Visual Phenomena Observed in Tesla, TARIEL KAPANADZE etc.. Research
  • #16
    @ Duncan,
    I found that video. Watching it again I realized the lines were more dotted so perhaps not what you were referring to. Anyway here it is if you are interested
    MVI 3364 - YouTube
    Thanks Ren, here are the pictures
    note: I see helical shaped sort of like the pyramid...maybe you see dotted because at the apex they nullify...
    the Unseen reflects the Seen....
    • #17
      Ren that really is odd to say the least, as you push the rods into the take off coil ( free power button if you will) its there! POW seems to have some sort of twist on it too which I've seem before! on small power machines
      • #18
        Hi guys, I have a theory for the light beams.
        All light moves in spirals or basically helices doesn't it ?
        I think the beams are caused by the frequency of the emitted light pulsations
        and the shutter speed of the camera combined with the curvature of the bulb
        and lens along with the lighting conditions.
        I think the character of the beams is determined by a few factors.
        1. The frequency of the emitted light pulsations.
        2. The frequency of the camera shutter.
        3. The relative orientation of the spiraling emitted light pulsation when the
        camera captures the frames.
        4. The effect is a spiraled or Zig zag vertical light beam, some can be crosses
        too. I have done it myself to the naked eye its just a beam, but to a camera
        it is a series of captures added together. when you look at one picture
        (depending on the emitted light pulsation frequency) you see the orientation
        of all the emitted light pulsations around the helical path of the light, kind of
        thing, at the moment the frame is captured.
        One reason we see it with our setups is because of the different frequencies.
        Most camera's should have a setting to adjust the shutter speed and stuff to minimize it.
        To point a camera directly at a light and have the camera see the light as
        bright it's compensating features must be disabled, and the camera will
        probably then be in some kind of manual mode, so the shutter speed will need
        to be set by the user rather than be automatic.
        The camera's usually have a setting for different light types and frequencies too.
        This is what I think so far after having thought about it overnight.
        P.S. This is actually one of the reasons seeing the brightness of a light on film
        or in a photo is not necessarily an indication of the actual brightness of the
        light. Which is why observed power measurements should be mandatory for all
        OU claims.
        If the power out is more than the power in why not show it ? I don't understand that.
        It couldn't possibly be any more dangerous than just claiming it with 1000 watts
        of lights lit from 10 watts claimed input.
        Lights can be made to look bright by the use of the camera and controlled
        light conditions, be they natural or artificial light conditions, and when that is
        done it is usually associated with poor footage quality.
        • #19
          OK and here is the observation I based my theory on.
          White Neon.wmv - YouTube
          In the video clip above you can see the angled pulsations rising up the beam of
          light. Only one is there because the converter is running at 60 Hz, which is
          almost the same as the 50 Hz the camera is set to for 50Hz fluorescent lighting.
          If the converter was running much faster there would be more and more
          angled pulsations until they appear to meet and form a zig zag looking line up
          the shaft of light.
          Each angled line is one pulsation of light at the working frequency of the
          device powering the light, in relation to the frequency of the camera shutter.
          The reason there is a vertical shaft, I imagine, is because of the curvature of
          camera lens and bulb, the angle the camera is pointed at the bulb, the
          orientation of the bulb and the lighting conditions.
          If a camera is forced to capture frames in unfavorable lighting conditions for
          the camera it will produce different artifacts depending on what is
          photographed or filmed.
          • #20
            Thank you Farmhand...always appreciate your intervention , always learn something new
            However, i will keep my mind open...and explore a bit more
            Dale Pond
            Our purpose and goal is to develop usable power by transforming non-observable, non-motion scalar or mind potential into observable, practical kinetic motion. Scalar can best be represented by metaphors, like a kitten under a blanket ready to jump out and do things. Mind Force can be found to affect matter under many circumstances, but it can't be measured or directly observed. There are several different ways to find this, most of which were classified as "spiritual" in previous times.
            Keely put together classifications of levels within the universe, some of which could be observed and some which couldn't. If we can go to the source and engineer from there, we won't have to deal with effects and symptoms. "Motion is an effect of disturbance of equilibrium."
            • #21
              The hertzian enigma
              the shaft of light.
              Thanks for the posting Farmhand ! If nothing else it demonstrates exactly what we are not looking for , This is effectively a hertzian wave heterodyne and you have even been kind enough to give us the frequencies, notice how the light is dispersed axially in a wide beam on farmhands video this is normal hertzian action, now compare to this still shot https://lh6.googleusercontent.com/-t...2520floyyd.png look how when the light is refracted it is in dead straight horizontal lines.. I hope you can see what farmhand has posted here is exactly the reverse of what we should actually be investigating.
              Remember I suspect you are looking at a manifestation of a linear wave and certainly not the linear wave itself which is travelling at 291,000 miles/sec compared to light at c=186000miles/sec as farmhand says the Herzian wave can also be seen every where you can see it on the TV when another CRT is caught in the background, Its all pretty much explained by Fouriers analysis, I hope the difference is clear to all
              • #22
                There are None so blind as those who will not see!
                Does it follow that because some one has “seen something before” It no longer has any significance!
                We all see things differently for instance I look at a tree and I see the Fibonacci series in the way
                the tree is shaped, In such a brilliant display of mathematics in order that each tier of the tree does not obscure the light from the tier below.
                Going around each Tier or level if you will see each branch is staggered compared to its partners on top and below, left and right,
                Again Natures mathematical natural beauty, slow time right down and you are watching the classic spin as described by Edward Leedskalnin and oh so many others others.
                If you carefully study a branch and measure the width of the bark you will discover its growth against time and the core directly tracks a natural log (e) base. So much going on and what do you see? A TREE. Yeh yeh Its a tree seen one of them so its not important!
                That is really why I suggested this thread not be started because as John Bedini says People just refuse to see !! and its true folks want to eat the meat and leave the greens.
                Lets just assume for a moment it is a manifestation of the “Linear wave” that of course officially (doesn't exist ) then it is every where caught in the right light you can see it entering animals.
                Consider this … If the linear wave (contrary to everything we are taught) exists and it does!! It is all around us! Its the very breath of life and I'm actually stunned that every one hasn't seen it!
                The fact that you are lucky enough to heterodyne with it because of a glitch in a camera is neither here nor there. Can you reproduce the effect? Is it the camera or the ambient light? Can you identify the glitch in the camera, does twisting the camera twist the laser type line,
                I guess what I am trying to say is DOH... IT A TREE will probably not advance this thread
                • #23
                  Thats more like it!
                  Originally posted by Haan
                  These vertical rays of light can also be seen from lamps powered by wireless power transmission using Tesla coils.
                  See attached from a video.
                  A fine demo Haan, Tesla transmission linear wave, I'd love to see what a mirror does or speeding up or slowing down .... And dont forget all the other qualities of the linear wave!!! I suspect that now you get the gist of what your looking at more will arrive.... we'll see
                  • #24
                    just posted this here: http://www.energeticforum.com/renewa...netism-46.html
                    The blue-violet light surrounding Schaubergers implosion engine when fully engaged was an ionization
                    effect caused by the differential of NTFFA between the inside of the container and the surrounding
                    outside, and on one occasion his prototype was creating such high values of NTFFA that the whole
                    construct tore lose from his working table and went all the way straight up through the roof of his house.
                    Thereafter Victor Schauberger did all his experimentation with the protoype securely bolted to a
                    concrete fundament outside his house.
                    He never was very interested in the levitation effect, his main objective was to create a reliable
                    power generator for domestic use
                    Dr. Hildy: Far-Infrared, SuperLight and Beyond - YouTube
                    I recommend you listened to it if you have time...some very interesting research info is being talked about
                    (talks about semi metal @ 15 min 26 magneto optical study )
                    • #25
                      Your welcome Duncan,
                      I just gave my opinion because the effect interested me. I presented my theory
                      for what I thought the effect most likely is caused by and what I thought some
                      contributing factors are. And I linked a video clip of it happening in real time.
                      People are free to make of it whatever they like, I just present my case.
                      I didn't mention anything about wave types.
                      I have no intention of looking further into it, mainly because the equipment is tied
                      up and I have other things to do.
                      Good luck with the investigation/research.
                      regards
                      • #26
                        Magneto-optic effect - Wikipedia, the free encyclopedia
                        A magneto-optic effect is any one of a number of phenomena in which an electromagnetic wave propagates through a medium that has been altered by the presence of a quasistatic magnetic field. In such a material, which is also called gyrotropic or gyromagnetic, left- and right-rotating elliptical polarizations can propagate at different speeds, leading to a number of important phenomena. When light is transmitted through a layer of magneto-optic material, the result is called the Faraday effect: the plane of polarization can be rotated, forming a Faraday rotator. The results of reflection from a magneto-optic material are known as the magneto-optic Kerr effect (not to be confused with the nonlinear Kerr effect).
                        In general, magneto-optic effects break time reversal symmetry locally (i.e. when only the propagation of light, and not the source of the magnetic field, is considered) as well as Lorentz reciprocity, which is a necessary condition to construct devices such as optical isolators (through which light passes in one direction but not the other). (The other, less useful, way to break time reversal symmetry is to rely upon absorption loss.)
                        Two gyrotropic materials with reversed rotation directions of the two principal polarizations, corresponding to complex-conjugate ε tensors for lossless media, are called optical isomers.
                        Kerr Rotation and Kerr Ellipticity
                        Kerr Rotation and Kerr Ellipticity are changes in the polarization of incident light which comes in contact with a gyromagnetic material. Kerr Rotation is a rotation in the angle of transmitted light, and Kerr Ellipticity is the ratio of the major to minor axis of the ellipse traced out by elliptically polarized light on the plane through which it propagates. Changes in the orientation of polarized incident light can be quantified using these two properties.
                        Circular Polarized Light
                        • #27
                          every little helps
                          regards
                          every inspection helps .. reveal the truth
                          • #28
                            I think you maybe interested in this thread:
                            http://www.energeticforum.com/renewa...collector.html
                            • #29
                              Duncan, some of what you said spoke to me. Here is a pic of a Bonsai I have grown for the last 10 years. Sometimes no matter how hard I tried to train it to grow a certain way it just did its own thing. Over time I learnt to tweak its parameters more effectively, more naturally.
                              @ MonsieurM, maybe you guys are onto something, who knows. I just looked at one of my old Dr Stiffler SEC videos I made and the light is there too, one wire AV plug and wireless AV plug. This was an older, different camera. Would be interesting to test it with some good equipment, maybe vary the framerates etc.
                              • #30
                                Thank you Ren for your contribution and keeping the flow going...i would advise anyone to read the article posted on Leon Sprink...you would realize that in his experiment a "zone of activation gets created"...if notice the proximity of most cameras to the running apparatus...we talk about over unity through harmony if so harmony would express itself through many levels...visual being one of them...
                                if you prefer a zone of influence
                                COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
                                An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways
                                . a harmonic cascade effect[/QUOTE]
                                just like a piano:
                                The Legend Of 1900 Duel Part 2 HD - YouTube
