Originally posted by OrionLightShip
My 76,000 rpm pulsed dc motor
Originally posted by soundiceuk View PostI believe using a bifilar pancake coil pickup you can make more wattage than your input. I have been trying to communicate this to Jorge.
What amperage is your current driver using?
Is it the high voltage spikes that are blowing the fets? The transistor in my circuit has never blown. The circuit was designed for this purpose. The fuse goes first.
What kind of coil are you using? Ohms?
What kind of spikes are you seeing? What are you doing with the spikes? I don't see any recovery circuit.
This is my last one...promise and you dont have to respond
I'm giving you a link to circuit that creates nanosecond PWM pulses up to 1000 volts from a nine volt battery.
Not what you are looking for but pay attention to the capacitive decoupling from the power suppy to the mosfet driver.
I promised....I will leave you alone now
Orion
Originally posted by mnsman View PostNo problem with 12V battery and 1000V fet. 24V-36V running from the batteries is where I blow 1000V fets. The power supply worked fine up until I started using the 1000V power mosfets. Now with as little as 9v from supply the kickback into the supply makes it go crazy. So with the 1000V fets I'm limited to 12V input from a battery. If I use a 200V or 500V fet I'm okay with a p.s. until the cap charges up to close to max voltage rating of cap then the bemf starts reflecting back to the supply.
Originally posted by OrionLightShip View PostThis is my last one...promise and you dont have to respond
OrionYou aren't any bother my friend.. quite the contrary I value your input that's why I'm here. The problem is that I can only think and type so fast with two of you coming at me with your ideas. It's a good problem to have. I will look at your suggestions later. Probably should be spending some time upstairs with my family for Christmas. Maybe a little research/building later.
Originally posted by mnsman View PostYes I've made a few suggestions to him too. I don't know if it's the language barrier or if he never saw them or he's his own man.
Originally posted by mnsman View PostDepends. I've run on as little as 250ma to 3A. 3A is way to much for the wire I'm using in the coil but I like to push the limits.
Originally posted by mnsman View PostYes the spikes are the problem with blowing fets. I wasn't blowing any until I started using the 1000V power mosfets. The bemf spikes are over 1000V with 39Vdc input. One exception... I finally blew the original fet I was using prior to start of testing others. That fet performed very well and got me to 76000 rpm. My best performer in terms of speed but less bemf.
I haven't got any test equipment apart from a multimeter. I need a decent scope and signal generator.
I have done a number of things using the spikes.
Put them back into the positive side of the battery.
Earth them to earth ground (plug socket or metal rod)
Let them go to atmosphere.
Put them back to coil negative as the earth is common on ignition coils.
Wire the coils in anti parallel and let the HV meet inside the bulbs I have been lighting.
What is your current coils spec?
If you want to find something off the shelf to play with I have recently learnt that in the transformer industry flat coils are known as "Planar" coils.
Might save you some hassle.
I need some HV caps and diodes to further my experiments.
Originally posted by soundiceuk View PostHave you actually wound a bifilar pancake coil?
I am using two ignition coils. One is 3.5ohm primary and 7900ohm secondary. The other one is close in spec.
Originally posted by OrionLightShip View PostI'm probably wrong about the spikes from a short pulse
One more stupid idea...use an rc integrator on the gate trigger input to ramp up to full on
The best solution I can come up with is some kind of rc circuit that allows the source voltage to ramp up slowly over say 10 seconds. I'm not in favor of a rheostat but if one were found that was about 5 ohm high wattage (500W) I would consider trying that. I would install a switch in parallel and switch it on after the full source is applied.
New thought:
Would a n-chan fet or NPN trans in series with the source work? Again switch directly to source with manual switch after up to full source. Instead of potentiometer an rc circuit could be used. I'm sure there must be better circuits out there. This is the idea though.
funny, I had the same thought and dismissed it due to more parts but yeah, you could put a slow rise time in between a primary power switch and the main mosfet.
I don't know that it will solve the problem because you have the same condition occur for every pulse right? Or does it always blow up at the first power up???
I think I would just use the 1500w TVP's
Originally posted by OrionLightShip View Postfunny, I had the same thought and dismissed it due to more parts but yeah, you could put a slow rise time in between a primary power switch and the main mosfet.
FYI: I finally read your Farnsworth thread. Interesting. Must learn more.
Jim
Originally posted by mnsman View PostHello all,
Have a look at this revision of the proposed driver circuit and let me know how it can be improved.
beg some more you make me laugh !
W
why dont you work at it insted of begging for help !!
do i beg did i beg .. the answer is no .. so your intenctions are inpure .. as your begging .. if you were suspoto have it you would never begg!
you need to learn that you get only what you work for !
fact! i have what i do from the work i have done !Last edited by willy96; 12-27-2011, 12:12 AM.
Originally posted by OrionLightShip View PostIt looks better than anything I could come up with!
I do think the 1500 watt TVP diodes are going to be your best solution against spikes....but I haven't looked for them and don't know it is cost prohibitive.
Thanks for your collaboration Orion.
Jim
Would you agree?
In my humble opinion it makes sense to be on a forum posting progress and failure and seeking input from others that may have knowledge outside your own and suggestions for improvement. In my judgement this is wise because as the old story goes... If I give you a dollar- you have one dollar and I have one less. In the same manner I can give you an idea and you have the idea and I still have the idea. The idea can be shared further and has the potential to be disproved or improved by others and fed back to the originator. It's a feedback loop. That my friends is the concept behind being on a forum like this- the sharing of knowledge for the improvement and benefit of all.
Would you agree?
