TUBE DRIVEN TPU'S The construction zone
  • i guess it depends on how you want to build it .. tesla did not use diodes .. i would use them in places as we are useing a nst or a flb .. we will find we will need to block things .. to portect it from damage
    if you fully understand the 3 devices then its play time .. and if you have the time it can be made in a ring ... like a tpu ..
    W
    • Who said Tesla never made the tpu
      http://www.teslascience.net/library/...stribution.pdf
      • I cant say I fully understand all three, here's what I get out of the ozone pat.
        He's induces a high voltage in the secondary through a pulse, but the energy in the secondary goes into a cap so it radiates, the primary is picking up a boost in between pulses from the charged secondary.
        I have a high voltage ozone generator that uses a flyback couldnt I wind another winding on top of the flb secondary and have the same thing,
        I guess not, now that I think about it
        I might be able to if I ran the power supply through the added winding but that might get out of hand quick with that kind of amperage.
        • this may not be exactly to par , but that is how i see the 6 3 9 working in his patent:
          • Quote
            I would state the apparatus which I have devised for this purpose is capable of other and highly important uses of a similar nature
            • ill cruze through the ozone pat later on today ... it is best i sight it from the pat .. then explain ... till it is understood ..
              here is 1 quote of importance ...
              herein after described wich enables me to produce with out difficulty and at verry slight expence ozone in ANY DESIRED QUANTITIES i would state the apprattus wich i have devised for this purpose is capeable OF OTHER AND HIGHLY IMPORTANT USES OF SIMILAR NATURE .....
              we can use the ozone as showen in place of g if we want ...
              i thought for simplisity the nst or flb ...
              W
              AGIN IN THIS PAT .. HE TELLS YOU HE USES THE ACCUMULATED CHARGE OF A CAP ... he also tells you it dont cost any more to make 1 ml of ozone or 1000 gallons
              anyway read it study it .. read all 3 he mentions study them .. i sure did...
              the damm pat # is 568 177 find the origonal drop the bull sh!t i dont want any modified bull ****!
              ORIGINAL im holding the origonal writeings of tesla trust me i have read this pat .. sevral times ..
              • He's kicking the secondary with the primary and the secondary is kicking back adding to the primary, no energy lost only gain.
                • I havent been able to source big toroid cores, I have been thinking of using magnetite and fiberglass resin and making my own.
                  I have some magnetite I got out of NM on an a little mining trip, a little tip on mining if you dont like digging ditches forget mining its hard work, but a lot of fun if you dont mind a little work
                    Dave you should check out this post for some nano magnetite for your core
                    http://www.energeticforum.com/165475-post1225.html very easy and well explained
                    • Willy the nst your using is it the 12 volt nst
                      Neon Power Supply 12 Volt for 4-Tube Car Kits
                      • the core should be quartz and magnette....
                        lol
                        ding ding ... i could find where my material was supplyed from it was in the usa...
                        amorphious nano materials or something like that ...
                        anyhow ...
                        is there something wrong with teslas proven tpu ?
                        W
                        sh!t you dont even have to wind a thing ...
                        served on a silver platter ...
                        well cromium zarcomunim and plaitinum lol
                          nope .. its 120vac ...
                          W
                          pluse it dc @60hz...
                          besides .. unless you do it right with fe304 and sio2 and understand how and why .. you will fail at an atempt .. as the device becomes 1 with the builder ...
                          its so deep and there reasons ..
                          i can build this with my eyes closed ... but it is NOT SAFE FOR PUBLIC BUILDING ! OK GOT IT !
                          if you induce a lightning strike .. and are not prepaired it will kill you dead .. to properly build the cores they must be fused .. to do this lightning is required .. altho there other ways ...
                          when you apply pressure to quartz see anything happin ?
                          lmfao
                          W
                            That would be a good way to go, but the magnetite I have also has other ores mixed in, Im sure there's micro platinum, gold and silver in the magnetite, also quartz, would be cool to see how that effected the fields.
                            • Alright Im ready
                              • we found us a luneatic !
                                lol
                                W
                                it wont be long .... i shall play too !
                                dave is that silver wire .... looks it !
                                what is common between 3 6 9 ..... ?
                                if we understood 369 we would have the keys ...
                                they repete they are repetetive freqs .. 3.333333_ 6.6666666_ 9.9999999_ you can devide them by 3 @120 deg
                                so lets say you have 2 wires 45' long you will have 2 identicle wires turned into 4 coils .. collector is 45' the other is devided by3 and mass is split 369 this is for heterodyining .. wich i have acheived via 1 tube driven bass amp .. and no generater ... i have a video .. and have done this with audio .. magnetics is NO DIFFRENT!
                                if your useing a 2ohm amp you need a 2 ohm coil ... 4ohm you need a 4 ohm coil ... etc..
                                built it years ago ...
                                W
                                H0H 808 AUDIO ! MAG!C MY MOVIE ONLY ONE - YouTube
                                and its times like this cant rock the body with out the bodyrock!!
                                got your c stone ? and your b stone .... lol
                                all i did was tune the amp and flick the switch .... the kick starts it it amps the ripple till it is self tuned to resonance and circulateing ....
                                yawn .. the video does not do this justice as you can hardly hear it .. do it in real time .. and wear your ear plugs ....
