TUBE DRIVEN TPU'S The construction zone
  • Schematic
    Can you post a schematic?
    • now i have many advancements i made all in the same 3 hours i played with this ...
      prior to this i have never played a nst ! i got bit yes you can feel it ..
      there no diodes used in this test ... some of my other tests i used diodes ..
      i added a silver wound youke to this setup .. powered the light through the silver yoke and spark gap ...
      i also took the blub away .. placed a 1 turn secondary on the yoke core
      and saw some damm neat sh!t !!
      its all on video
      W
      i start with the simple lite .. and the understanding of what is actually going on
        to be honest i dont even own a pencel to draw you one ..
        battery connected to primary .. and lite blub on secondary .. that is all there is ...
        nothing more ..
        W
        what happens is exactally as i have explained it !
        i dont understand humans ... why not use this .... why not build a HUGE ONE... give her some amps ... why not ?
        silly humans ...
        i can fetch you a quote from teslas words .. where he says .. this spark is sutiable means to charge almost any value cap ....
        it starts at 1.2 vdc .. but it could run 120vdc ... its a neat toy ...
        it works good at slow speed it is contained .. in the core .. so juce it .. big amps get bigger back ... i could throw a magnet on it and wobble tune it ya want me to ... lmfao
        what it takes to come alive ? ... my kick! then it fills the caps and away she can fly
        • now if you want to get wak....
          go get a nst and a flb .. the primary on my nst is 4 ohm .. the primary on the flb was .... i forget .. but im sure it was more as it was like 1 henry or such ....
          now jt the 2 trannys ... and harvest ... harvest...
          get it ...
          oh yea freely vibrateing too .. no resistor ... 3055 will work .. i suspect ..
          W
          harvest from secondaries .. and self run or recharge from primaries ...
          let a single charge be first considered
          thats wak
          but with the 4 input wires to the 2 transformers.. you make a W OK just like makeing a VV with your hands .. you make a W with the wires ....
          and it goes like this
          P+T
          VV ok simple pluse common trigger .. ok trigger= flb pulse = nst .. primaries ... you could join both transformers as 1 core via a magnet .. so much you could do ....
          now what im introduceing you to is HEMF now ... as we added another componment to the mix of the riddles and the tricks ...
          we have introudced lower self inductance and higher self inductance with the colapse and the power on spike and now if they were out of phase as the mw unit will be ... you got true magic of the grandest scale ...
          W
          tapping 5 feeds from the trigger wire only ... freely vibrateing ...
          WJT TRANSFORMER TRIGGER RECOVERY 5 FEED DEMO - YouTube
          JT TRANSFORMER MAGNETIC TUNEING - YouTube
          dont be shy with playing with it ... if you add caps and diodes ... be wize ... hvdc can kill you
          here you can see my magic maker boards and resistor....
          NPN TUNER BOARD - YouTube
          makes a VERRY EFFICIENT FLASHLIGHT .. REALLY CHEEPLY MADE ....
          HERE LOOK AT THIS JT TRANSFORMER IST WAY.WMV - YouTube
          freely vibrateing magnetic tuned transformer running on a aa with 2 freq output modulaution .. now if i modulated 2 freqs on the input ...
          boy it gets crazy ....
          here is a flb
          JOULE THEIF STAGE #2 : ) THE IST WAY! - YouTube
          • similar to how the device i just built operates..
            Joule Ringer! Light keeps going without battery. - YouTube
            now i dont agree with all that is said .. but he has a dang kool coil ...
            my device is totally ou .. with gain .. it is simpliflyed in form than his ...
            however they operate similar ..
            but mine does not require resosonance or any ringing .. TO SHOW ITS POWERFUL KICK!
            W
            my kick is displayed upon 1 single pulse ...
            • Joule thief
              I've built a joule thief and was instructed by one of the guys here on this forum nickname Zilano. I tried this but not giving me alot of out maybe cause it's on a small 2" toroid. It lights two neons easily. I have to do the resonance part now.
                well i worked on the jt for a few years .. wrote the thred... ya know
                i say what i do with confidance! as i know things others dont ...
                any how take the resosnance and shove it !
                my work makes resosonance ... resonance is based souly upon my work ..
                resosnance is miss understood !
                sorry but fact !
                i push it ..... it pushes back resosnance in its purest form!
                W
                so how could i align every god given stone .... lol
                ps ... btw the size of the ring torroide deturmns the speed your ring runs at ... the smaller the ring the faster the freq!
                my g6 is resonant at 1.2khz.. this is CORE MATERIAL ONLY ...... but for the size of the ring ... it is was the highest permibility.. like 10 000 u
                trust me not much of this matters ...
                use a N S T .. QUIT PISSING ROUND ...
                • people make videos ....
                  i have been reviewing my videos ...
                  and it seems as if they have beamed a signal to dissable the device as i try to shoot the videos ..
                  proof
                  #1 the device fails ... several times on camera .
                  #2 the light wont even lite .. yet 2 min b4 it is blinding bright
                  #3 there lines on my camera like a static interferience ...
                  #4 my cam is hd dvr camera and i can see the screen beeing effected by some source outside of my expairments .. you can see my camera unfocous and blur back it .. it never does this .. i have shoot hundreds of videos with it .. this is not the first time they try to mess with my BASIC BABY RATTLES THEY DONT UNDERSTAND
                  W
                  • you would not beleave the troubles im haveing loading a simple video ...
                    it apears to be a bit of a mess
                    i managed to get a youtube account .. so we will see if im allowed to upload to it ... so far its a no go ...
                    W
                    • Originally posted by willy96 View Post
                      Toroid size determines frequency you've said so what variable capacitor should I use for resonance? Zilano had told me to use CW an CCW on secondary coil is this ok in your opinion?
                      • im not sure .. play with it ..
                        i reccomend a nst .. when you see what it does how easy it is and how it works ... lol
                        you wont wind another ...
                        W
                        but do as you want
                        • today is your day ... bout time ......
                          ok well i have been able to upload to youtube ...
                          so today is your day !
                          Shania Twain - "Today Is Your Day" (with lyrics) - YouTube
                          W
                          here ya go ... no turning back now ... this is it now !
                          NST and 1.2vdc Battery Powering CFL
                          NST and 1.2vdc Battery Powering CFL - YouTube
                          i am currently uploading a really good video .. this is an eye poper ...
                          this is made for my friend joey .. the wow factor ...
                          unlimitied energy ether tapping full explanation - YouTube
                          cheers ill drink to that .. if you got cups your old enough go a head and hold em up !
                          W
                          ok comeing up next is ... the H.V.S.S.T the high voltage silver spinner technology
                          • HV flyback
                            Thanks for the vid very nice. Do you know on Don Smith devices?
                            Did you build a circuit like Don's or any who close the loop?
                            Thanks for sharing.
                            • no i do my own sh!t i build THINGS I UNDERSTAND UNLIKE 99% OF THE REST OF THE WORLD ....
                              yawn..
                              I LEAD I DO NOT FOLLOW ..
                              W
                              • i find it sad people have got not a clue ...
                                o well .. im not here to collect everyone .. i only collect my kind ..
                                the sad part is people think my devices need to be closed looped ..
                                just a poor demonstration of the laque of knowalge .. they have ..
                                thats all
                                here is something a little diffrent ..
                                Advanced High Voltage Silver Spinner Technology H.V.S.S.T. - YouTube
                                W
                                **********TAKE NOTE**************
                                TIME in the video ....... 7:00 to 7:30 ending...
                                look at the length of spinn i get .. from 1 properly timed pluse through the spark gap ..
                                1 bang ... almost 30 seconds of spinn ...
                                MY SH!T FLYS... just like my weed it will fu#k your sh!t up!
                                im doing all of this by hand pulseing ... so many things are learned at low speed .. oposed to those that took the high speed route ... they all got lost in resonance ...... yawn ... resosnance is a EFFECT NOT A CAUSE ... and my device causes the effect of resosnance ..
                                hummmmmm
