The electric field of a magnet
  • Have not tried it
    • A variant of the ZVS should improve efficiency, may just need single cap between the coils and no pos lead at all.
      Adjusting the 470 ohm resister may be needed.
      If it doesnt burn the core up, it could get explosive
      • Using heavy wire with just a few turns means less resistance, allows the coils to run at a higher frequency, allows the magnetic field to build a collapse quickly.
        About the shorted secondary winding should it be of a higher impedance, is there a harmonic relationship here.
        Should the shorted secondary be wound cw and ccw as well.
        Can this be made into a dual rail use one rail to loop and draw from the other rail.
        • We are not going to understand or achieve overunity until we start to understand and use both polarity's.
          Ole Ben Franklyn was half right, we have two polarity's running in a circuit, and we have to collect both.
          • NO BEMF
            • Half of the Answer is knowing the right Question
              • Or we can do it like Hendershot did it.
                • Son of MEG
                  Dunno if everyones seen this yet.
                  free energy generator - partlist included - 100% free - YouTube
                  Kinda cool.
                  • The guy really seems sincere, it really wouldnt take long to find out.
                    • Reminds me of: Roy J. Meyers Absorber
                      See: Roy J. Meyers: Absorber (Atmospheric Electrical Generator)
                      Look for figure 8 - the one with the horse shoe magnets where wires are wrapped around it and then taped in the middle.
                      Regular service Signature:
                      • Yes and the Hendershot device, the magnet is also backed with mumetal this could be having an effect as well.
                        I may play with this a bit, I wonder does he mention the diameter of the core anywhere.
                        Hmm seems he took the backing off in some of his vids
                        • Hmm this is interesting, I wonder if his coil is completing the path
                          • I wonder if the counter wound center tap is pulling from the other side of the field.
                            • Could we wrap a coil around the centertap and pulse it.
                              If this really works it will teach us.
                              • Could a counter wound coil be mounted on the other side of the magnet with a center tap in the opposite direction.
