Hi all,
I have an idea for an über-efficient high-speed vehicle.
Cutting out overhead surface area all together.
Main features:
- rougly cylindrical craft shape, like an open head rocket
- payload is hidden behind air intake, and adjacent to smaller internal engine)
- air intake surface makes up ~100% of the frontal surface area
- exhaust pipe surface makes up ~100% of the front surface area, good diffuser for effiency, air naturally expanding back to ambient conditions
- Intake air is sped up/compressed to fit through much narrower channel, say 10-30% of vehicle's frontal surface. Keeping the outer shape cylindrical (cross section shaped for optimal intake+compression), this frees up significant space.
- Prop or jet system. Anything good at thrusting air.
- Prop version could well run be run electric. Grid, battery, or solar. Train version could be gravity assisted for acceleration, with the engine for cruising (resisting decelleration) only.
- Really, it's an open head rocket. Think about it.
Vehicles can be made to work as:
- (Maglev, ground effect or semi-traditional track) trains
- personal vehicles, ground effect.
- all-inclusive aircraft only needing additional aerodynamics for lift, not payload
- superspeed underground train. No issue to get it through a tight fitting tunnel, as it digs more than forces. Alternative to gravity assisted (deep track, high station, vacume tube systems?
- underwater crafts? Obviously, thrusting water which doesn't compress well, water will travel at high multitude of craft speed through the narrower inner channel and engine.
My questions to you:
Is there easy-to-access data or formula on the efficiency losses of compressing/speeding up air through a smaller duct, and then allowing it to expand back? By lack of overhead surface area, hardly any nett thrust would be required for cruising. Compression should cost little more than the expansion offers back? Perfectly designed inlet and exhaust shapes should get air drag at bullet train speeds to an absolute fraction of what trains use now.
My threads usually don't get any replies. At least just tell me something rude?
Main features:
