i set up the nst table found my variac but i need to wire the damm thing lost its wires some how ... then i placed all 3nst's and found an aa but i guess it is dead found my scope some probes not the ones i need tho .... errrrrr found my volt meters managed to get 1 that still turns on try to mesure the aa dont read it put it on a 12 vdc thing is blowin i guess... so i could not find a good battery or meter
ill have to get some new meters and batteries b4 i can test much
we can always jt the nst meaning 1 wire it the primary and secondary
secondary becomes your resistor set it up as a freely vibrating circuit then intrupt it ...
W
you take 1 wire from the primary and 1 from the secondary hook it togather and you make a fnnn W with it
w's up baby! lol you end up with 3 ends the 2 wire joined connection is ground or pos depends on npn or pnp ...
its like a pumped up camrea flash board on dope!
never mind the freq... it will tune its self ....
this is a prime demo of hemf... low inductance and high in the same wire freely vibrateing and intrupted ... when we intrupt it we harvest ...
this operates 2 diffrent frequencys 2nd is what we harvest .. first is a carrier .... for those that dont know we harvest what is shooting accross my scope in 1 of the videos i posted you can see how bright some of the driveing leds got while intrupting the running freq .. much more was returned than used to induce this energy effect this is easly seen on the driveing led as they dont even get that bright when not powering the coil so there brighter powering my coil and driveing circuit than just running alone ... gain .. i know so ...
how to tune a 2 freq treat
TUNEING A IST 2 FREQ TREAT .WMV - YouTube
this it a driveing flasher and power supply for many of my 2 freq units ..
1$ FLASHER - YouTube
cool effect here
ODD RELAY COIL AIR CORE JT SELF PLUSE WAVE - YouTube
how to grow your output!
IST OUTPUT TRICK - YouTube
can i take your x ray ?
IST NEO ZAP AND RING - YouTube
look how BRIGHT THE LED IS !!!!! LMFAO
2 FREQ RINGING MAGNET TRICK - YouTube
ROLLING IN THE DEEP
ADELE 'Rolling In The Deep' (Studio Footage) - YouTube
W
cool effect here
ROLLING IN THE DEEP
