The thorium battery is very interesting, using radioactive isotopes to ionize the fields is a very interesting idea or maybe just a ionizer circuit from a air purifier would work.
I watched a vid where a guy from Europe placed a ring like this between the electrodes of a high voltage transformer to separate the charges, it worked.
I think it could be used on the Don Smith device to separate the charges between the secondary's.
I like this one, this is what Im building
although very slowly Im sorry to say
minus the radioactive material, I really dont think we need it, when the right combination is found.
I think sometimes we need to step back and reconsider what we are trying to do.
We are trying to draw in and capture the aether that permeates all space.
What is that aether drawn to............a magnetic field
So what would create a sink..........a raw magnetic field
When I say raw I mean a magnetic field that is free of ions, electrons or whatever we want to call it.
Eddy currents heat up transformers, eddy currents are electric particles that are already in an orbit around the magnetic field line, the electric field that surrounds the coil or magnet are electric particles that are wanting to connect with the magnetic field, so if we build a raw magnetic field we will have created a sink.
How do we build a raw magnetic field..........put the core in a Faraday cage.
Thats what they are trying to do with lamination's in a transformer the dielectric on the lamination's are restrictive to the electric particles that are orbiting the magnetic field line, allowing the magnetic field line to pass but restricting the electric particle. Have you ever run current through iron wire? It heats up very fast, thats because the iron has a high resistance to the electric field but is very conductive to the magnetic field.
Separate the electric field from the magnetic field.
We'v all read the reports of a ufo pulling energy out of batteries, what would cause this ,a very high energy sink.
They are funneling the magnetic and electric fields in such a way that they are drawing energy from all around their craft. So the shape of their craft should give us a clue, they are doing it naturally, with the fields.
I think they are creating a raw magnetic field then funneling the electric particles thereby boosting the raw magnetic field even more.
