"Being myself a remarkably stupid fellow, I have had to unteach myself the difficulties, and now beg to present to my fellow fools the parts that are not hard. Master these thoroughly, and the rest will follow. What one fool can do, another can."
What is the natural voltage in power grid in your country ? Did you tried with transformer method to step up or down voltage ? Can you elaborate ?
Reason: add info
Slovenia I am anxious to Cut the Diamond??
Can you get a few overall dimensions and some instructions from your Contact?
Thank you
Chet
PS
I must admit I am confused by the Professors Graph?
The 8mm bolt is attached to the threads on the thermos.
Inner & Outer Stainless sleeve, tube, are cut to exact same length. The tubes are tuned by grinding a very sharp edge on both ends of each tube. Take care to keep both tubes the same length!!
Reason: changed one word
Mathematics and Physics to calculate COP of sonic boiler:
For L of water to raise to 13.5 degrees Celsius for 10 minutes should be = (5000ml x 13.5 x 4.19) / 600 = 471.375 Wat / sec power. To calculate the base of the cliff COP heaters require a balance with two decimal places to excrements vapor and heat thermometer and multimeter to measure voltage and amperage draw of heater input. This is how it works.
Reason: Removed Line
Well I suppose the best way to understand what this device is capable of is to finish my build and FIRE IT UP!!!!
A thought to my fellows...............
I was speaking to my friend this AM and he was sharing how his Mom just got a new Gas Furnace ,Its 97 % efficient !
A thought occurred to me an alliance of sorts with the powers that be??
My Poor underprivileged electric company benefits in no way whatsoever from the Revenues that are expended to heat my home!!
Very Sad indeed............
My Thought
If it becomes obvious we can make more heat with less electric .to the point where it becomes more efficient than gas???
We will all have a new friend ...............
and a much cleaner and cheaper way to heat our homes!!
Its not always what you know Sometimes its who you know ??
S
Duncan said he found the Amps were falling off in his experiment?
Now I want the dimensions even more!!
Please
Chet
Hi Ramset yes its true the Amps do drop down considerably when boiling, But I'm not at all sure that isn't to be expected as a “change of state “ occurs ice to liquid and liquid to steam. I think the “specific heat”equation changes. The whole operation is far from linear .. I know my focus on this meter is poor but its always in circuit reading the current at 10A FSD I’ve since tested the meter and it is pretty accurate .. if you watch the meter back mirror carefully you'll see the current draw is really so small as to be unreadable until about 1.40ish when it starts to climb, climbs to a maximum of perhaps 1 1/2 amps and then drops right back down when boiling... almost like pulling a Bow back and then letting the arrow fly.bubble.wmv - YouTube
What would be really helpful is a recording temperature gauge along with the changing current.
Of course I then found varying the distance between the plates altered the dynamic of that “low current high temperature change.
I was trying as you Know to bring a capacitance box into play in order to try and discover a way to tune the machine (still waiting for better switches that don’t arc and pop for no reason)
I was researching sympathetic waves as I assume was MonseurM and came across the same winding system. At first sight there would seem to be no connection between the one subject and the other but ...Its all based on variables and “sympathetic frequencies” and I'm just trying to see a way to tune .. although of course I can already see the figures are impressive.
I can tell you this much However well we do with this project and we are already progressing well the ramifications of what's occurred as the result of a bungled “double assassination” which resulted in these “cells” coming into operation in different countries. Working OU wake up. We are the People Save it now!!!!! - YouTube has forever changed the equation.
I just wish I could see a way to bring it into play here.. although I must confess was starting to think along the lines of fitting a SWR meter in the feed line.
