PLH Tapping fundementals
  • PLH Tapping fundementals
    ooooo
    its getting fun now
    this thred is for eduicatonal perpouses only
    PLH stands for POWER LINE HARMONICS
    i fully understand how this is achieved !
    and own the tools to do so !
    basically this solves any CRTC and RF interferience produced from any ring devices ....
    i can lay out a test plaitform for those intrested in testing WIRELESS BROADCAST RECEIVEING COILS the biggest challange is to tune in the coil the distance deturmans wich harmonic you choose to tap ..
    W
    here is a visual picture of how plh looks in my opinion the center dot of the picture is the power line .. the rings around it are the broadcasted harmonics....
    PLH stands for POWER LINE HARMONICS.....interesting....sounds like PLN
    Power line communication or power line carrier (PLC), also known as power line digital subscriber line (PDSL), mains communication, power line telecom (PLT), power line networking (PLN), or broadband over power lines (BPL) are systems for carrying data on a conductor also used for electric power transmission.
    if it is not....looking forward to reading more about it
      i have done work with wifi and poe power over eathernet ..
      but this is a wee bit diffrent anyhow we can tap it ! it cannot be traced! it makes no siginiture in space time ..
      basically there are many ways we can tap power lines via external devices!
      a friend of mine lives near power lines big ones he has held a floresecent bulb in his hands under the lines and it glows !
      so its there free for the takeing...
      the lines act as omni antennas broadcasting hv as the lines near me are 50 000v and aluminum basically all you need is to step down the 50 000v to something more useable ..
      and a friend of my friend's got his electric fence powered 0 wires .. and it works just fine
      W
        besides
        when the truth comes out ! this world will find MY VACCUMES DRIVEN BY TUBES JO! MUST BE USED TO clean up the PLH mess that is flying around out there causeing all kinds of health problems !!
        im not gonna get into it ...
        just know they will find an execlant use in the modern world !
        W
          ok so plh
          there a few ways we can tap this the simplest way is a floro bulb .. and a diode another simple TESLA way is the radient engery antenna simply an eleavated peice of metal insulated from the ground and the identical burried in the ground match the length of wires .. if you want it to piss fire ! because bacically you want to use the PLH'S to RING YOUR CONDUCTORS but clearly the wire lengths must be tuned in such a set up ... however you can recieve power dirrectly from the lines in such a set up as this just it wont piss fire .. that is achieved at the resonant wave for the conductor length ...
          puke !
          that feels better burp!
          there is a wave that fits in every conductor .. so you have to match it !
          lets just assume for an instance ..
          we have a 60 hz signal flying down a wire radiateing because thats exacatlly what ac does it radieates .. so it is kinda like radient energy eh?
          so at said distance we are gonna have a ring in the eather .. oscolating too...+-+-+-+- @120hz and the next ring at said distance .... osc @ 180 hz and so forth
          so this is gonna take some thought ... but it can be done this way and probally 100 other ways ..
          W
          post in thought ......
            insane
            yep i get it
            RF on the net is bad for you.
            Who want's to cook his brain anyway !!
            And i do understand about your tube love.
            It's between the plates and through the grid where electrons are really free, free as a bird not bound to any metal conductor.
            In here they can go faster....much much faster this is the place where magic happens all the time.
            Here they can dance whizz and fly along, over,through and on top of the field lines of the magnetic and the electromagnetic fields surrounding the tube but especially our planet.
            Just to return to that metal conductor at the end of their flight to be stuck stuck again...seemingly forever.....
