willy is laying out the tpu in full with unargueable proof then we shall advance it !
so this is next the tpu driven by a freq genny and a power amp ...
we term this power assisted tpu ...
thease devices are ether spinners ... agin a simple device aircore coil rotation is caused depending... the simplest way to understand this is to make a coil and drive it all 1 wire is best to start basically in a motor generator set this is your rotating magnets ...
your coil must!! be impeadinced matched or you run the risk of blowing the amp
i have a few amps i can designate to this cause .. some tube and a tube freq genny as well as transistor amp and genny ..
make sure imput does not get to high it will fry the amp .. exp talking ......
so where are we hideing the hot tesla writers ? cupple books under her belt ... gonna kick my feet up soon ya know
i have noticed hot damm chicks write books about tesla ... damm hook me up
First I thought it was a Bug then I changed it to a turtle
No matter its quite cool .............
Speakin Of Cool
Willy's Freakin Cool!!!!!!!!!!!
He's like a Mad Humaalien Scientist
some things Iv noticed about coils and induction
the first initial pulse seems to induce more voltage than subsequent pulses, this may be related to vop, it also adds resistance to the coil and not just in pulse motors but any kind of induction.
The electric field, it see's only the external wind and runs counter to it, all other winds under the external wind are shielded, this coil may work because it is showing counter winds generating two electric fields.
What is ferrite, insulated magnetic particles, they are allowing the magnetic field to pass but interrupting the electric vortex that is orbiting the magnetic field lines, what is this doing, its creating a charge buildup at both ends of the coil, how is this effecting the electric field that orbits the coil.
can we strip away the particles from the magnetic field in the core with ice and aluminum rods placed strategically in the core, I wish I had more time and resources. I sometimes have more idea's than I can keep up with.
if we had say two aluminum hats one inverted on the other with dielectric sheet between them, with a coil wrapped center core will we get opposite charges on the hats, would we get liftoff houston
what if we poured magnetite and fiberglass resin around an aluminum rod in the core, would the electric particles seperate into the metals
If we could efficiently strip the particles we could have more than we need, maybe several rods or just aluminum wires placed throughout the core.
Lots of possibility's
david
No Time , transfer your lab to your Imagination room
My method is different. I do not rush into actual work. When I get a new idea, I start at once building it up in my imagination, and make improvements and operate the device in my mind. When I have gone so far as to embody everything in my invention, every possible improvement I can think of, and when I see no fault anywhere, I put into concrete form the final product of my brain.
(Nikola Tesla Quote)
“Signs and symbols rule the world, not words nor laws.” -Confucius.
I do the same it just mine dont work like his did
If we could see as he did, oh baby we would rock this world.
but you have so much practice with hv and hf...and you can easily recreate in your imagination all the physical laws you know + the added ones you know ...that is how it works...let your simulator run and you'll see
the 7 laws are always at work.....
hint: he saw matter as a very low vibratory wave if your prefer the bass player in the band upon which the whole music is built....
i have been busy too i have everyday world to play around in too im still trying to clean up the shop so i can focous .. the nice thing about this style of work is the hows and whys dont change much .. we just can see deeper and clearer and things make more sence from year to year ...
we can build a ufo .. we can build what ever you guys want to build ..
just 1 thing we wont build right away .. NO TELEPORTERS! got it!
W
a lil FE304 AND SOME SI02
we could have some reall fun ... you know i did find some really cool crystals in my prospecting...
slightly magnetic ...
dave looks like you have round neos drawen in on the top of the coils ... would help to contain it and force the energy toward the center and banged at the same time .. would make shock waves ..
take 2 magnets and push the north feilds togather .. then freeze the magnets
W
dinner is served ! dave's got it in ice .... hahaha
