Tesla / Imhotep Radiant Energy Circuit
  • #61
    Originally posted by LetsReplicate View Post
    Yes, thank you. The frequencies are going to be VERY helpful in getting this working, one of my first bottles was not far off that. I'll order the remaining parts today and hopefully have this working by the end of the week.
    The scams are that they never show the complete circuit. For example the cell phone charger (Tesla Secret Generator) misses any mention of the ground or a proper antenna preventing it from being useful.
    I was running the circuit as an RF receiving charge pump by using a bifilar sensing pancake coil to cause suction on Earth. The inside of the first coil went to the antenna, outside to the circuit. The earth ground connected from outside to inside on the second coil which is about the same as what we're doing here minus the radiation. I'm wondering if the back-end of your circuit will work as well on that ground pump: I can't see any reason it wouldn't.
    Those are nice pictures, did you use a CAD program? I'm using DraftSight these days because AutoCAD is so expensive.
    SmartDraw was giving me problems so I used MS Paint to generate the entire instructional :-) the ion pump serves a second purpose... Murray put his antenna 30' above the ground and then was 50' from there... That's 80' .. The initial 30' was just to cause a bias antenna side (which is what the ion tube achieves without the 30' ground side... Later Murray also included an ion tube)... Technically the circuit can work with a single diode antenna side... As long as the frequency of the antenna is correct... But under rectification... We'd only receive a halfwave in that case, thus the use of a full bridge in our circuit :-) (plus straight antennas of MHz range would be quite long)
    You'll notice when you hit a right or really close frequency due to the fact if you use low voltage (under 1KV+) components.. You'll see an arc and suddenly the circuit will stop working (you blew it) :-)..although bad.. Is good because you almost have it!
    Have noticed glass rupturing off the germaniums a few times... And the circuit still functions.. (diode was still in contact minus the casing)
    Groundside capacitors have ruptured a few times.. (have resorted to using higher capacity voltage ratings (Low loss).
    Trying to make a replica with all homemade components :-) so far so good.. Tuning homemade capacitors is a pain!
    • #62
      Full Day
      Full day and no responses.. I pray you're constructing and havn't electrocuted yourselves :-/
      • #63
        I'm working on it still. It's been a long time since I've designed a whip antenna and in none of those was it ever the plan to maximize the number of turns on the choke (normally it's the opposite). I've even pulled out my old college telecommunications textbooks on the subject but they are not even nice enough to give a formula for coil self-resonance... Which means I'm still going to have to guess on spacing for the parasitic capacitance until I find a value that works on my diameter of tube. I'm close I think.
        • #64
          I think its amazing and should tie in very well with the lighting circuit I'm working on. I'm guessing it can be regulated quite easily down to 12v?
          • #65
            Coil Tuning
            Perhaps this may help?
            Inductor Designer / Calculator
            When the americium is excited it will help "funnel" energy through the choke with the Leyden setup.. (I used fine wire)... If u have magnetometer you'll notice the field is like that of an upside down cone... Coming to a point at the bottom of the ion tube. And the choke unlike a regular choke doesn't use a ferrite ring or core (would ruin the effect).. All extra "static" capacitance is regulated by the surrounding "shield" (plastic or glass). If you use a straight antenna it's 147.3 feet of coaxial for 5.4 MHz... A combination of coil and whip will work as long as the inductance is equivalent :-) for the antenna.
            • #66
              You are a Genius!
              For mcombatti
              Im new to forums and hope I'm posting in the right place. I've tried all sorts of devices from this website and they all fail. Yesterday I finished constructing your radiant circuit and you are master of the electron! I believe my antenna is tuned but I am only getting 22KV at 1.4amps. Either way it's impressive! How do I get a full 50-100 KV like the schematic says? How do you shut the circuit off or prevent the outputs from arcing?
              Thank you for your hard work!
              • #67
                Circuit
                Originally posted by Seth0103 View Post
                For mcombatti
                Your frequency may be just over or under the 'peak' frequency. If you disconnect the antenna your circuit will dwindle to a halt :-).... What is the rating for your transformer? Perhaps you've lowered the voltage while increasing the current?... (which would make the voltage appear lower) technically the circuit isn't meant to "shut off"... It's a solid state power generator :-) can you post some pics or supply info for your construction.. For others? Arcing can be controlled by adding a load to the output terminals :-) or separate the leads beyond the breakdown point (sparking occurs).
                You're welcome and continue building. As more people construct the circuit, I urge them to build them for others (for the cost of parts alone.. Non profit).. After enough hold the technology in their hands... It will become undeniable. I hold all intellectual rights to the circuit and would rather it be in peoples hands than locked away somewhere for a few bucks in my pocket :-)
                • #68
                  Wow! Great work guys. Did I get it correct that Seth0103 is getting 22000 volts at 1.4 Amps ? !!! Are we really talking over 30000 Watts ? Or did he mean milliamps? I'm not seeing a lot of others in on this topic and wonder how many are aware of the successes here. There are a lot of hot topics right now with several other devices drawing a lot of attention due to some success. But I really like the essence of this idea and I think others will too once they have awareness of it. Note to self: get off butt and start building...
                  • #69
                    Antenna design
                    The closest way I can show how the ion tube increases power output is with the following:
                    Maurice Hately, Fathi Kabbary, X-Field Antenna,US Patent 5,155,495
                    The method is used in thesta-distatica with the horseshoe magnets, antenna keys, and large Leyden-style "capacitor shields." My version is all 3 in a single unit. Most influence machines generate high FREQUENCY and high VOLTAGE... under steady semi-slow rotation (50-60 RPM).. (no need for tall antenna here :-)...and proximity to energy source removes need for 'tuned' antenna :-))...
                    By the way if you add HF or HV to the ground wire and fill the ion tube with quartz sand or resin (resin has to harden under HV or HF) and cap the tube without disturbing the "aligned" quartz.. Americium is not needed. (alternative for solar panel question.. And used in TD)
                    • #70
                      Location of thread
                      Wow! Great work guys. Did I get it correct that Seth0103 is getting 22000 volts at 1.4 Amps ? !!! Are we really talking over 30000 Watts ? I'm not seeing a lot of others in on this topic and wonder how many are aware of the successes here. There are a lot of hot topics right now with several other devices drawing a lot of attention due to some success. But I really like the essence of this idea and I think others will too once they have awareness of it. Note to self: get off butt and start building...
                      I was wondering how people find this thread without a search.. It's really burried in the forums... As long as some know of it.. It's better than none :-) word travels quick with each new success though :-)
                      • #71
                        No, that doesn't help because it does not predict parasitic capacitance (which is what gives a coil it's resonant frequency). The only way to determine parasitic capacitance is with an antenna analyzer or by measuring phase angle at the required frequency and calculating reactance from it.
                        The bottle coil is the loading coil for a 1/4 wave multiple (45.5 feet @ 5.4 Mhz) whip antenna according to your design, otherwise there would be no way to tune it. Coax and an additional antenna should be unnecessary... In fact, unless you've balanced the reactance for the 50ohm or 75ohm coax: it will only cause you extra loses from power reflections.
                        • #72
                          Crystal radio
                          I see what you meant now.. The antenna side is just like that of a crystal radio's coil and antenna. I hadnt factored this into the equation. perhaps that's why there's the extreme variance from 50-100 kV arises using antenna setup.. I will do some math and see what I can find and will recompile a new diagram setup with full dimensions, turns, guage, and such of the entire circuit. :-)
                          • #73
                            Coil
                            I use coil antenna... A straight antenna is possible..Sorry if I confused you.. Generally I speak in phrases (counter productive I guess unless were thinking the same).. But for experimentation.. People can use coil, straight, square...dipole.. Any sort of antenna (correctly attached to circuit of course). The 147' coaxial was an example for a vertical (80 lbs tension) at 5.4 Mhz :-) Like I said, an antenna and single diode can construct the entire setup.. The circuit just increases gain and transforms the sudo AC to DC :-)
                            • #74
                              Thank you for your quick response. I now have to rebuild the main circuit. I was playing around with the amazing light show producing arcs between the output leads and in a flash of light it all stopped working and one of my caps exploded. The underside of the circuit is burned. This next time around I will heed your warning and add a load or turn it off while not in use. What can I power with this?
                              • #75
                                What to power?
                                With 20kV at 1+ amps (might need little voltage, current regulation..:-)) I'm pretty sure you can power almost anything. At a constant 20kV you could power your home... Power yours and your neighbors on both sides or neighborhood (depending on size)... Charge a battery bank... Make a "perpetual" tesla coil (yard ornament??)... You can power just about whatever your heart desires.. As long as the devices voltage range doesn't exceed a constant 20 kV. Play with your antenna a bit to see if you can't get the 50-100 kV range :-) you could even have an electrician wire it to the grid and get paid for your contribution of energy? Can you still upload pictures of your circuit burnt or working it might help others :-)
