Originally posted by ewizard
Tesla / Imhotep Radiant Energy Circuit
Just missed you..
Originally posted by Seth0103 View Post22156 Volts at 1.4 Amps after my transformer has processed the raw electricity.
Circuit
Hi Seth,
I am a bit confused and or curious as to which circuit you are using. Is it the "circuit#5" in post #19--page 1 ?? or the one in post #56 -using the globe too???
That voltage and amperage you got are fantastic.
I built the circuit #5 and only got about 6 volts when I hooked it up to a Yagi Ham radio antenna
Can you please post your circuit and or pictures of same so we can get at replicating it ASAP.
Thanking you in advance --Paul
Hello
Originally posted by soundiceuk View PostI see the future as an open source community.
Many thanks for sharing your work.
You follow in Tesla's footsteps and share his vision.
Have you got any more mind blowing circuits or coils that are of great interest?
Did you talk to your Grandad much about Nikola Tesla?
Plasma globe
Originally posted by EMCSQ View PostHello
I would be interested in a circuit , which captures the 'radiation' of a plasma globe.
Tuned circuit
Originally posted by bbem View Post@mcombatti
What a nifty finding!
Am very impressed
I am living in 'the Netherlands' and as the name already suggests it's below or just above sea level.
What is your advise how to proceed?
Replica
I'm assuming you meant peak-to peak AC, and I'm going to assume it's a clean sin wave for simplicity, in which case the RMS voltage of 7833V. I also have to assume that current is peak-to-peak AC current of the same sin wave which translates to an RMS current of 0.49A. That means the output power is 3877W... Again, you'd need a beast of a transformer: but at least there are transformers for that power level that a person can access. None of them have an non-ferric cores however, so I have no idea how you manged to drive them with this circuit, they are also not constructed for high voltage. So unless you can show pictures that you're running a pole pig or something equally as monstrous: you must have measured incorrectly.
Wow
Originally posted by mcombatti View PostI believe he used my radiant circuit found on #56.. as that one is the only one I've posted which utilizes a transformer. :-) The prototype I've been using is aprox 30kV at 2 amps (fluctuates down to ~1.7amps). Forgot to take into account the capacitance of the coil..so am recalculating and modifying everything for a new instructional.
Wow, thank you , that is awesome.
Can you elaborate on the 2 caps after the spark gap and some more info on that step down transformer. Also can we get some values of the caps and resistors of that "electron cascade amplifier" which to me, might be the way to go.
Sorry to bug you for all that info but I can't tell you enough of how much I appreciate all that you have contributed so far on this device. This is exactly
the route I always wanted to go in my free energy research from day one.
Keep up the good work .--Paul
Transformer
Originally posted by LetsReplicate View PostI have to call BS on that until I see how you measured it. Unless you're cooling that transformer with liquid nitrogen there is NO WAY it hasn't melted... In fact, I don't even think liquid nitrogen would do it at that power level: EVERY piece of wire in the circuit would get white-hot and melt.
You can buy a transformer here below..no oil...no resin...stays cool..no fan..no wires getting hot...no pole pig :-) (similar but more compact and more efficient..)
20kV or 24kV high voltage current transformer (CT) - Detailed info for 20kV or 24kV high voltage current transformer (CT),current transformer,20kV or 24kV high voltage current transformer (CT),1000 on Alibaba.com
it's about the size of a quart milk container... has a torroid configuration..which decreases the potential slightly..but it's negligible at high power levels :-)Last edited by mcombatti; 11-30-2011, 06:27 PM.
Caps n parts
@mcombatti
Thank you for your valuable insights and willingness to help the common man.
I am wondering if I can take advantage of a large aluminum roof on my studio as a collector? It is approx 16 feet wide by 30 feet long. It sits within 40 feet of the power lines that run through my neighborhood to distribute power. The power line to my house runs right over it, only a few feet above. Would this ionize the roof as a collector? I am at 1300 ft altitude. If you were me, what approach would you try first. I am trying to keep the circuitry simple as possible as it is now difficult for me to solder, getting old.
Thanks again,
tishatang
