So, using resonance (at a percise frequency) you can make water and air clean (no bacteria and germs). Is that what this is doing? Can anyone replicate this using the patent? I would be interested in this inventions uses. Especially used on the human body (which is mostly water).
""I must be noted that neither Don nor we are still using frequencies in the 20,000 Hz range. Our Zappers oscillate at about 15 Hz and we have found this to more effective in that the lower frequencies allow the current to penetrate deeper into the body.""
Sadly, this comes off a bit corny
(Com'on people, I'm trying to be polite).
For this to work, it would seem (logically),
an entire jump suit with these embedded
into all surface area would be needed
to effect realistic change event, right ?
At the very least, a bodysuit covering non-limb areas.
