Hi! all busy guys here!
First, thanks for all the huge amount of experiments and personal experiences shared in this forum.
I'm here to propose to explain overunity by usual theory of electricity and magnetism.
The first idea I submit for critics, is that the gain of energy obtained in overunity device, like heat-pump or eventual self-running generators, finds is root in same phenomenon:
We saturate a space with an energy we want to catch and because of this saturation, the exceeding energy will want to leave this space.
The control of the flux or of the radiations will permit to use or stock this energy while transferring from a space to an other.
To be clearer (sorry, english is not my native language and it's pretty much efforts to type what I want to express
and thanks my browser for the orthographic corrections
) shall take the heat-pump:
We compress a gas to concentrate the entropy of the space. That creates a Difference of Potential of entropy between the inside space of the compressor chamber with the environment or other space of the device.
So, by this DP, and by a law that I call the "Law of Equilibrium Tendency" (implied "in the space"), the exceed entropy, expressed as temperature, will have the tendency to find a way for reaching back the equilibrium.
While controlling this tendency we can use this DP and stock or use the "exceeding energy", relatively to the space considered.
All the problem of overunity is that the ratio of the power of energy we want under the power of the energy that cost to us is > 1.0. It has never meant to "create" any energy from "nowhere"! in the usual cases like so heat-pumps, wind-turbine, solar-panels, etc.
So, my point is about electromagnetic motors/generators and possible overunity:
As Tesla has seen in very first times, when we inject very shorts chocks of hight voltage in a coil (compressing electric-field), there is a huge "pic" response in term of voltage too, and the Back EMF would be this tendency to reach back equilibrium.
What I see too, is that while we do this, while very saturating the electric field, that creates such a DP that creates to a the tendency to convert this electrical energy in magnetic energy and makes when comes backward in the coil, reactive voltage with reactive current (that we can't read on a ordinary meter) and this is this current which can feed the batteries without been observe if lack of adequate instruments.
So for this first point, for me, no "exotic theory" needed.
My second point is this one:
When we push back a magnetic field, we do it we a certain speed, known as very very lower than light-speed. But when we take-off any opposition to the compressed magnetic or electric field, the backward movement of the field comes back not at the same speed, but near at light-speed (even if in a mechanical viewpoint, the moving parts reacting to it are much slower).
We could say that the energetic work would be the same in the tow case, but I looks to me not:
Look at the wind, the power of a wind goes with the cube of it's speed.
Take a electric rotative generator, its power goes with the square of the rotating speed.
Or, to speed a car from 0 to 100 miles/hour on 100 meters in 5 seconds, how much more power it takes ? how much more energy we will consume than if the same distance in 1 min?...
You know: E=mc2...
So, the energy of the backward magnetic-field could represent more energy because of the difference of speed, even if the length of the path is the same.
So, here is my theory, and again, sorry if not very clear, but I will try to answer any question.
What do you think? tell me in what I could be wrong...
Cheers, Khwartz.
You know: E=mc2...
Cheers, Khwartz.
