Hello to All!
Hello to ALL!!
I am very glad to see how many of you have gotten involved in building this little oscillator...I am waiting from a response once you have tested...even if it did not worked out...I know it does, if it doesn't is because there have to be adjustments done on the signaling, regulating voltage or else...
I want to tell you all something very important, that I have written here before, but I will write it again.
Just want touch, some important issues here today...
Do not spend a lot of money on this, I have seen many sending me the whole set for body work...in pounds I believe, that's too much!!...I said it works even better on an Air core...So, please read me carefully, whenever I answer someone else, even if it is not related or within the scope of your doubts. This is an Experimental Circuit, I just brought it here as simple as I could find it, but it will get more clever as I keep going.
Whenever You are going to do the first testing, make sure of:
1_Set "Gauges" everywhere you could, Digital Meters, Oscilloscopes , etc.
Mainly you need:
A Voltmeter on Input (between Coil and Diodes, where you hook Input. This measure is one of the most importants...If you see nothing happening and "spending over 2.0 V...something is WRONG!! . So STOP, and go over everything again.
A Volt meter on Batteries Terminals...This measure will allow you to "see" if the Load is kicking back to your Oscillator, if it increases too High, STOP...Recheck your load , that is why I recommend CFL (Fluorescent Bulbs), they are your pilot light.
A Voltmeter on Output (After Diodes) If the light doesn't even attempt to light up...and you get huge voltage here...STOP!!...RECHECK!!
Ammeters on Input Versus Output.
And finally a Hertz meter on Input and Output (Here I want you to record on video if you could the behavior of this two gauges...
At normal set up, they should start at equal values...approximately (I use a TWIN set of same brand meters (EXTECH), this is because there are less chances of % of errors, same manufacturers use same components and designs...so they should be performing pretty good.
There are some meters, that when reading this type of electricity, they start jumping at High-Low...very fast...NOT GOOD!!...It happened at my Motors-Generators...And they were not cheap either, so the $ does not always means they are great,you will never get a good reading with them, therefore is a waste of time.
There are some Chinese Meters that are cheap, but very precise because they have built inside a Compensation Analyzer, and other designs as Logic Controllers , etc...so they do a very fast math and reads out a very good average value.
When doing the POT turns for the first time, GO SLOW!!...VERY SLOW, here watch your Hertz gauges, this should start giving some minor signals at very, very low values of Frequency...a very small pulse...ONCE You have found this point, MARK IT, then go super-slower...to get a faster pulse. (Here at this very first puling is where you could hook a Neon 120V like in my latest video..and here Radiance will come to you at ZERO VOLTS from Input Voltage...Here you have to establish another mark at the highest peak you get the neon to Pulse this light ONLY!!...Once you start getting the Normal illumination, you HAVE PASSED this stage, then STOP, and take Neon Off. and keep going on the CFL...(DO NOT PUT CFL AND NEONS AT SAME TIME FIRST USE NEON, even though the CFL will also do this reading, however the real picture of Radiance you will only get it with Neon, they are beautiful colors and is worthy) put a switch for both On-Off, so you do not get distracted where you were at.
Do not try a Halogen or Tungsten filament Incandescent lamp...it will turn it on , but you will get MASSIVE negative feedback ("C EMF")..and your Coil will overheat, Later on We will even light a Metal Halide Sodium HID Bulb...but NOT NOW.
I have to keep moving ahead, there are tons of things coming on, some are related some aren't...
I am "reviving , and enhancing to newest technology improvements, a few Nikola Tesla patents, Motors-Generators and Coils...And some new type of Oscillation..
But I will like first to see some of you, at least one, got it going perfect...then He-She can stay here while am gone to other sites-or Forums..
And last, I know this is a public site, so anyone could see-read this Posts, and this Goes mainly to them, as You have read me before on this.
THIS FINDINGS I HAVE MADE, CAN NOT BE PATENTED NOR, INTELLECTUALLY, PROTECTED, THEY ARE BASED ON A SERIES OF ANCIENT LAWS on PHYSICS and ELECTROMAGNETISM, that SCIENCE MADE SOME "MISTAKES", AND SOME FORGETTING, BUT AM NOT HERE TO JUDGE THEM, I AM HERE TO DISCLOSE THEM OPENLY, AND PROVE THEY WERE AND ARE WRONG, WITH REAL LAB FACTS THAT MANY OF YOU WILL BE WITNESSING WITH ME THROUGH HERE.
SO, IF ANY SEE DIAGRAMS HERE, AND COMMENTS THAT WE'VE FOUND RADIANT ENERGY TAPPING, PLEASE, DO NOT ATTEMPT, TO COPY AND WALK NOR RUN TO THE DESIGNATED AGENCIES, TO MAKE THEM PROTECTED , I KNOW YOU MAY HAVE A VERY CREATIVE MIND...BUT ALL YOU WILL DO, IS CREATE SOME HEAVY AND PAINFUL, STOMACH ACHE IN THE USPTO or ANY OTHER COUNTRY, EXAMINERS OR ATTORNEYS FIRM...DUE TO TOO MUCH LAUGHING!!
THAT GOES ON EVERY DISCLOSURE I MADE HERE OR ELSE, MUST ARE BASED ON "PRIOR ART" APPARATUS, DEVICES, INVENTIONS OR LAWS.
Cheers and good luck on this!!
Hello to ALL!!
Mainly you need:
