  • sweet............
    I forgot all about these guys ,sorta funny too
    Years ago I was building a core rig [multiple cores] for a high speed rail application [Amtrak]and these fellahs were one of my suppliers
    Polished Stainless Steel - Tubing - Solid Bars - Stocking - Metal - Fleischer Tube Distributors Corp. - Your Metal Problems Solved
    Now the funny part ,Yah know how every body is all 'CAREFUL" with elec and water.Well ,... years back as a side job I would go down into the subways {on a fairly regular basis] And have to Core drill over the live rail .on the ceiling the walls and right next to the track on the Tie ............. [600 amps dc].
    Piece of rubber over the rail ........... that was my protection plus common sense!!
    Oh just for clarity You run water thru the bit when you diamond core drill!!
    true story ... they could never shut the rail down for me and the test lab had no one else to take those samples [chickens] .
    Any how the point is be safe .......... and you will be!
    They're gonna see if they have some tube in stock, if so I'll send you some with the expander!
    Gotta go back to work
    Chet
    BE that change !!
    • Thanks!!
      Thanks Chet!! Your the Man!!
      Chet
      • Slovenia, not to be a nag, but you gonna be able to cut that? After all it is fully hardened. Yea what was I thinking it is shim stock though.. it is designed to be cut. Just ignore me.
        • Hardened
          Tektron,
          You well may be right. Thanks for sharing your thoughts on it!! No, I saw the hardened too. It may be a case where it has to be heated before we could cut it. Ideally it should be cut on a shear to insure perfect cut with no warping and no material loss. I don't have a shear but that piece would make a bunch of rings.
          Best Regards,
          Slovenia
          • It's interesting that I found kind of metal plate almost with required dimensions.I'm in other town now but I think there is already ready piece of metal 0.5mm wide and 0.2mm thick used for something , which I wasn't able to figure out. I found that when I cleaned my attic.
            • Heating Element
              Companies sell heating elements of this dimension. That's probably what you found in your attic.
              • Heating elements??
                S, do you have a link?
                I spoke with my old supplier today he has .060 and .110 in stock , I believe its 16 gauge and 11 gauge respectively?
                we need .080 which is close to 12 gauge [very close],Everything took for ever to do today ,its ruff working on the road ,not like at my own shop!!
                very hard to call peeps and get Putor time here! gonna be at least a few more days of this too .
                Have you heard from Mr.C??
                Chet
                BE that change !!
                • just got your mail
                  Slovenia
                  You've done the right thing.................
                  I will do the only thing I know to do in times like this,
                  Pray!!
                  Your friend
                  Chet
                  BE that change !!
                  • Heating Elements
                    Heating Elements
                    http://www.sisweb.com/ms/wire-stainless-steel.htm
                    Chet
                    • Muffler shops
                      Slovenia
                      Call the muffler shops in your area ,high end exhaust these days is stainless!
                      2.5 inches is a standard size ...we can stretch it to where we want it!
                      I'm sending the spreader tomorrow, have a good night
                      Chet
                      BE that change !!
                      • I may have 2.5" in my garage
                        I used to be a very serious Joe Cell guy. I may have some in my garage. I know my supplier has it and it's relatively cheap.
                        My supplier is Voracious Motorsports. I think they're out of NJ.
                        Slovenia
                        Chet
                        • Guests??
                          Have you seen the number of guests we have checking us out?? There's 26 of them this evening at one time. That's a bunch.
                          Are these your buddies Chet?
                          • Cut-off Saw
                            I have an industrial abrasive cut-off saw too Chet.
                            This was all necessary equipment when I did hydrogen with all the stainless tubes. I think my outer tubes were 5" on my Oz Nitro Cells. Shame we couldn't figure out how the Germans made those work in their tanks during WWII.
                            • I sure hope there our buddies S
                              Instinct ,
                              People know there's something here,I have to say we are going to learn by this experience ,and its not going to be "Peter Davey was Nuts!
                              More like "There's a better way to heat water" If you take it to the most Basic level, the iron resistor in the kettle [which I am going to pick up for a baseline]
                              it doesn't move the water it sits there stagnant ,sure the heat moves through the solution , but its lame.
                              This device utilizes the electricity like a flame it becomes one with the water
                              moves right thru like a living blow torch agitating, mixing, bubbling, working,
                              Fast Very fast!!
                              And then maybe we find out why this device is built the way it is?
                              Slovenia this is gonna be tons of fun ,I can't believe we actually have
                              a device that I have all the skills to build!Tolerances and all..........
                              I am freaking happy!!
                              Thank you so much
                              Chet
                              Ps
                              I forgot to tell you ,several years ago there was a man who was always just picking on guys [on the forums],He was a very smart German electrical engineer,we battled all the time.
                              He was always right ...........
                              well we became somewhat friendly and one day he told me how he had a device in his heating system that heated up the water jacket
                              He said it was an open circuit of raw voltage configured a certain way,i never pressed him for details because he said it could be very dangerous [I thought plasma]It was Much much more efficient than any thing out there saved him a lot of money
                              But it was illegal to have it this way.
                              his stock went up with me big time right there!!
                              WE are going to learn something here .................
                              Something Good!!
                              Chet
                              BE that change !!
                              • I sure hope their our buddies
                                There's a bunch of them watching. I've been watching them. Most of the forum members lurk without saying a word either.
                                Instinct ,
                                Chet
