Hey Dave
Thanks for the link - I usually check this thread every day, but guess I missed it today. The swirling images remind me of standing waves or a kind of slow moving pattern produced by helicopter rotors or rotating hubcaps on a fast moving automobile wheel. To me, your red and green wire illustration seems to approximate this.
My mind goes to David Lambright's experiments on YT, and the visible light anomalies that seem in some way to be part of the same spectrum of phenomena you're describing. If this is the case, then the whole notion of electro-gravitic-magnetism as one interrelated matrix of forces seems that much more plausible.
I think John Janikowski and Tim Harwood's Power on Demand (POD) device may have something in common with what you're driving at. Just can't find it online right now - maybe someone else can.
Until next time,
Bob
Hey MM
I was thinking about Ed, I think he was using the magnetic gen to pulse his coils, I dont think he had any pulsing electronics so he made his own.
If I remember correctly there were 24 north south poles on his gen that makes 48 poles I bet he could get some good frequency's even turning by hand.
His setup would induce ac into his coils, he was a very patient and observant man I wonder what he really found.
I dont think my coils are wound exactly right, the ends dont line up right, the wiring didnt work like I wanted as far as number to number, but this was just a proto I will be building more Im going to work with this one awhile.
I have built many but none intrigued me like this one, I havent done much testing yet so we'll see, I'll ponder it awhile.
Stumbled upon this thread last night. Loved the coil in ice!!
I've been trying to figure out How to Make EMF Fields Visible in 3-D. YouTube shows how suspended steel wool fragments in dish liquid align when a magnet approaches the bottle. Obviously, (mineral) oil would preserve the fine fragments and if placed in a durable clear plastic bag, it could be safely wrapped around a wire, coil, magnet, or motor without a mess to clean up!
Is it true what Hans Christian Orsted discovered in 1820 that the force field outside a wire won't affect the current inside the wire? So for example, if every homeowner and business located near HV transmission lines ran field harvesting devices along those lines, they could all go off grid without affecting transmission?
Does the field around a wire follow a spiral path? Walter Russell said all direction is curved, all motion is spiral. Viktor Schauberger discovered water flows more efficiently through spiral pipes and that at river bends, there are electrical and temperature differences between both sides. Could electrically conducive nano-fibres (printed?) in spiral formation enhance a materials conductivity? There've already been nano motors.
Forgive the digression.
If you want to see 3d fields look at the plasma experiments on the tube involving magnets.
I agree everything moves in a spiral even our precession through the galaxy and the galaxy's precession through the universe.
I was thinking this morning about the winding of the scroll, when I made the coils all the ends were the same length I connected all cw windings from the outside of the coil to all the beginning windings of the ccw coil then when I went back with the windings from the outside of the ccw coil to the beginning of the cw coil they had to be offset by three to make the right connections to have continuity through the coils, which would only make sense but we get this
There are twelve connections at the center.
I think Im going to wind one with three wires then we would have six in the center.
Something else I did with this build the six windings are all the same frequency because they are side by side on the core, if layered each winding would have a lower frequency from the core out, if I had layered the windings I would have had a stronger magnetic field and six frequency's running through the system.
If a magnetic field is compressed space then starting from the outside in we should be able to compress the same space six times, a normal wound coil does not do this because by winding back and forth you dont bring energy out of the system, but this type of winding brings energy out then folds it back into the system.
The build I made does not get the compression that a layered system would get.
reminds me a bit of the Asymmetric Motor winding done by UFOpolitics
also from an old post ..... I think it was evolvinggap who posted it :
Cool MM we are definitely on to something I havent quit got a grip on it yet but I will.
Something else to consider this is an asymmetrical system and I am getting a strong magnetic field through the core using dc this should tell you something about the magnetic field.
