Originally posted by Michael John NunnerleyView Post
Foregot to say, this and any circuit like this emits powerful High Frequency RF and should be shielded or you could have big problems, I will not be held responsible for this, you do it at your own risk.
This and similar devices do not take energy from the environment unless you call "in this case" ferrite as the environment. In my other work I use gases and vapours for molecular vibration.
The energy in this circuit comes from the molecular vibration of the ferrite which has been vibrated and so induce a current in the output coil. Care must be taken on the amount of power used as the ferrite can shatter from the vibration, I think this has been stated before, AND IT IS TRUE, you have been warned.
Mike
Michael, thank you for sharing your drawing ! Lots of detail and very easy to understand. One question or clarification if you would... the 555 circut is that 250-450 hz or khz?
Your welcome, Khz
Mike
Hey Mike he he always full of surprises nice to see you on thread,quite within my limited grasp this,practically anyway, however there's still a few bits spinning about one of the first is Ferrite I dont like the involvement of ferrite or spectrum analysers for that matter after all would Tesla have either available?
I am actually starting to see the ferrite core part of this circuit as a crude form of what in mathematical terms would be the equivalent of cancellation of two lots of almost unsolvable maths. which in these machines is simply ignored and cancelled out In the ferrite core(nothing wrong with that)
I would imagine the key node would be searched for with a sniffer loop at some stage on these ferrite incarnations and then go for best signal.
I actually see the foundation of this machine (although electrical) to be identical to this mechanical/electrical equivalent Leon Raoul HATEM -- magnet motor You will see the way this man has cancelled all the magnetic spurious fields by simply throwing one magnet at another in such a way that all that remains is the gain, So where's the gain ? Its in the vectors in the above link. Notice this machine is forced into what I can only call forward slip in synchronous motor terms.
The gain actually results from the work of this Nobel award winner who noticed an anomaly in the pendulum Professor Maurice Allais - a genius before his time - as are they all It is my contention that a caduceus winding on an air core could well be manipulated into doing the same operation . still I leap ahead of myself got to get one going first! Hope things are improving in other regards.
Best wishes D
Best wishes D
Hi Duncan,
I'm sure you can do this, just be careful if you use ferrite, just don't over power it, use the minimum on the HV, 12v drive should be OK.
This is molecular vibration in the ferrite which induces CURRENT in the output coil "nothing from the vacuum as one might say". Lots of RF floating around with this one, so be careful of neighbours and TV eye etc. If ferrite is not used then you would be vibrating the air "nitrogen, oxygen etc", in gases the molecules vibrate and break links, this is what I use in my e-beam reactor for molecular manipulation, but if they are of none magnetic material then you will not get a current induced in a coil. It is current that you need NOT VOLTAGE, you can create high current densities in gases but if they are none magnetic then you do not induce this into the output coil, only voltage from what I have found.
Molecular vibration can create very high current densities and if the ferrite has induced electro magnetic resonance, EMR, then you can use this current, (thats putting it simply).
Mike
PS. Mark is having a lot of tests at the moment, we will see how things go, he needs one of the family 24/7 at the moment. Thanks for asking.
Easy to apply water-based paint for walls, ceilings, doors and other interior OR exterior surfaces. Very effective for blocking cell phone signals, CB, TV, AM, FM signals, radiofrequency radiation and microwaves. Tested highly effective up to 18 GHz!
Based on a high quality pure acrylic binder, this shielding paint offers a perfect compromise of excellent attenuation, high water resistance and good ecology. Good adhesion on many surfaces and substrates like latex paint, construction boards, cement, plaster, polystyrene, masonry surfaces, etc.
Signs and symbols rule the world, not words nor laws. -Confucius.
For faraday cage, I have a scrap microwave oven ( for test & development)!. Finances did not reach a full scale room!
Any way, 2 questions:
1- What is longitudal Coil/plates
2- what is the function of the light bulb?
Michael
You wind a coil at 90 degrees to the other coils, can be a few turns of thick wire or can be copper strip or plate which goes at least one complete turn on the ferrite @ 90 degrees to the other windings, this is the plane kulon, the Hz vector that I have explained in another topic "three dimentional wave" here in this forum (none conventional science). People should note what I have said in other threads, a lot of my work is linked together and is many years of work.
This is placed so as the ferrite is in the center of the strip or plate or few turns of heavey gauge wire "see how it has been done using the tube ferrite tube setup, it is a sandwich.
The light bulb is to give a resistance on what would be without it a near dead short, it also is a good tuning aid, you will see if you build it, it's brightness will change as you tune the PWM and the spark gap "more or less amp draw"., due to the interreaction of the frequencies.
In the circuit diagram for Tiger's device replicant, the two transistors in the oscillator, TR2 and TR3, are both shown as KT819 but TR2 is NPN, and TR3 is PNP ( according to the symbols ) It would appear that both should be NPN (As the KT819 series is ) I am curious because I have not seen any other mention of this ( is it just me ?) and, there is an almost identical issue with one of the Kapanadze diagrams ( the one that is started with a 9V battery ). I just wondered if anyone could throw any light on this ?
- function-generator ( 50Hz) run with battery-supply - then this is the
negative terminal of the batterie or midpoint of symetric battery-supply
Therefore all oszillators are free-wheeling ( no ground-reference )
- function-generator run by mains then it must be ground-reference.
ossillators have ground-reference
The first option is best because if you have this setup encased in a metal-box and leave the box not connected to ground it will not matter if by accident one wire hits the metal-casing.
eagle_0x
Could somebody confirm the truthfulness of this explanation?
It seems to me that it is correct, anyway one confirmation from Ganzha would be welcome.
midpoint of symetric battery-supply---What is that for?
Wesley mentioned two peaces of paper between toroids halves, what is that about?
And that copper plate bothers me since i am not sure how exactly connect them at one end, solder them with single wire?
Could we use TIP 3055/2955 transistors or 2n3055 and complementary?
And finally could someone link some image where we can see precise construction details of spark gap?
Mike
Hi Mike,
Thanks for your schematic. Id like to play around with it a little and I was wondering if one could use a toroidal ring off a transformer? Or would a pure ferrite flyback transformer work better?
Also, would an ignition coil work for the HV gen or would I need something with an isolated secondary?
Ren
Ren
I would use a flyback.
If anybody thinks this should be moved to another thread then please say so, but in reality it is much of the same thing
The possession of Knowledge, unless accompanied by a manifestation and expression in Action, is like the hoarding of precious metals-a vain and foolish thing. Knowledge, like Wealth, is intended for Use. The Law of Use is Universal, and he who violates it suffers by reason of his conflict with natural forces." Hermes Trismegistus
