The electric field of a magnet
  • I would thinkyou are right about you need bait.
    my question would be if the local radio station is putting out say 1 mega watt of power any coil you would make of small wire would just burn up with that type of power input be it static or magnetic.
    then you would need to time the bait frequency to the actual timing phase of the generated wave.
    and then there is the question of grounding good or bad?
    i would use a magnetic tickler as because you already pointed out the voltage should already be there and if energy has any inirtia it would need to be overcome to get it going.
    Martin
    • lets say dave you make a 555 timer amd put the output to a resonant coil cap series and let it just pulse the coil and then let it ring down and then put it near a radio and adjust it to the frequency of the ring down best if it is am station tuned something local.
      that station will come in loud as will other stations from around the world as the ring is not set to keep time with the local station it is a form of hetrodyne.
      if this could be kept tuned to the local station as with the radio ferrite feedback the station comes in more powerful due to the timed feedback.
      but in my example it is not kept timed so it looks for other timed sequences to pickup on.
      there are small things like this on the don smith circuits that i see but seems most people don't wonder about it.
      there is such a thing as locked charge it is internally bonded within the matter so to get it moving you need to overcome the surface tension. as you thought above i was just pointing it out that i think you are right even to the kapanadze and stiffler circuits the voltage moves easily but the charge has limits and i agree with your statement.
      Martin
      • Originally posted by Dave45
        Lets look at what happens when the two coils are perpendicular to each other
        I found the following which reminded me of your drawing: FREE ENERGY # 27 ELECTRICITY GENERATOR USING SINGLE MAGNETIC FLUX PATH (MOTIONLESS) - YouTube
        the reason it also caught my attention is that the next picture also looks similar from a Russian engineer-electrician Alexander Kushelevwe previously talked about here: http://www.energeticforum.com/153539-post454.html
        [IMG][/IMG]
        Btw: link to patent mentioned in the vid:
        ELECTRICITY GENERATING APPARATUS ... - Google Patents
        russian link
        Íàíî, íàíîìèð, ïèêîòåõíîëîãèÿ, ìèêðîâîëíîâàÿ ýíåðãåòèêà / Ôîðìû, ìåõàíèçìû, ýíåðãèÿ Íàíîìèðà
        • Chug along Dave, as usual be careful...
          Have you checked out the 7.8 hz generator i posted....would really love to hear what you think
          • @ MonsieurM
            Hi M M, In your post #192 and also #206, you show a still from a video with a yellow coil, ring magnet?, red wire, and light. Can you provide a link to this video, or explain what is going on there. sorry if this was posted before and I missed it. I have quite a few ring magnets and hope to be experimenting with them soon so I find all things related quite interesting.
            Thanks, Gene
            • IMGP5275 - YouTube
              no description posted unfortunately
              if you have ring magnets...check this thread out also:
              http://www.energeticforum.com/renewa...tml#post169702
              • MonsieurM, Thanks for the RE.
                Gene
                • looking good dave
                  Martin
                  • Dave
                    i like what you did but i am having some feeling that maybe instead of ribbon it should be many strands connected between two split ring ends for the two halfs it would be hard to make like this but if there is a field rotation it would not show up in the ribbon.
                    as for cold you should see it here -7F last night not real cold yet but cold enough you wish it was 30F.
                    also does anyone have any thoughts about paralelling MOSFETs. is it ok? don't do it? don't mix types? just not the best idea?
                    Martin
                    • it looks like a copper coating on the lower plate so would assume if reflects the field back. it could be a form of field resonation.
                      on the imhotep radiant energy thread there was a post about the tesla court case and how tesla said that the voltage was the waisted energy i think this is so for a long time now and it is what fills the space between matter moving without physical influence it also states that the charge is captured much the same as what i found but call locked chargesfor a short post it was good for me to read.
                      guess no one here knows much about mosfets?
                      i will try elsewhere
                      Martin
                      PS our site is almost up.
                      • TROS -- Don Smith II - YouTube
                        this video goes for the magnetic resonance and what we talked about the phase volume between magnetic and e-fields so you may want to watch it
                        Martin
                        • dave
                          i got some new cfl lights and something has happened the last few days since i put the new ones in the other one that were of a different type are all brning out when i take them apart they all are out for the same transistor being blown apart.
                          it goes well with the corporate line of thought and some things i have seen in the past one type has a compensation for var a better bulb but not as bright the other is brighter but no var correction so cost more to run is brighter and causes the other bulbs to burn out.
                          lets see if i add it up right it will cost me more to run makes me buy more bulbs offers me more light and puts the other company out of business due to cost to safeguard there bulbs.
                          yup it all adds up.
                          maybe the better question might be were is the bemf coming from?
                          is it because we redirect the natural magnetic flow so another charge is generate?
                          this would make me think this is why tesla said that the ether was hard you push it and it pushes back.
                          Martin
                            Will a hvt work like a tesla coil secondary's dont effect primary, and collect the same
                            if you look closely Dave...It resembles the following (was posted by Farmhand)
                            • Per me le calamite hanno solo questo:
                              linee di forza dense, più degli avvolgimenti elettrotecnici.
                              Questo è utile per fare esperimenti di elettronica per lo ZPE.
                              N.B. i vortici sulle calamite cubiche
                              sono sempre linee di forza magnetiche permanenti.
                              For me, the magnets have only this:
                              [U]lines of force dense, more in the windings electrotechnical. [ /U]
                              This is useful to make experiments of electronics for the ZPE.
                              N. B. vortices on cubic magnets
                              are always permanent magnetic lines of force.
                              That experiments you have built?
                              • Originally posted by mostromagnetico View Post
                                My apologies mostromagnetico, could you go into more details ..would love to know what you mean by
