Earth resonance, Electrical resonance, acoustic resonance combined.
  • Earth resonance, Electrical resonance, acoustic resonance combined.
    Ill keep this short sweet and succinct as I have little time with internet access in the wilderness these days. Usually I try to illustrate as well as possible a concept in several ways to really convey the information from several angles, but no time today!
    How does one go about creating high Q resonant devices which operate on levels close to the Schumann resonance frequencies? The benefits can be manifold if such a device could be created both in the health and alternative energy field, but many problems plague the inventor.
    The recipe for high Q is low ohmic resistance, high inductance, low capacitance.
    The recipe for low frequency resonant circuits is high inductance + high capacitance.
    Therefore in order to secure a low frequency resonator with high quality factor, one needs to have a VERY high inductance, reasonable capacitance, and very low ohmic resistance. This equates to a REALLY REALLY big coil, many turns, with lots of copper for low resistance, very difficult and expensive to create.
    Here is the solution.
    Obtain a large ceramic magnet. Give it a ring (tap it with a sharp mechanical impulse and find its resonant frequency in terms of sound). note this resonant peak.
    Now excite the magnet at its "acoustic resonant point" and mechanically vibrate it. This vibration in turn creates a changing magnetic field within the space surrounding the magnet at the frequency of the acoustic resonant point. This changing field will impinge back upon the exciting inductor, and it will reach a state of high impedance, little power draw, and large resonant magnetic field (in turn inducing electric fields).
    This state acts much like a parallel tank (LC) circuit in that it has a very high impedance point. You now have a resonator in the audible frequency range which uses very little copper windings, and has low resistance internally (ohmic resistance of the winding).
    Now you may use TWO of these devices to create Beat frequencies (if you need an explanation "google" it.) The sum and difference of the two frequencies creates your needed Schumann resonance points.
    You have now merged sound, with electrical. You have used the large B field of the magnet, and its mechanical properties to create a very efficient tank circuit for low frequency experimentation. You really have no idea how important this technique is.
    Please consider these techniques when working with the papers of Frank Znidarsic.
    Thank you for your time.
    Andrew Manrique.
    the same action occurrs in transformers with loose windings when they hum.
    this could be used with inductive rings as well placed at either side of the coil.
    Martin
      I remember what someone said : tap it at higher level because there is many harmonics in close distance and you can be almost sure to find one resonating with your circuit....Interesting....
        i think that adding the sound is very interesting i have stood i a very intense sound field and it was an eye opening ecperience.
        i have also seen pipe in a vice vibrate wildly just from being filed on and thought that this would make a good power generator just by adding a magnet to the end now adding charge plates may be a bit much tuning it all would be areal problem for sure but i see what you are getting at.
        martin
          sound and electricity is the same , only medium changes
            i think before i want to argue this that you should define how you are going to use the term medium?
            Martin
              self oscillating magnet makes no sense to me.
              The only YouTube video that I could find that may be close to what you're talking about is...
              Self Assisted Oscillation in a Shorted Coil
              Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation - YouTube
              Are we talking about the individual magnet domain (grains)?
              Because otherwise I don't see how a magnets shape on the macro-scale, can affect its natural oscillation point
                The perfect storm.....
                I have always looked forward to any contributions that
                this gentlemen has shared with great interest ....
                Something rings Oh so true here!!
                Thank you Andrew It is a pleasure to read your posts!!
                From the trenches..............
                Chet
                BE that change !!
                  Martin
                  This is similar but not the same. With what I am describing, a magnet (biased space / dipole) is ringing acoustically. In a transformer, the magnetic field is from the action of the windings not a magnet.
                    I am talking about the acoustic resonance point of the magnet as a physical entity with disregard to its field. If you were to hang it from a string, and ping it with a hammer, you would hear a ping sound. it would be a slew of harmonics related to the shape, density, material etc of the magnet. These are the acoustic resonance modes of the magnet as a piece of ceramic.
                    using cymatics, you can get a visual interpretation of the resonance of physical objects, this effect works on 3d space as well as 2d plates shown here.
                    Cymatics: Sacred Geometry Formed by Sound - YouTube
                    imagine the plate in this video is a magnetic dipole.
                      Chet
                      Thanks!
                      This allows a person to create high q low frequency oscillators which interact with biological conditions. Think about the frequencies at which alpha, delta, theta etc states of mind are. how could we induce certain states of mind. Many possibilities.
