  • JohnStone
    The
    ACS714LLCTR-50A-T
    is a 50 amp version.??????????????? Digikey has them at 1.80 USD.
    Also the
    ACS709 Current Sensor Carrier -75 to +75A
    breakout board is same but heavier, also not a lot of money. These can also be cheap amp measuring devices.
    Dana
    Nikola Tesla
    • Originally posted by prochiro View Post
      JohnStone
      The
      ACS714LLCTR-50A-T
      Also the
      Dana
      Thanks for the hint. I will evaluate th 30A version. This is no decision regarding final component.
      The carrier with ASC709 is a choice as well
      • Automotive, yes please!
        Hi Lester,
        I agree with your concern and experienced it at a scope based current meters. I own such an old pet (Tectronix) and it proves you to be true.
        On the other hand we may consider:
        • This monolitic all in one component in automotive grade (1.5% accuracy) might be an advance compared with former makes.
        • We do not want to measure exactly but to protect and thus it is not important if we stop current at 30A or 35A as long we prevent running FETs at maximum ratings.
        Component: ACS714
        Breakout board I prchased: here
        Consult: this
        I will go ahead and test it.
        @ALL not being gurus in electronics! Do not fall into despair! We need to discuss this on this level. You will get solid instructables later on.
        Hello John and Lester, you guys are doing some great work here, Thanks.
        I LOVE the words " AUTOMOTIVE GRADE " because it's normally made to withstand vibration, being inside a hot vehicle, etc, etc.
        Regards Cornboy.
        • Originally posted by JohnStone View Post
          Hi Lester,
          Component: ACS714
          Consult: this
          That looks great John!
            Hello John Stone, first of all, I was very sorry to hear about your some problem for which for the time being your motor project is on hold. We pray all the problems will be behind you very soon.
            For the future, I am going to make my pulse unit using Arduino route.
            I just received today:
            Hopefully will incorporate measurements like current, voltage, RPM, etc. within one or more Arduinos.
            To @JohnStone @Lester, @ all
            The current sensors:
            ACS709 Current Sensor Carrier -75 to +75A @ $9.95 has a typical error of ±2%.
            ACS714 Current Sensor Carrier -30 to +30A @ $8.95 has typical error of ±1.5%.
            price wise there little difference.
            Will be starting imperial motor project soon.
            Warmest regards
            light
            • Originally posted by Lightworker1 View Post
              Warmest regards
              light
              Thanks for sympathy. Fogs are lifting but it takes time to disappear.
              Regarding current sensors:
              This is an addon for safety protecting our FETs. We should start keeping drivers simple and loading them with less load and voltage first. Do not get lost in secondary tasks!
              Just now there is no recommndation for using a specific sensor or technology.
              Please note using such sensors is not like using a simple switch. We deal with different noise problems being severe if switching 50A and more. We deal with minute signals in mV range. And we can not relay on any micro because it will not react within µs.
              I will test the 30A sensor in order to forward experience. Anybody may do the same but on own risk. There is no general recommendation availably yet.
              Let's focus on drivers and get them running.
              BTW:
              For electronic enthusiasts herein: RS electronics offer a free program for schematics and PCB layout (full version). DesignsparkPCB
              Quite big library and you can add own components easily. Schematics is quite easy to learn!!!!
              Regarding components: You may decide to choose - directly from designspark - online out of RS stock and get a quotation for parts instantly.
              They sell the coolMOS FET suggested and the Micrel driver (sugested by Cornboy) as well.
              I will draw my next schematic in Designspark. So you will get BOM along current prices.
              JohnS
              • RS.
                BTW:
                JohnS
                Hello John, I mainly buy parts from RS but have not been game to even look at designspark, once again, wwhhhooooosh, over my head, but maybe if you go this way i can follow.
                It's feeling more like home to me.
                Thanks john,
                Regards Cornboy.
                • Sfh617a
                  JohnStone
                  I have been trying to see how the SFH617A works by creating a small breadboard circuit. Cant get it to work. I set up the PWM which has a small led to show slow pulses and put that into pin one of the opto. Pin 2 goes to PWM negative. At this time I believe I have somewhat like what a mosfet with a wire to the base looks like. OK to here? Then on a separate power supply, positive to opto pin 3. Pin four goes to an led/resistor and back to negative. The led just stays on and does not blink like I think it should with the led in the PWM. What am I doing wrong. ?????
                  Dana
                  Nikola Tesla
                  • Switching batteries.
                    Battery Isolators | Solid State Relays | ORing Diodes
                    Maybe off topic, but might be something for future.
                    Regards Cornboy.
                      JohnStone
                      Dana
                      Hi Dana,
                      Not sure what output you have at generator side. Is it source/sink or sink only? The opto input might be dead now?
                      In your report a resistor is missing at opto input. It needs to be operated like normal LED. Calculate the resistor to let 10...20mA to flow through the led.
                      Given your generator output is being driven by 12V calcualte (12V-1.6V)/20mA = 0.52 kOhm = 520 Ohm (1KOhm will do for test as well)
                      Connect for driving opto:
                      12V -> resistor -> opto pin 1 -> opto pin2 -> generator output.
                      [B]
                      Consult this animation I found for you in internet:
                      Additionally to pic you might want to connect a LED in prallel to the output pins of opto.
                      FYI: Transistors operate as well if you interchange emitter (arrow) and collector but they perform worse. Please check correct connection of pin 3 and 4 at opto.
                      JohnS
                      EDIT: for more details see post
                        JohnStone
                        Dana
                        Hi Dana
                        I think you may have pin 3 and 4 the wrong way round:
                        http://www.vishay.com/docs/83740/sfh617a.pdf
                        Also I found out the hard way, you need a resistor between the MOSFET gate to ground to quickly switch off the MOSFET.
                        John
                        • Originally posted by john_g View Post
                          Hi Dana
                          John
                          Sorry, my post above is not clear enough.
                          Thus you can test the opto itself.
                          For connecting a FET remove LED. A FET gate is basically a capacitor. You can imagine on how to charge it and discharge it.
                          You can add to the circuit above a FET (connect gate to opto pin 4 and source to pin 3.
                          If output of opto switched off -> the gate will be charge via resistor -> FET switched on.
                          If output switched on -> the opto output sinks ALL current from resistor and additionally discharges the charge out of the gate - the FET switched off
                          There are different ways to wire an opto to a FET. This is just one way to do it.
                          IF any question please ask! It is essential to understand!
                          • Hi JohnStone
                            Thanks for the help. Got it going now although it throws my frequency/duty cycle thinking for a loop as it is inverted from PWM.
                            Nikola Tesla
                              Hi JohnStone
                              OK, got it. Here is a test circuit being not inverting.
                              States:
                              1. no curent at input -> transistor open -> 10K drags gate to GND -> FET off -> drain 12V -> bulb off
                              2. current at input -> light at LED shining -> transistor switches on -> 1K drags gate to appr. 11V -> FET on -> drain GND -> bulb on
                              But please note it is slow and thus not a final circuit for your pulser.
                              • BZW06-15 - MULTICOMP - DIODE, TVS, 15V, 600W | Newark
                                BZW06-13 - MULTICOMP - DIODE, TVS, 13V, 600W | Newark
                                Freight Charge: $20.00 once per order (two links above)
                                BZW06-15B STMicroelectronics | 497-12462-1-ND | DigiKey
                                BZW06-13B STMicroelectronics | 497-12759-1-ND | DigiKey
