Bumped up because of spam.
The electric field of a magnet
Dave , i don't know if you have seen it but i think it is worth checking it out
A I R Magnetic phenomena's 2012 - YouTube
“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by Dave45Coming to a theater near you soon
Im having to much fun.... any trailers before hand
looking forward to see the results of your tests“Signs and symbols rule the world, not words nor laws.” -Confucius.
Ezekiels Wheel is the first recorded "Machine" in History. Two intersecting toroid fields has been my prime study. Its a difficult configuration to deal with and not much experimentation is done with it.
Just one idea I have on it is a toroidal Pmh with the poles being separated somehow at the intersects of the "wheel". One pole on each intersect. The magnetic current flow stays inside the materiel though. Question is can you access the magnetic current at the intersects,think cavity where the 2 toroids join,and use it to generate an electrical field in the other toroid.
Then there is pulsing an electric current through one toroid creating a magnetic field in the other.
Dave ....check this out :
a wheel within a wheel
The Vega Science Trust - Electrical Generator Demonstration
might interest you .. a simple test yet much to be learned
he has a nice youtube channel with all kinds of test ... the one i was looking for was graphene
VegaScienceTrust - YouTubeLast edited by MonsieurM; 04-26-2012, 08:54 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Looks like one could move through the inside of the other eh)
Think of it this way, The South Pole Wheel has to fit within the North Pole Wheela Standing Wave
North Pole and South Pole ( look closely at the circles )
an Alchemical Analogy for you would be:
When the Sun meets the Moon (the sun is larger and More immaterial than the moon )
the same is shown here:
Last edited by MonsieurM; 04-27-2012, 12:25 AM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
This is very interesting approach DaveI've been trying similar concept couple years ago with conical coils. I think, my mistake was in employing another coil in between to collect, while it should be different component - just as you're doing.
Great work
Vtech'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
We have to search for clues
in this vid the aluminum ring gets hot, that tells me current is running in the ring,
If a ring were placed on the other side of the coil current would run through it too, but in the opposite direction.
Lenz's Law & Eddy Currents - YouTube
the magnetic field is in the iron core this reaction is caused by the electric field.
Walter Russel saw the answerHalf of the Answer is knowing the right Question
Walter Russel saw the answer.... 3 large circles to form one unit :
Silver circle , Blotting Circle and Zinc Circle
find silver and zinc on the periodic table below
Last edited by MonsieurM; 04-28-2012, 05:13 PM.“Signs and symbols rule the world, not words nor laws.” -Confucius.
Originally posted by blackchisel97 View PostThis is very interesting approach DaveI've been trying similar concept couple years ago with conical coils. I think, my mistake was in employing another coil in between to collect, while it should be different component - just as you're doing.
Great work
Vtech
I plan to also use permanent magnets in my core, I hope to make the system versatile so I can change it up easily, Im a very slow builder but I'll get there.
daveHalf of the Answer is knowing the right Question
