grounding suggestion
Gents {and Mrs db]
I want you to understand something ,you can play with this very safely!!
Here is a technique for doing a good ground [extra ground].
I take a standard grounded plug I wire up only the ground [the other two poles are empty]
I plug this cord [25 ft ... or whatever] into another grounded outlet close to where I am working I CHECK THIS GROUND with a meter probe the hot and it lights .....I have a ground .... no light [or reading ] NO GOOD!!
Once I have finished my test run ,I unplug Professor Savics Device
Take the plugged in ground .... drop the end in the tank ...Take My meter [make sure its on and set properly] ... remove the ground lead from the water
clip one wire to my ground place the other meter lead in the water .
No reading at all ??
Set meter to DC
Still no reading??
Your water has no charge remaining.
Remove device............
You can of course leave your ground probe in the water at all times [connected to the neutral on the device or ground post in the water].
I er on the side of caution ,as this device is not supposed to do what it Do!!
Chet
Gents {and Mrs db]
Set meter to DC
Still no reading??
Chet
