Bi-toroid Transformer of Thane C. Heins
  • #31
    Magnet Transformer (free energy) - YouTube
    • #32
      Dave45,
      Awesome video, looks promising. The input looks to be
      pulsed DC. The following looks to be either a support
      base allowing it to stand, or some kind of third coil.
      Any additional info on this?
      Here's another video, using a Bi-Toroid frame.
      Its a bench test of the famed arrangement, with
      a mysterious result.
      [ Bitoroid BiTT Transformer - Unsolved Mystery - ]
      • #33
        Bi-Toroid Transformer
        Interesting concept.
        Thanks for your post.
        VIDBID
        • #34
          Besides the input to my primary coil being pulsed DC, does my system
          seem to be on the right track? My goal with it was to use the
          thickness of the cores to prevent the bEMF from reaching the primary
          while keeping the permeability of the materials at a level conducive
          to producing lots of output.
          Otherwise it has become a matter of expense and little availability
          in finding the correct core parts to build a working system with
          dual-reluctance materials.
          My guess is ideally the transformer might be constructed from four
          U-shaped ferrite cores and a thin primary, by comparison to my
          current system with the extraordinary amount of .03 mig wire
          accounting for the decoupling pathways.
          • #35
            Originally posted by geotron View Post
            Dave45,
            I believe its a third coil
            Your doing some interesting work, great vid, what are you using for a core, Im haveing the same problem finding core material,
            I went yesterday and bought some three quarter weld grade round stock, would rather have ferrite or metglas but we do what we can.
            dave
            • #36
              Just an idea I want to try
              • #37
                Dave45,
                The core materials I've used are ferrite and er70s mig welding wire.
                In woopyjump's version of the BiTT, the output is enough that it
                will power lightbulbs.
                [ BiTT Power Factor 3 by woopyjump ]
                The input to the primary of the DC-pulsed BiTT from my video was at
                roughly 1.25V through 20ohms or 78mW, while the output was at 144mV or 1mW.
                When driving the primary with the following resonator circuit there
                was an input of 12.5V and 96mA or 1.2W, while the output being 600mV
                on a 20ohm was .018 Watts.
                [ Video: Bi-Toroid Transformer Resonating ]
                • #38
                  Output Examination
                  The following video will show running values from the same
                  transformer as in the other two I've posted, only this time
                  the meters are connected directly through the primary and
                  secondary coils to measure AC while a 47nF capacitor is
                  turned on and off from the circuit. The resonation of energy
                  with a capacitor seems to produce a desireable effect on the
                  output, running from a 12V laptop adapter.
                  I've omitted the mig-wire decoupling cores due to their
                  apparent non-functionality. They will actually decrease
                  the output values once in place.
                  [ Transformer Output Experiment ]
                  • #39
                    Black Wire BiTT
                    [ Performance Video ]
                    Primary: .9ohm, 3 layers 25g
                    Secondary 1: 1.7ohm, 3.57mH, 5 layers 25g
                    Secondary 2: 1.8ohm, 4.14mH, 5 layers 25g
                    Variac used with 120VAC outlet.
                    Results show,
                    10ohm resistor into primary reads ~ 2.165 VAC
                    Loading the secondaries does not seem to effect it.
                    20ohm output resistor reads .065 VAC when both
                    secondary coils are connected and .063 VAC with one.
                    Obviously these figures do not represent the correct outcome,
                    and I'd like to question why this is so. Upon viewing
                    woopyjump's favorable demonstration of his black wire BiTT,
                    the only noticeable difference seems to be the much
                    greater impedance of his primary.
                    Would then increasing the impedance of my primary coil cause
                    a resultant leap in output? Have I mistakenly used the wrong
                    type of black wire? What else could be going wrong?
                    • #40
                      It looks as though my question has already been answered...
                      • #41
                        A 3d BiTT could be build using off the shelves transformer cores. I've seen a similar design before but you could use 3 identical toroidal transformer cores to do the job. They could be silicon steel, nanoperm, metglass...toroids or a combination of them. All experiment I saw deal with mW ranges surely that could be scaled up?
                        • #42
                          2D/3D BiTT & Rings BiTT
                          I think that 3D design would work when comparing essentially the same thing in 2D.
                          It's basically two small rings inside one large ring.
                          I wonder if the rings couldn't be built out of iron wire.
                          Vidbid
                          VIDBID
                          • #43
                            Vidbid
                            I'm talking about high power outputs something which needs some decent bulky efficient power transformer cores to achieve. As far as I can tell I haven't seen any kW Bitt's before.
                            • #44
                              Yep. I was interested in the coil configuration.
                              VIDBID
                              • #45
                                The tri-toroid configuration looks workable... as for this
                                black wire version, it's ability to transfer magnetic flux
                                seems to be lacking in a big way.
                                The following is my report after rewinding the primary. Having
                                used masking tape between the layers, an inadvertant connection
                                has left it a bit darkened from heat. Thankfully caught in time
                                to avoid producing flames, the coil has shown to be resilient.
                                After connecting it through a variac it has shown to have
                                better performance than the previous one, although does not
                                yet look to produce a gain in energy.
                                The primary core of two wires is secured to the inner toroid
                                of four wires by bending each sideways and then wrapping around
                                it with another wire. This method may be partially responsible
                                for the transfer performance, versus having one continuous
                                pathway from the primary core into each secondary coil.
                                It would have been extraordinary to wind this primary coil
                                in place between the two secondaries with the mass of wire
                                that it took.
                                Perhaps spot-welding it would improve things a little... ?
