Measuring Loads
Here is a video that is simple to understand and is only meant to be used as a tool for tuning. This video is not my setup but could be used by someone to loop with. Remember at the end of the project when more is coming out it is power that must be converted back to a form that powers the input.
Then the extra can go to a resistive heater element.
The one I am setting up is a 1.2 amp AC window unit that runs on 120vac.
Each motor runs very quite and are the same. I need a small system to run my tiny amp. It only needs about 60 watts input and the amp produces and output of 50 percent of that figure. So say 20-25watts.
It will be sooooo evident when I hit a node when the rotor is relieved.
This is the same as a wind turbine. Or even set it up off of a car alternator that is powering a load to an HHO cell pack. The claim is that the bi-toroid
Would double or triple the alternators capacity or any motor.
This simple setup could allow experimenters to test and tune without a scope.
https:
//www.youtube.com/watch?v=_-EJhUsxhUs
Mike
https:
Mike
