One widely unknown effect of drawing energy from beyond the zero-point (sometimes referred to as reguaging zero, not the absolute zero temperature reference that most scientists think zero-point energy*is referring to) is that the frame drag of that energy flow has consequence upon our reality. Concentrate too much of that energy flow in one area and the affects upon our*weather*can be disastrous. As this energy flows, it drags weather patterns along with it. This is how the majority of weather modification technologies employed by the elite and the corporations/governments that*they control*are being used. They pump energy in to push weather away from certain points, and/or draw energy out to pull weather towards certain points.
Many researchers, in the quest for "free" energy, do not understand the give and take of the energy patterns of our planet, nor do they understand the consequences of their actions. They seem to feel that these natural energies are unlimited, and therefore they do not use caution in their research. If mankind is to use these natural energies on any sort of large scale, we MUST distribute the usage of these energies evenly throughout the surface of our planet. To hog energy in any one or more locations*can and will*disturb the*balances of natural energy flows*and wreak even more havoc upon our environment. The elite have done, and continue to do, massive amounts of damage to our environment. Those of us that understand and have the ability to tap into this energy, need to take responsibility for our actions, and ensure that what we are doing DOES NO HARM to our fragile*planet and its multitude of inhabitants. The elite alone are not the only reason our weather has become so fickle, but I'll get into that later.
While my System is designed to minimize damage to these natural energy patterns, and to minimize radiations harmful to living organisms, it can still be turned into a weapon by slightly modifying how it is operated. Just the addition of a few simple components will turn a potentially*safe*machine into a tropical storm generator!
Also, nobody seems to be*satisfied with*limiting their power draw to a few KW in any given location. My*Machine has a design limit of about 3 KW for this very reason. That is more than enough power to meet the needs of an average household, if the excess energy is stored during times of low demand, and then that stored energy is used to meet higher demands at other times. I am constantly being bombarded with emails from those that want to*use multiple* units in order to multiply the output. I designed the*machines so that they will interfere with one another in close proximity to help discourage this sort of activity, but I do fear that others will not place similar restrictions upon their devices.
Every prototype*unit installation that*is currently in operation is limited to one*machine per site. I have been collecting operational data*from these sites*for more than*a year, and tracking the data. All data collected thus far is pointing to a huge event in the near future.
As we near the galactic alignment of December 21of 2012, the stresses upon the magnetic field of our sun, its heliosphere, are increasing. Currently, the heliosphere is compressed to about 50% of its normal size in the direction of solar system travel. The magnetic stress that this places upon the sun has greatly increased solar storm activity. The cause is the region of space that our solar system is travelling through. As we near alignment with*the galactic plane, the density of hot plasma (the remnants of ancient*supernovae) is increasing. This once million degree C plasma has cooled to a mere 8,000 degree C.*Our suns*heliosphere is "ploughing" a path for our solar system through this hot plasma, but it does affect our sun, which also affects our planet and its weather.
From the data collected, it appears that the earth’s magnetic field, the magnetosphere, will collapse around May of 2012 +/- 3 months. The inhabitants of earth will be pretty much unprotected from solar and cosmic radiation during this time, and we will be vulnerable to CME (Coronal Mass Ejection) events. I fully expect there to be massive global infrastructure failures as the EMPs (Electro Magnetic Pulses)*of these events wipes out satellites,*power grids, communications systems, and nearly all unprotected electronics on the planet. While the magnetosphere is gone, the earth’s crust will drift away from magnetic lock with the earth’s core. When the magnetosphere re-establishes, which should be around July of 2013 +/- 3 months, the earth’s crust must re-establish magnetic lock with the earth’s core. This will result in what is known as a crustal displacement, aka pole shift. We can expect huge earthquakes, volcanic eruptions, and massive tidal waves on a global scale.
When all of this is over, it will be time for the survivors*to rebuild our societies. Hopefully, there will be enough alternative energy researchers left to help rebuild our societies around the use of clean and responsible alternative energy technologies.
