  • Message from Mr. "C"
    Sound Generator Instructions:
    First join the sub-woofer to the amplifier and the computer and launch mono tone generator output and enroll 60 Hz. It is used a tone not three.
    Cap the cans can play at 120,180,240,300 Hz it was 2.52 mm otstojanju at 220 V or 1.725mm at 110 V 60 Hz for maximum efficiency boiler.
    Cap is made of steel for the battle of the bells and brass 70 mm diameter, 0.5 mm thick it is playing at 228.57 Hz and must be slimmed down to 180 Hz to 200 Hz USA or EU.
    Frekvenciometrom must measure the frequency of bells.
    Peter Davey Info.:
    When the original sonic boiler Mr Peter Davey ball is made ​​of brass or silver plays on a cap 1000hr playing of steel or brass to 350 Hz within the ball nlazi is another cap of hard steel at 49 Hz. It is 2.1 mm from the ball which enters a little water that enters from the bottom of the ball.
    highly heated vapors from the ball goes out through tiny holes under the cap and a very heated water.
    phase is connected to the cap inside the sphere and zero for the top hat.
    I am not able to create original sonic boiler because I had a quality hard steel for the inner cup, because the material was shot in the polishing.
    • US Gap (Serbian Boiler)
      for 110 volts it is 1.725mm
      for 220 volts it is 2.52mm
      This is very important!!!
      • EU Gap (Serbian Boiler)
        For Europe, the gap remains 2.1mm!!!!
        • Setting up 220
          WELL WELL WELL
          Hows it goin slow poke??
          Only kiddin
          I had a few problems to sort thru ,220 issues .
          I am still not certain we can do things this way with 220 and expect the same results as our European friends.
          WE will be mixing phases two 110 lines out of phase with each other?
          As opposed to our friends with 50 hz they have one nice [in phase] 220 line that gets a neutral .
          We shall see ??
          I am actually not even sure if I can get good Watt measurements??
          I will attempt to run My two 110 legs into two killowatt meters [one on each phase/leg] I don't know what to expect ?? Could roast my meters??
          I'm going back to the shop .....
          Chet
          BE that change !!
          • In the stretch [not the home stretch]
            Had to make some changes for bigger [ikea] ring ,hope I don't snap it doing a cold stretch because of PVC
            Still gotta stretch .. plus you see I'm still trying to figure an "open" no weld Mount !
            BE that change !!
            • Innovative
              Very innovative. Great ideas!!
              • Design Changes
                Design Changes
                I decided to make a few design changes to my electrical connection points such as mostly ring holder but then I changed the support for the tubes too. The ring holder scenario was a bit trickier than the can device since it's a whole different ball game in several respects.
                • RESPECT to Your work.
                  There is no solution without proper execution.
                  You are simply awesome guys.
                  Most promising thread I ever encountered (and I saw a lot belive me). Even if all turns to one more desperate attempt it is only thread on OU worth reading. Attitude is what changes people.
                  • Originally posted by RAMSET View Post
                    WELL WELL WELL
                    Only kiddin
                    We shall see ??
                    Chet
                    Chet, I agree. You need to step up the single phase 110 to 220 with 2:1 transformer. Here is a lot of (3) 1 kva control transformers. You could hook them up in PARALLEL for more current if you want.
                    Lot of 3 Acme Transformer TA-1-81217 Industrial Control Transformers 1000 VA | eBay
                    • lord of the rings
                      S
                      I have new respect [additional] for your patience with these rings!!
                      It will most definitely become a bit of an art form ,this 304 is fairly high PSI
                      and fights like a cat on a leash .
                      I'm really struggling to get 5mm [afraid its gonna snap]
                      Chet
                      PS
                      Ares123 thanks for the flowers ......[lots of good men here .... and one woman
                      BE that change !!
                      • taking a brake for a few from the ring stretching !!
                        Tektron
                        Good to see you Bud
                        I am afraid something will get lost in the sauce with a transformer??
                        The fellow who is sharing the ikea device has emphasized 220 for max benefit ??
                        We shall see ,I am on schedule to get this running this evening !!
                        @S
                        I am breaking my own rule for the chassis
                        since I am building away from home [and my shop] with only limited resources and tools,i am going to see what happens with wood
                        Chet
                        BE that change !!
                        • S, I need help??
                          I know I know .........its wood ?? gonna swell, warp and so on But its OSB mostly glue?? [I broke rule number 27..... No Wood]
                          Which end goes up??
                          I remember you said vertical!!
                          And how for from the end should the drive ring go??
                          Chet
                          BE that change !!
                          • Wood
                            Hi Chet,
                            It looks good. You have to use what you have and sometimes it's only wood so you use it even though it's not optimal choice. Mr. IKEA says it needs to point down, (i.e.: the bottom of the flask is supposed to be pointed down).
                            I've got my experimental assembly totally completed except for the ring which I still need to make. I've got the strip cut out but that's it. I've also figured out the length I need but I need to radius it and make my bends and then attach it to my ring holder. I feel really good about my setup. Anybody with hand tools can make what I made with the IKEA flask. You'll be seeing a pic of it soon.
                            Best Regards,
                            Slovenia
                            Which end goes up??
                            Chet
                            • I see a fixture that we can make for ring centering and adjusting [like on a telescope].
                              So Upside down HUH ?? Okey Dokey!!
                              Chet
                              BE that change !!
                              • control is done
                                rig is ready
                                BE that change !!
