Bi-toroid Transformer of Thane C. Heins
  • Tesla is everywhere
    The "Solfeggio frequencies" are cyclic variation of the numbers 369, 147 and 258.
    Solfeggio frequencies - Wikipedia, the free encyclopedia
    • Solfeggio frequencies - Wikipedia, the free encyclopedia
      If we made a coil resonate at 963 hz could it also be tuned to the lower frequency's of the scale.
      I think it could using variable capacitors, this could get very interesting.
      • Type of core will I think contribute to its success
        from less permeability in the primary to high one in the secondary core
        resonance for the output can be achieved
        • been playing with the circuit simulator at falstad a series lc circuit can get out of hand real quick producing voltage and amperage levels that are unreal.
          very interesting, good thing it will be used on the secondary's.
          • if the secondary's draw energy like I think they will I dont think we could run the system at peak resonance once the lc series goes into short circuit mode the energy is phenomenal
            • New Use of BITT for a Generator on a Bill Muller Disc
              Overhead View:
              New design for a generator incorporating BITT stator coils.
              You could also have more rotor magnets to stator slots so there would be less cogging.
              • Originally posted by Berg View Post
                Overhead View:
                Image shack seems to be down at the moment.
                http://img838.imageshack.us/img838/6...tgenerator.png
                http://www.energeticforum.com/attach...1&d=1353402714
                It's the strangest thing, so I re-uploaded to Image shack.
                and below are some images of the Bill Muller configuration for reference purposes.
                The Stator:
                and the Rotor:
                • new vid, solid overunity?
                  hi everyone, back with some more measurements and testing.
                  i noticed my scope has a built in RMS calculator with internal calculable ohms.
                  it is not simply reading peak spikes, the scope understands that peak voltage is NOT the same as wattage, and it is a function that leaves nowhere to hide...
                  with all factors the same, using sine wave, and low frequency, the power thru the bulbs is the only variable.
                  and you will notice the readings are visually consistent with the apparent behaviour of the bulbs.
                  i am confident now with the RMS readings shown here. and the results here are in line with the inventors claims
                  now to scale up, and use this system as a HV resonant driver for my Smith coil board, or simply go with this system entirely, we'll see
                  here is what im confidently calling, overunity with the BiToroid, inspired by the people who originally disputed the output readings
                  Now with these RMS readings i am further convinced of the potential in this system
                  40 Don Smith Device Project: BiToroid SineWave Testing, Confirming RMS in/out - YouTube
                  -Shunryu Suzuki
                  • Good job, thank you for your persistence and willingness to share, shows your true character.
                    I think alot of us are working towards an end now, this gives us a direction thanks to your efferts.
                    dave
                    edit: forgot to add a link Back to Basics: Tutorial on LC Resonant Circuits - YouTube
                    viva le revolution
                    • Yes. Thanks so much Kurt? Is it? I can hardly wait for your scale up!
                      • Originally posted by mr.clean View Post
                        Cool video, Mr. Clean! Thanks for sharing your results.
                        Very interesting.
                        • Hello Mr.Clean,
                          In going with the diagrams posted of your transformer system, thus far you have not demonstrated the Bi-Toroid core configuration as developed by T.Heins.
                          The precise reason it is not operating as such is due to the secondary decoupling cores residing at the same magnetic reluctance as the primary cores. Magnetically they are one and the same.
                          Whereas in a BiTT configuration the primary core reluctance is much less than the secondary decoupling cores, your transformer diagram shows them with equal reluctance due to the positionings of the air gaps.
                          • Originally posted by ekpod View Post
                            Hello Mr.Clean,
                            Hi everyone and thanks, but credit goes Thane
                            Excellent catch, lol yes it is pretty much extra primary legs rather than sec core legs, BUT keep in mind i snapped the ferrites and they re connect almost flawlessly, BUT you are still correct, the sec cores need to be more secluded from primary, mine saturates too easily.
                            I was even thinking higher perm metglass core material as well, just on outer ring, with no connection to primary at all, and primary having lower perm ferrite would have even less reason to fight primary emf
                            -Shunryu Suzuki
                            • This resonator is built out of 16 ga. bailing wire its just a mock up, still have to secure wire ends then start winding the coils.
                              Center primary and four secondary's on the larger bands, the smaller bands are to shunt the primary.
                              • An iron ring has some very interesting quality's watch the iron ring he uses for a barrier to separate 300,000 volts.
                                300Kv On A Television - YouTube
