Confirming the Delayed Lenz Effect
  • He is getting power to the LED via induction, his amp meter show no draw because of this !
    The coil is being powered by his frequency generator, and the LED (with it's own little core and a few wraps of wire) is taking power via induction.
    Nothing magial here.
    • Indeed an interresting Video.
      [I guess the rule for the delay time would come down to the speed and physical size of the rotor pole magnet, not the amount of poles]
      I am no more than agree with you !!!
      Impressive.
      I come to an other Conclusion, i had once a CD Rotor with 2 Magnets, and the another with 6 Magnets, they got both he same Size.
      Both did spin at the same Frequency over a trigger coil inside, just the Rotor with 2 Magnets did turn faster then the 6 Magnets Rotors.
      Therefor i say, its more a a Case of how fast the Coil get charged, and how far the Push is, what it gives the Magnets.
      The Advantage or disanvatage is, that you have a pysically faster Rotor with lesser Magnets, but the Frequency from the Coil will be the same.
      • @Joit
        Ok then, I will test the whole sets, i mean both, and post again. Thanks.
        • "Anyway I'm saying this because I've noticed that your input power didn't decrease while you were dialing from 200 to 950 Hz, which it should since the impedance of primary is going up. it's also possible that at 950 Hz you are getting close to a resonant or sub-resonant spot of your secondary. In that case it would mean that you would see an increased primary consumption in no load condition, and decreased primary consumption in load condition because the load, depending on its resistance, is shorting and diminishing the resonant condition".
          Mario's working theory describes just what we witness in the bifilar resonance
          video.
          • Halo's.
            Ringing an axeled magnet spinner with a hi voltage wrap will produce the propusion shift. Here's a quote from the first test under load:
            "I sucessfully wound and tested the Plumber Tape spinner spool coil. Eight and a third volts rectified D.C. output more from the core spinner coil than from the same amount of wire and wraps in a Radio Shack coil that only outputs three and a half volts held in adjacency. Over twice the voltage from the magnet spinner spool axel wraped with one skien of RS red magnet wire, then the amount on an output coil of the same siize held close to one side." That's because the spinner began to race from " Delay Propulson Effect", after the load was attached! The output was compared to an output coil causeing "Lenz Drag".
            Take an empty latex tape large blue PLUMBERS TAPE spool, wind it full of 30Awg, then power it up from a seperate power coil, and see what happens when you short the Halo Coil!
            A ring of 6 or 8 Halo coil satillite magnet spinners may power up enough from a prime mover spinner in the center, to cross the "Lenz Delay Threshold", and gain in acceleration when shorted!
            • @ AB, what was the load type/resistance ?
              I wound a new coil today and ran the same tests for my rotor device, the results are fairly similar :
              AUL EFFECT 0.5 VOLTAGE RANGE TEST COIL 250mH 120 Ohms.xls
              What i wasn't expecting was this (i'm pasting my post from overunity.org.uk where i am a moderator by the nick of DeepCut) :
              "OK this is getting interesting, i ran the diametric spinner at 18 volts, i then put on a miniature light bulb i got from Maplin (can't remember it's rating), the frequency rose by 5 Hz and the current draw dropped by 5 mA.
              I'm looking for other loads to try, I CAN'T SLEEP NOW !"
              So, a real-world load (albeit a tiny one), with an increase in frequency/RPM and a decrease in current draw.
              I can sleep now
              • Halo coil output.
                I ran the plumber spool magnet spinner over a red Radio Shack coil wire to a rectifier, and lit an LED got 7.58 volts and 1.75 amps D.C. coming out of that jasper. The power source was a 12 volt RS alarm battery at 12.25 volts. This is while speeding up! I believe the effect is doubled when the magnet poles have two coil ends to work from the "Lenz Delay" shift.
                This discovery led to my other nested coil core designs.l
                I dug up a picture of it. It's the blue plastic spool and magnet visable lower right. click on and magnify the picture. The spool has a hi inductance wrap and exhibits 2X"s the "Lenz Delay Propulsion". Attach the 7 volt LED thru a FWBR, and watch the spinner accelerate! This is a new generation in alternator design, that integrates LDP, "Lenz Delay Propulsion" and nested rotor.
                • I've upped a video of acceleration-under-load rather than just short-circuit.
                  The rotor speed rises by only a few Hz, and the milliamps only go down by a few but the effect is there and will be amplified with higher impedance coils.
                  Acceleration under load - replicating the Heins Effect ... - YouTube
                  • Hello You All,
                    Finally I have hooked up a Second Hand MOT (Microwave Oven Transformer)
                    Directly to my frequency drive controller. To be more precise, it is connected to the frequency drive controller by a 2.2 Ohms resistor, so that I can show the primary amperage going to my primary. And that I am able to show the phase angle between the voltage and the amperage on the primary side of my MOT.
                    I found that the results obtained are exactly the same as in my previous experiment about the home made transformer with a very high impedance secondary coil.
                    So this time I only have used normal Off-The-Shelf components. So please see my New Video about the Delayed Lenz effect on:
                    MOT Microwave Oven Transformer Delayed Lenz Experiment - YouTube
                    It looks like my LED Light Bulb (load) on the secondary is running purely on reactive power by now!
                    With Kind Regards, Overunityguide
                    • I don't know OUG, some of your videos are not adding up...
                      Trust your own instinct. Your mistakes might as well be your own, instead of someone else's ~BW~ It's kind of fun to do the impossible ~WD~ From now on, I'll connect the dots my own way ~BW~ If I shall be like him, who shall be like me? ~LR~ Had I not created my whole world, I would certainly have died in other people’s ~AN~
                      • Originally posted by Allen Burgess View Post
                        I didn't quite understand what you did, can you explain further. This might be important.
                        http://blog.hexaheart.org
                        • Halo Magnet coil.
                          @elias,
                          This is important! I'm glad we agree. The design is so simple, it's easy to describe. The magnet's spinning inside an output air core coil wired for hi voltage around it. The skin of the magnet spinner meets the edge of the pancake spool magnetic field. I believe this design doubles the "Lenz Delay Propusion" effect. Naturally, you have to power the spinner from a different generator. I'm trying to run a sphere up inside the air core of a half pound of 30 AWG. The other factor is the inclusion of a load. The wire goes unoticed by the spinner if left open. The acceleration only takes place while under load.
                          The design looks like an Omega! The spinner axel bridging the circle of thin wire wraps, to compare the shorted to the open rotor speed above threshold frequency.
                          @overunityguide,
                          Thane apparently believes the (MOT) may be overunity. Any plans to try and self loop and power itself?
                            @elias,
                            I get it, you mean spinning a magnet inside a high voltage air core? Almost like the Newman Machine?
                            If you get acceleration by an air core THAT IS SOMETHING serious! I have my Newman motor disassembled. Can you tell us the speed of your magnet when the effect manifested? Also some info about your coil will be useful.
                            BTW What do you mean by the pancake spool?
                            • It might be a bit off to call it an aircore when there's a magnet filling most of the space. I think "Magnet Core" would be better. The surrouning output coil is wider then it is long, hence the pancake description. Thin wire!
                                That is the description of the Newman Machine:
                                The Newman's Energy Machine tested by JL Naudin
                                Can you tell us what was your rpm? I am going to set my newman machine with its large coils up again. Its coils are about 7 Henrys, really thousands of thousands of turns, I need to grind some new magnets I have bought for it to fit it inside. As I tested the motor about 10 months ago, it was a really efficient motor, very close to 100% efficiencies, but I could not verify above 100%.
                                Now you siggest me use it as a generator, that makes sense, but I didn't expect acceleration, let's see.
