Hi Folks!
Great community here, I love it!!!!!
Probably no better place to release this idea of mine and rediscovery of another one of the Great Nikola Tesla's overlooked patents.
According to Nikola Tesla patent:
Tesla Patent 454,622 - System of Electric Lighting
A minimum of 20,000 volts and 15-50khz pulse will light bulbs using one wire.
The potential and frequency of the voltage is great enough to excite the gas in the vacuum of a bulb. Much higher voltages and frequencies will also work.
It does explain many of the effects we have witnessed recently from other peoples experiments.
This means all these bulbs can be lit:
1. Incandescant
2. Fluorescent
3. Modified CFL
4. Neon
5. Metal Halide
6. High Pressure Sodium
The gas is in a vacuum and cannot escape. There is no current running through the light, so in theory the bulb lasts forever unless it is smashed.
The device to power it will only use milliamps and can be self powered using a solar panel and one of the many circuits that is currently being used, eg joule thief, ringer etc....
So far I have tried
2. Fluorescent
3. Modified CFL
5. Metal Halide
All bulbs produced light using one wire!!!!!!!
I am only using a Imhotep Radiant Oscillator Lite 5 pin relay circuit, but using two 6 volt lead acid batteries wired in series.
Imhoteps Labs
The frequency isn't high enough to get any of the bulbs, in particular the metal halide and high pressure sodium, lit to full brilliance. They have an interesting lightning effect inside though.
For anyone that doesn't know much about metal halide and high pressure sodium bulbs here is a very basic overview.
They are typically available in 250w, 400w, 600w & 1000w (although I have heard of higher ratings).
They are extremely common and are used in streetlights and horticultual growing.
They are usually powered by a ballast which produces a lot of heat. They have no filament and have a gas inside a vacuum. When they ignite, a spark is seen to arc inside the vacuum and then once the bulb is lit it uses a high current to keep it running.
I can see this one being very interesting.
Lumen / Lux output follows the inverse square law.
Horticultural growers main problem is heat from the bulbs. Using this method crops can be grown extremely cheaply and bulbs placed even touching the plant.
If you want to convince any non believers that they are living in Matrix and need to wake up, then this is it folks!!!!!!
I am having a custom transformer designed and manufactured and wondered whether anyone would be interested in a group buy?
The specs:
Ferrite Core
20Khz - 100Khz
12 volts to 25,000 volts
Any help towards our common goal will be greatly accepted with much gratitude!
1. Incandescant
2. Fluorescent
3. Modified CFL
4. Neon
5. Metal Halide
So far I have tried
2. Fluorescent
3. Modified CFL
5. Metal Halide
Imhoteps Labs
The specs:
Ferrite Core
20Khz - 100Khz
