Firth Avenue, where the offices of the company were located. Someone suggested guessing weights and I was induced to step on a scale. Edison felt me all over and said: "Tesla weighs 152 lbs. to an ounce," and he guessed it exactly. Stripped I weighed 142 pounds, and that is still my weight. I whispered to Mr. Johnson; "How is it possible that Edison could guess my weight so closely?" "Well," he said, lowering his voice. "I will tell you confidentially, but you must not say anything. He was employed for a long time in a Chicago slaughter- house where he weighed thousands of hogs every day. That's why."
                            Maybe a reference to some aspect of design being between 152,000 and 142,000?
                            The whole book "My Inventions" can be read online here:
                            My Inventions: The Autobiography of Nikola Tesla
                            Here is an analysis of Tesla's comments regarding Mars. It's an interesting read with data regarding planetary signals and related information:
                            www.teslasociety.com/mars.pdf
                            • some info:
                              Scientists build graphene from scratch, heralds new age of designer materials | ExtremeTech
                              You’ve heard of “designer babies,” the idea that you can customize a baby by altering its DNA, but now a team of researchers from Stanford University and the Department of Energy have meddled around with the very fabric of reality and created the very first “designer electrons.”
                              As you probably know, the bulk of the universe is made up from just a few dozen elements, and each of these elements is made up of just a few subatomic particles: electrons, protons, neutrons, quarks, and so on. For the most part, the properties of every material — its flexibility, strength, conductivity — is governed by the bonds between its constituent atoms, which in turn dictate a molecule’s arrangement of electrons. This is most obvious in elements like carbon, where a single element can form materials as different as charcoal, graphene, and diamond, all by virtue of different electron arrangements.
                              In short, if you can manually move electrons around, you can create different or entirely new materials. That’s exactly what Stanford University has done: Using a scanning tunneling microscope (the blue point in the image above), the team of researchers placed individual carbon monoxide molecules on a clean sheet of copper to create “molecular graphene” — an entirely new substance (pictured right) that definitely isn’t graphene, but with electrons that act a lot like graphene. The team, which was led by Hari Manoharan, then proceeded to move these individual atoms around, changing the structure and electron arrangement of the material.
                              “One of the wildest things we did was to make the electrons think they are in a huge magnetic field when, in fact, no real field had been applied,” Manoharan said. The team simulated where the atoms would be if there was a magnetic field, and then proceeded to move the individual atoms into these positions. Weirdly enough, the molecular graphene then behaved as if it was in a magnetic field. In other words, the presence of a magnetic field is neither here nor there: What really matters is the position of atoms and their effect on the arrangement of electrons.
                              What Stanford’s discovery means is that we could soon be looking at all sorts of new, designer materials. To reiterate, the physical properties of almost every substance is dictated by the position of atoms and the arrangement of electrons. The only reason that semiconductors exist — the only reason that the world is littered with computers, that I can write this story, and that you can read it — is because of the electron structure of atoms like silicon and germanium. The reason the table in front of you is a table is because of the way carbon atoms bond together.
                              Stanford University now has the power to create new materials and to tweak the properties of existing ones. It might turn out that silicon, by moving an atom slightly, can suddenly operate at higher speeds and leak less power — or maybe that copper wire can be made more conductive by slightly altering its electronic makeup. Really, though, it’s impossible to imagine the materials that scientists will end up making. For all I know, someone might create a version of oxygen that’s polka dotted, or iron that explodes under pressure. Exciting times!
                              • Thank you Llynch for the info .... dwnloading the mars doc
