I'm trying to find some expedient frame material for the prototype. I may just have to go with plywood. I need something fast and readily available. I know there are expensive alternatives and I don't have that luxury right now. Thanks!!
Slovenia
This device may have other benefits Too?[Mr "C's"]
Health benifits [if properly manufactured for that purpose}!
From MasterPlaster at OU and OUR
A VERY informative and recent Patent
Well, you are going to have to cut the top off the can and tune it to 60 hz. It needs to be 200 mm in length for the 60 hz deal, so you may need to add metal as I have with the American cans. Anyway, measure the length of the can from the bottom up to the top round of the can and let us know that measurement. Thanks.
The steel can will work really well for the ring material because it is fairly easy to work with and solders up nice. I would highly recommend using three thicknesses of can however to strengthen the ring. This is best accomplished by folding the material over several times making it three thicknesses of material all attached together as one. You need a can with a circumference of at least 10 inches for this to work properly. You need to take care not to warp the material while rounding it up. It has a tendency to not want to bend the way you want it to and warp in strange ways in the radius of the ring. Three thicknesses will give it more strength but will also make it a little harder to work with. Two thicknesses is just not strong enough. Round your flat up with say a 2.5 inch fence post and then mark the outside of the flat where you are going to put your 90 degree bends to the outside of the ring. Be very accurate where you put your bend because this will effect the gap distance between the ring and the can which is critical according to Mr "C".
This PDF is from another post. It is very interesting explanation of Peter Davey’s device. I attached in case someone didn’t read it.
We obviously need a sound generator in order to make it work. And that guy from Serbia said something about sound and tuning. He said that you need a needle attached to thread which touching the can. Purpose of that can be tuning the beer can on resonant frequency 50 or 60 Hz.
Does anyone know where I can find sound generator program for XP?
This device is a gift.......Could not be any simpler!!
How it works will no longer be a mystery!!
It has No secret VooDoo, [not implying any derogatory comments here] no crazy electronics!
What I am Saying is boluslaw is Correct, this thing works do to forces that we havent completely gotten our brains around yet!
If you prayed for a simpler venue to experiment with,the next simplest would have to be the Wheel!!
This is gonna be a good learning experience for the entire community!!
Thanks Again Slovenia !! I am really starting to get excited
And thank you boguslaw for bringing your wonderful thoughts to this thread
They inspire..............
I found a slick method of rounding the ring flat so that it's true and doesn't warp.
First, attach a vice grip to both ends of the flat three layer can material. Now lay a 2.5" steel fence post across the flat and stand on both sides of the fence post to hold it in place over the ring flat. Now carefully pull up straight with both vice grips forcing the ring flat against the fence post. Now pull the ring flat back and forth against the fence post the full length of the ring flat about ten times. This will give the ring flat memory and remove any chances of for warpage. Remember to pull straight and with even pressure on both vice grips. This is very important. I have tried this and it works very well.
