sec exciter SEC 18-1 ?? help
  • sec exciter SEC 18-1 ?? help
    hi i just got my SEC 18-1 and i got a bread board and some 32 leds ordering more and iv run into a problem. There is no information on how the leds should be hooked up to the SEC 18-1 all i know is that the L3 coil output goes to the leds are they in series or parallel is there another connection to leds from the board are the extra diode looking thing's important? any help would be greatly appreciated ty
    I don't own one, but might be able to help.
    One good idea is to pour over related video's on YouTube. I know Lidmotor has used this type extensively and his channel would be good to check out.
    The diode thing may be an AV plug ? Is it 2x diodes soldered together at one end ?
    If so, the two diodes ends go to the 2 LED connections. One diode should face one way and the other face the other way. Black band denotes the negative end.
    Normally, and if that is what it is, you'd then have a small amount of 20'ish gauge wire hanging off the free single end of the diodes...this collects usable HV output from devices like the SEC.
    If you have 1 wire connectivity instead of pure wireless energy, then the end of the diodes that is soldered together links via a wire to *probably* the L3 coil.
    I think the LED's are connected in series...again check Lidmotor's channel for the confirmation.
    Hope to hear that you get it running.
      thanks that helped im going over youtube stuff now
        got it working yea diodes and ground woot really cool
