this conveys better the information
posted here: http://www.energeticforum.com/psychi...ntenna-10.html
The key in this regard [pardon the pun] is that Music is basically about ratios, frequencies (geometrical sine waves), and timing (a very mathematical kind of thingamagig). There is also a strong geometrical connection, in that, if one takes the unique 3-4-5 right triangle (with sides of 3, 4, and 5 equal units -- the only triangular shape utilizing a combination of single digit whole numbers which result in one angle of the triangle equaling 90 degrees -- however, larger numbers such as 5, 12, and 13 also work), and strings a continuous fine wire to each of the three points of the triangle, it is then possible to tune one of the sides to a particular note, and have the other two sides be in a tuned harmony. The three sides of the triangle form a series of tones that are equivalent to the first three strings of a tuned guitar. (One might also note that geometrically, one only has to tune one side of the triangle, while the guitar requires all three strings to be individually tuned!)
