Bi-toroid Transformer of Thane C. Heins
Originally posted by Alexg800 View PostHello,
I made & tested the BiTT represented on the photo. The big toroid has 6000 permeability, the little ones 1000. The tested frequencies are 1...20kHz, the loads were symmetric & non-symmetric ones, the primary was in resonance mode & ordinary mode. All the modes did not give any overunity, though there was an extremely high COP when the loads were asymmetrical ones... Where is a mistake? Who knows?
Why not contact Thane Heins and tell him you're an EE prof from some revered tech u hoping to replicate BiTT.
LinkedIN Profile Page
LinkedIN Group (Regenerative Acceleration)
SlideShare (79 Documents)
One would think the more BiTT replications, the more credibilty he'd enjoy. After all, his main focus has been on regenerative acceleration. If he were deliberately withholding secrets, why post 'How to's... or is it just a tease to lure unwary, techno-naive investors?
Originally posted by Web000x View PostIn DLE-TEST05 : Confirmation of the Thane C. Heins' Effect with the BiTT v1.5, Naudin states that the overunity effect seems to be related to a high time constant (L/R) of the primary winding. Your primary seems to have a relatively small L/R and could probably use a lot more turns. Inductance, L, goes up exponentially with each turn whereas the resistance, R, increases linearly. Just keep wrapping more turns onto that primary and see what happens. I'm interested to know as I've tested the Bitoroid configuration before and didn't get the results similar to Thane's. Everything seemed conventional, albeit I was using a non-ideal core for a transformer effect.
Thanks a lot for your comment.
In my design L=42mH, R=0.5 Ohm.
So as the f = 4kHz, then X_L = 2*3.14*4000*0.042= 1055 Ohm.
It means that X_L >>R, so COS is a proximately 90 degr.
Of course I could add turns in the primary. Will it help? How do you think?
B.R.
hi all been away for a little "bit"
here is most recent and most exciting work to date, enjoy
Bi Toroid Technology: Measuring Input and Smoothed DC Output - YouTubeIn the beginner's mind, there are many possibilities.
-Shunryu Suzuki
Zero Voltage Switching Circuit
Awesome video, Mr.Clean!
It looks like overunity to me.
Would you please post a schematic of your Zero Voltage Switching Circuit?
All the best,
Hi Kurt,
You have asked woopy under the video text: btw...how do you check (lamp) ohms while running?
Well, it is not needed to know the "hot" resistance of the lamp for getting the lamp power: once you have the smoothed DC output across the lamp (16.95V) all you would need to do is connect an ampermeter directly in SERIES with the lamp. Even if you use a digital DC ampermeter, it would give a much better lamp current than your using the supposed 34 Ohm lamp resistance, just because you now have a well filtered (smoothed) DC voltage available.
One more notice: if I can see correctly you use a 12V battery as the input power source and you use 12V for the input power calculations. Have you checked the actual battery voltage? because if it has 12.8V for instance, then you underestimate the actual input power, the difference is not too much I know but why not use actual values?
Thanks for all your efforts.
rgds, GyulaLast edited by gyula; 03-06-2013, 05:04 PM.
great work everyone, sorry to butt in, i have a new Bitoroid video to share, using Metglass large cores and unique primary centertap idea.
Driving each primary core leg separately at its according secondary, while exhibiting input current drop under load, maintaining a strong emf thru distinct deliberate flux paths to secondaries, and good power to the load despite the input current falloff.
More to come, but wanted to see how the primary performed and if i got the right effects using Metglass, pleased so far... enjoy!
Bi-Toroid: MetGlass Powerlite Cores, Testing For Input Current Drop, Strong Performance Maintained - YouTubeIn the beginner's mind, there are many possibilities.
-Shunryu Suzuki
Originally posted by zolgar View PostZvs circuit diagrams are at google, it appears to be an identical circuit in your new video 44 Mr.Clean. The center tapped primary is gorgeous, how have you arranged the pickup electromagnet?
The secondaries are connected to each other, bottom to top with thicker wire, added turns until i got the voltage i wanted. was a process for sure, but happy with the result.
Now to do the same with the Metglass cores, get away from LEDs and drive some real loadsIn the beginner's mind, there are many possibilities.
-Shunryu Suzuki
