Originally posted by JohnStone
Originally posted by JohnStone View Post@Lightworker
1. Glad you adopt Ardunino / I2C. In case you intend to get I2C opto isolated see.
2. For cheap arduino search for "tosduino" at eBay.
3. Note: most analog sensors have 2.5V for 0 reading. For unidirectional measurement you have 512 steps left only (1024 for full range + -). In some cases a precision level shifter will be advisable.
4. Please note we want to have a set of building blocks in order to measure our research motors. Additionally we need PC links (USB / BT) in order to get data out of our setup for evaluations and proofs.
Hierarchy: PC -> Arduino -> I2C bus nodes
JS
Hello JohnStone
Many thanks. That I2C opto isolation link was great and I have book-marked in my I2C Bookmark. Only last night I was searching for this very topic. You are right about collecting data that is easy to collect & analyse.
We are now moving in that direction.
And thanks for that note about the analogue sensors.
My A1302 Hall Sensor behaves in that manner too but however N-Pole makes it go in direction and S-Pole in the opposite direction.
For the Hall Sensor that arrangement is fine.
For other types of sensors lets see what happens in practice.
warmest regards
light
Hi All,
I worked with 4, 50w, 12v Halogen bulbs today and the monster driver had not problems. Heat went 10degF above ambient to 71.
At all Frequencies checked from 16 to 10,000 and all duty cycles checked, all was well.
I did notice a little spike at the lower end of the vertical line of the sq wave after turn off. We'll see if this is an issue at higher power.
bro dLast edited by Donald Haas; 03-21-2013, 03:14 AM.
bro d
I stayed with the setup and moved on to 108v and 6, 300w bulbs.
Pulsed them at about 5000hz and 70% duty cycle.
The spike in my previous post has dissappeared. I traced one issue to my lap top PSU that I was using to power the regulators so we are very clean with the square waves at the fets.
After about 5 min the fets were in the low 80's F.
I have AL angle iron for heat sinks, not large and no fan.
One Monster Driver with 2 fets.
I'm satisfied that the Monster Driver is buildable and will work as John Stone set out to design.
Thankyou Mr Stone. I really appreciate that we've had a ring side seat.
The bulbs are 120v bulbs and they were all very hot. Too hot to touch.
I will give links to the Target files where I modified the layout to "taste"
but did not try to change anything design wise.
I just learned how to etch pcb's and have etched my gen cct and two
parts of the Monster.
All is well in bro d-ville.
bro d
bro d Target links
https://www.dropbox.com/s/yox4ebqzm6...O%20FETS.T3001
https://www.dropbox.com/s/6vebk2wsy4...O%20FETS.T3001
bro d
You may add further tests:
1. 5% duty -> temp. indicates switching losses
2. 95% duty -> temp. indicates losses from RDSon
If you decide to add a second pair of FETs you should repeat test#1 with same load, same heat sink in order to check if switching performance is still OK or derated (more heat)
JSExperts spend hours a day in order to question their doing while others stopped thinking feeling they were professionals.
Hi Lightworker,
regarding I2C:
You should be aware that I2C does not provide any genuine error check. It was invented initally as pure IC /IC bus on PCB. This could give erroneous readings if extended to cabling.
Conversely 1 wire bus from Dallas provides genuine error checking.
Originally posted by JohnStone View PostHi Lightworker,
regarding I2C:
JS
Hello JohnStone, thanks for the info.
While trying to find solutions I came accross the following:
Communicating between Arduino boards using I2C, Bus Extenders, and Isolation - oxGaggets
oxGadgets: Communicating between Arduino boards using I2C, Bus Extenders, and Isolation
To operate a bus over longer lengths, an extender such as a Philips/NXP P82B715 is used. System tested by extending the I2C bus over 5 meters.
There is some work in progress using Arduino with one-wire also.
Dallas Semiconductor (now Maxim) produces a family of devices that are controlled through a proprietary 1-wire protocol. There are no fees for programmers using the Dallas 1-Wire (trademark) drivers.
If need eventually arises with advantages then for sure also use one-wire system also with Arduino.
Warmest regards
lightworker
1. If two microprocessors communicate via I2C their programmer may add a layer for CRC check.
2. But genuine I2C dedicated devices do not supply any check.
I am not sure on what way you head to #1 or #2? Please explain your architectural view.
Hello to All, Hello Sir John Stone.
Hello to All, Hello Sir John Stone,
Hello John, hope you are getting better from the Flu..
Wanted to share some electronic motor control knowledge, which would be very useful for our future Asymmetric Universal Machines...controlled by AC Sinewave.
Yesterday I repaired a very good small drill I had, that all the sudden stopped...
It has a Digital display on the controller showing from 10-35 (10-35,000 RPM's)
I started to check first all electronics on it and realized it has like a MOSFET where Drain was attached to one of Motor Stator wire..(Motor is a Universal type...connected Parallel stators with rotor brushes in a "sandwich", where rotor connections are in the middle. So I tried checking Drain Source and it did not gave me same typical FET readings...I searched part number and it was a Triac...did not have a heat sink nor a metal heat mount back plate...here it is:
Z0409MF Datasheet
So... this Triac replaces the MOSFET application for AC speed regulation...
Anyways, the problem with tool, was an open wire in one of the stators...nothing wrong with electronics.
But the point here is...
This component does not require a heat sink, meaning it works pretty cool...and it does the High Speed switching for Universal Small Motors...receives the Gate signal from a small microprocessor...and it handles from 20-50 V AC.
I know it is not compatible with Permanent Magnet Machines...only wound stators...
What's your opinion on this component?....I have not got the time to make a long search...but are there also TRIAC'S for Higher Amperage handling in a small TO220 case?
I mean, I know there are VERY High Voltage/Amps TRIAC's for TV Applications as many others...but, I was referring specifically to Motor Switching Control...
UfopoliticsLast edited by Ufopolitics; 03-25-2013, 05:33 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Hello UFOPolitics
This is probably the quickest intro and circuit related to motor control for the Triac.
http://sg.renesas.com/media/applicat...iacAppnote.pdf
Dana"Today's scientist have substituted mathematics for experiments and they wander off through equation after equation and eventually build a structure which has no relation to reality."Nikola Tesla
Triac
Hi Ufo,
thanks! Flu is gone to nirvana
1. Triacs have one bad habit. They will not stop conducting until someone else switches the current off. Therefore once triggered they will conduct the rest of phase time up to mains current reversing. Bad for DC!
2. I learned that switching off rapidly is one essence of OU. Triacs will refuse to behave alike.
There are some tricks to overcome this. Early electronic photo flashes used this method. Unfortunartely it is not applicable for us.
3. Example for high amp SCR F1857SD600. Drop voltage ca. 1.4V -> 140Watt loss @100A. Price about $100.
100A triacs for pin welders range at about 200$
4. Tesla's mech. switching is still unsurpassed! Any electronic switch will generate losses and needs to be cooled at high amperage - unfortunately.
5. For very high current we can switch to IGBT. They are somewhat less lossy at high temperature - but still lossy and need to be cooled. Expensive SiC-FETs from Cree are somewhat better. ($47 each)
6. Sorry for desillusion. I still vote for monster driver. It can be expanded to 4 or 6 FETs while maintaining good speed (needs to be measured) and while reducing losses. Then we need to separate driver PCB and FETs along protection circuits. Cornboy posted a pic with his choice of heatsink - smart!
7. The only alternative I know are solid state relays. They come as "hockey pucks" ready for mounting on heat sink. Price above $100.
Sorry for inconvenince! I am an optimist - usually.
JS
Today I received this in my Email
Perhaps they may be faster and better
RS Top Selling New Products!
Dear IAN
Renesas - Super Junction MOSFET
Super Junction Power MOSFETs product line is based on Renesas' own deep trench technology. This enables highest efficiency and performance through low Rds(on) and low gate charge.
RJK60S8DPK-M0
- Low Rds(on) [600V/53A/56mohm(max.)]
- Low gate charge [Qg 82nC(typ.)]
ST Microelectronics - MDmesh MOSFET
- MDmesh™ V is a revolutionary Power MOSFET technology based on an innovative proprietary
vertical process
- TO-220 worldwide best RDS(on)
- Low Total Gate Charge (QG), Fast Switching and high efficiency
- Withstand voltage 650V, 100% avalanche tested
- Smooth Turn-off waveform, Easy to gate controlled, Possible to reduce EMI filter
Just trying to helpful
Thanks John!
Hello John,
No problems at all, is always great to know advantages-disadvantages...
I am sure the Monster driver would give a nice fight to the Beast...
Thanks!
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Thanks Dana!
Dana
Thanks my friend!
On the other topic...
When are we going to see that Imperial being oulsed by the Monster driver my Dear Friend>??!!
Pleease We are eagerly waiting!
And by the way, send my regards to Bob French, long time I do not see Him around...hope everything is fine...
and Regards
Edit 1:
After I finished writing to you this post...I went to check my email...and guess what?..a mail from Mr Bob French...
He is fine, moving to CA...
Regards againLast edited by Ufopolitics; 03-26-2013, 02:36 AM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
