Walter Russell - Understanding and applying his work
  • #61
    We have been thought in school that magnetism is "a property of materials that respond at an atomic or subatomic level to an applied magnetic field" (Wikipedia). The magnetic field is "demonstrated" in a magnet bar, as the simplest way to visualise it. By extension, the same was demonstrated with an electromagnet.
    Next is an example which contradicts all this theory.
    We have been presented with the concept of Cyclotron: File:Cyclotron patent.png - Wikipedia, the free encyclopedia
    Please note in the figure the "Magnetic Field" which it will make us believe that magnets or electromagnets will be used to create that field.
    Now you'll see the principle of Cyclotron demonstrated to a small scale: Ball Cyclotron.
    Does anyone sees magnets or electromagnets? Even the title of the video clip says it is an "electrostatic accelerator".
    Russell said that the fields at the extremities of a magnet bar are the two opposite electric fields centered by the magnetism which generates and controls them. The same for the extremities of an electromagnet.
    The Earth has been presented as:
    1. A giant magnet
    2. A big ball which like other celestial bodies manifests gravitation.
    Except ferromagnetic materials, nobody proved a magnet experiencing gravity-like properties. A bar magnet will not "attract" paper, dust, or metals like aluminium, copper, etc. But an electrostatic charged baton will do it. So it seems an electrostaticaly charged body will manifest gravity-like properties better than a bar magnet.
    Regards.
    • #62
      Originally posted by dambit View Post
      In the pdf, the writer mentions that they couldn't get the coils close enough together to replicate the experiment exactly. I was thinking that maybe Russell used conical shaped coils that emulate the spiral vortices he writes about.
      Just a thought,
      Steve.
      This is precisely what I think it wrong with that experiment. Russell stressed the use of conical shaped coils to represent the two poles of nature yet these replicators think they know better. I hope anyone here replicating the experiment will do it with conical coils, otherwise it's a waste of time.
      As for talk about Russell's generator I found this picture on SVPwiki which is highly interesting. Might not be the diagram that is missing but it is a diagram of his generator none-the-less.
      http://pondscienceinstitute.on-rev.c...COS/SD_298.jpg
      Don't know the exact origin of this picture and unfortunately it looks like it could have been tampered with but who knows.
      Raui
      Scribd account; http://www.scribd.com/raui
      • #63
        Raui
        I've been going over the drawing you posted, looks like it was done on a chalk board, anyway I have started to model the components and figure out how it would go together. I've attached the test renders below.
        It is a very interesting design. The coil arrangement is obviously designed to simulate the spiral vortices, and the outer air core and inner solid core is designed to concentrate the field in towards the center of the spirals.
        I don't yet know if the coils rotate around the copper rod or if they simply rotate on there own central axis. Also how does it generate anything without some magnets?
        Steve
        P.S. The white parts represent the coil windings, and the metal parts the coil core. The black piece in the center of the whole thing is the insulation between the two halves.
        I still have to figure out the shaft etc.
        You can view my vids here
        • #64
          Edited out per user's request...
          • #65
            Thank you We.The.People, whenever I read your posts It is always to learn something new...Thank again for taking the time to contribute to our knowledge
            • #66
              Thanks for that pdf. It is very informative.
              • #67
                Originally posted by purelyconstructive
                I would like to thank each of you for the interesting things that have been shared, and look forward to working with you all.
                Notes On The Works of Walter & Lao Russell
                Thank you for thelink to the doc:
                the following is from that doc:
                The Mind
                There is a continual emphasis throughout Walter and Lao's work upon the distinction between knowing and repeating. For example, one can repeat information without necessarily knowing its meaning or significance.In relation to this concept, the brain is seen as a recording mechanism for sensed experience, and the Mind, while acting through it, is distinct from it. Likewise, our senses are receptors for wave motion. They span only a limited bandwidth. We might extend this range with instruments like microscopes, telescopes, and the like, but they can also sometimes be deceived by motion.I'm sure many are familiar with the phenomena of seeing a pinwheel moving clockwise when viewed from one direction and counter-clockwise when viewed from the other, or how a fast moving object can sometimes seem to stand still. There are similar illusions for every sense(hearing, touch, etc.), and not just sight. This fact is extremely important to bear in Mind whenever we observe things, even with our instrumentation (such as in "Empirical Science").Only the Mind can encompass the whole spectrum, and in so doing, know the transcendental Causeof all manifest effects directly.
                • #68
                  Steve
                  I am still not entirely sure but I do believe that the output is on the copper disk rather than from the coils similar to the homopolar generator so the coils would be powered and the you'd get your output from your coils. There is not too much other information I've found regarding this but the captions on the picture talk about taking output from certain points on the disk.
                  Raui
                  • #69
                    Raui
                    The pdf posted just above by purelyconstructive has a much clearer description of the device and others. Very interesting.
                    The copper disk / commutator must rotate but I'm not sure how/why it rotates. I get the impression that the positioning of the brushes on the disk correspond with peak pressure zones in the field that is created when the 4 coils are energized. Maybe this why he thinks 4 separate currents can be collected.
                    Steve
                    • #70
                      Hi All,
                      Well I got bored today and decided to wind some conical coils. Talk about epic fail!
                      As I would get to about the halfway point winding from the apex to the base, the outer diameter winds would jump position and come off the coil form. Tried using tape and all sorts of stuff. Not going to happen.
                      I will now get some removable cores made just like in the latest pdf posted and attach normal coils to them in series. I'll just do two at first to see if I can at least get some observations before going further.
                      I have attached a render of the coil cores. The separate coils will be glued onto these cores and series connected (4 coils per core)
                      Steve
                      • #71
                        Hi All,
                        Steve
                        Check out Dave's Method of making Conical coil....easy breezy
                        http://www.energeticforum.com/172395-post323.html
                        • #72
                          I used cardboard cone shapes covered with thin, foam double side tape. Also, secured every few turns with crazy glue. There should be some pics in Pyramid thread. This winding process went well even with AWG#26. I still have both cones. Couldn't continue due to financial difficulties.
                          V
                          General D.Eisenhower
                          http://www.nvtronics.org
                          • #73
                            @ MonsieurM,
                            Thank you back for taking a moment to acknowledge my efforts to try to get things sorted and share results.
                            @hann,
                            Thank you for indicating it is a split document,
                            and that the document is still missing important parts !
                            I see your point clearly now, and I'll keep
                            a strong lookout for the missing diagrams.
                            Originally posted by petar113507 View Post
                            Hope this gets everyone on the same page.
                            Ruddy excellent work mate. You just set up the field for the rest of us
                            Still very incomplete as you see from my later posts,
                            but a fair starting point for most people following this
                            until the rest are found & shared by one of us.
                            On the matter of Walter Russell - Atomic Suicide,
                            I have this information from an owner I wrote to:
                            Page-112 (First sentence) says:
                            "God creates three pairs of disunited male and female bodies
                            upon His extending octave wave shaft-
                            and then a united fourth pair at His thought-wave amplitude."
                            Page-156 (First sentence) says:
                            "All matter dies a centrifugally dividing heat death,
                            but it also lives a centripetally multiplying heat life."
                            Helping my handicapped wife to have a great X-Mas/New Year/family-orientated January,
                            I'll get back on this persuit about the third week in January or so, sorry for the delays.
                            • #74
                              What sort of cable was that? Looks like a good method.
                              I still think I will do it as I described before. I believe I can get a much stronger field strength due to the greater number of turns involved.
                              Steve
                              • #75
                                Steve
                                Ask Dave on his thread...He'll be more than happy to give you the specs
