Searl Effect Generator Progress
  • #31
    Yes. This is one of the small original working models.
    • #32
      Here it is again. If you can not get laminate or ferrite then bundle some copper coated mig wire. Form it into a "C" shape to utilize that magnet to the max. Start small 24/12 vs 36/18
      • #33
        SEG as the inspiration for something new
        My first post so do not hit me with anything technical I am trying, as time will allow, to follow the Keshe technology workshops and although I have never made anything technical; however, l I do research and follow the new energies. Therefore, I would like to bring your attention to this video where John Searle’s SEG magnets format is adapted in a different way to gans plasma format by Michael: https://www.youtube.com/watch?v=N3PXgH8JMQs 47th Knowledge Seekers Workshop Jan 29 2015 – at 2 hrs 36 mins till the end of the video (there is a section on plants between the 2 parts of discussion on this topic).
        • #34
          Searl Technology in production
          [VIDEO]https://www.youtube.com/watch?v=fE9h0o2Zgjk[/VIDEO]
          • #35
            Hola Desde España le doy las gracias a usted por esta interesante información que puede ser facilmente replicada mediante un circuito similar a este pero con algunos pequeños cambios.....................................
            Hello From Spain I thank you for this interesting information that can easily be replicated through a circuit similar to this but with some small changes:
            Mediante este circuito modificado podemos magnetizar una ferrita y a la vez crear una oscilación rapida de corriente alterna junto con la corriente continua.......................Through this modified circuit we can magnetize a ferrite and at the same time create a rapid oscillation of alternating current along with the direct current ....................... Tambien existe la posibilidad de hacer con un circuito serie..................There is also the possibility to do with a serial circuit:
            El condensador de agua lo sustituimos por la bobina magnetizadora, hay muchas otras formas de hacerlo............................The water condenser is replaced by the magnetizing coil, there are many other ways to do this.
            REGARDS.
            must first understand the nature .... and then imitate
            • #36
              De todas formas pienso que la configuración de anillos es erronea a proposito.
              Deberiamos de centrarnos en el triboelectrico efecto, mi propuesta seria anillo central de imán ceramico chapado en cobre y recubierto de Nylon (+), imanes satelites ceramicos chapados de cobre y recubiertos de teflon (-) .... El metodo es simple, al hacer rotar el centro respecto de los satelites estos se cargan negativamente y el centro positivamente, creando un atomo a escala.
              Son los imanes recubiertos de cobre los que se cargan electricamente a miles de voltios, a mas velocidad mas diferencia de tensión entre centro y periferia......................................... .................................................. .................................................. ......................Anyway I think that the configuration of rings is wrong on purpose.
              We should focus on the triboelectric effect, my proposal would be center ring of ceramic magnet plated in copper and coated with Nylon (+), ceramic satellite magnets plated copper and coated with teflon (-) .... The method is simple, to To rotate the center with respect to the satellites these are negatively charged and the center positively, creating an atom to scale.
              Copper-coated magnets are charged electrically at thousands of volts, at more speed plus voltage difference between center and periphery.
              • #37
