    Hello Mike
    My research, honestly, has not gone that deep and far into the field of Electrolysis. Therefore can not answer every one of your questions in detail.
    I had tested lightly and a simple salt solution and two chrome plated electrodes...gases are released and chrome had been stripped off one of the electrodes to the point to leave it in the bare copper, clean, while releasing a black solid liquid (heavier than the solution, goes to bottom of container slowly)
    Temperature is very low, couple of degrees above room temperature...
    Bubbles were 'On' all times, but did not analyze type of gases there, sorry...
    Like I said before, it was a light, simple testing...
    Yes, related to Motors and Generators...that is where I am really going on heavier...
    So it would be great if you decided to test this Chemical reactions of Electrolysis and come back here and tell Us your results...
    Hello UFO,
    Thank you for the info.
    -What voltage input did you use in your electrolysis experiment?
    -Estimated amperage input?
    -Did you use your 3-120 turn 18ga coil in parallel hookup?
    -estimated freq. range?
    Basically, did you use your single coil setup with power supply you describe in your earlier posts?
    Cheers Mike
    • My Info related to my lite exp with Electrolysis...
      Originally posted by vrand View Post
      Hello UFO,
      Cheers Mike
      Hello Mike,
      Sorry about not getting back to you sooner.
      1-2-Voltage/Amps Input 36V 6A LiPo batteries
      3-Yes, I used my 120X3 Coil. 18awg NOT in parallel, but in series each one 1 to 2nd to third.
      4-Frequency Input @ 800Hz, Output Cold RE @2000Hz
      Yes, when I did this test I was running my older set-up, Oscillator single N-Channel, and Steel heavy core with 360 T 18gauge, have not tried with new one Mike.
      • My opinion on LM324 and frequencies related.
        Hello UFO,
        -Used your 3-120 turn 18ga coil in parallel hookup?
        Here is an example of a HHO PWM:
        50 Amp 50A PWM HHO DC Maxx Tronic MX068
        MXA068 Heavy Duty 50 AM PWM DC Control
        Detail:
        - PCB dimensions : coming soon
        - Generic Enclosure : FB09 Plastic Enclosure 5" x 7.5" x 2.5" deep (see item FB09)
        - Power supply : 8 to 30 VDC by using jumper
        - Load voltage : 8 to 30 VDC
        - LED Power on indicator
        - Output : controlled DC motor by PWM (Pulse With Modulation).
        - Large Spades on circuit board for ease of connection.
        - Obtain low speed operation of DC motors without sacrificing torque
        - Range : 0-100 % adjustable Duty Cycle
        -100 Hrz Fixed Frequency of operation or 400hz to 3khz adjustable
        -LM324 and 6 Heavy Duty IRF1404 MOSFETs with Large Heavy Duty Heat Sinks
        - Fully Assembled and Tested.
        - Ready to hook up and use in your project or OEM Product
        -Replacement MOSFETs Available
        For fast diodes with No Switching Losses, 1200 V and 32 A rating:
        CREE C4D20120D
        Silicon Carbide Schottky Diode
        http://www.cree.com/~/media/Files/Cr.../C4D20120D.pdf
        Looking to see if there is an off-the-shelf power supply that would work, but need the info. on voltage, current and frequency specification range.
        Cheers Mike
        Hello Mike,
        I have tried with many different chips to obtain oscillations to drive coils and motors...One of my failed ones was with an LM324, It did oscillate but pulses for some reason were not strong enough to drive Gates (as reflected in the MOSFET's Output) as a 555 Timer...
        Another thing here related to that oscillating circuit...
        Do not like that fact...the starting level to adjust the frequency should be at least from the 100Hz going up slowly...not 400Hz. And a 100Hz fixed frequency means absolutely nothing to get RE...
        I can start rolling up my oscillators at 9-18Hz up...and I installed a Vernier Dialer to Pot in order to delay turns ratio and isolate turns from touching directly Pot.
        One more thing, the Pot must be grounded or it will increase (jump) to higher freq with your hand...
        • I have followed your thread from the start, and I hope to inspire you to look at it from a different angle, a coil produces two electric fields one cold and one hot if you are not allowing for the hot as well as the cold your system will be inefficient.
          In my book you are a highly respected experimenter and I just hope to inspire.
          dave
            Hello Mike,
            Hi UFO,
            Thank you for the info on some of the power supply specs. Designing specialized power supplies, such as super fast rise/fall times is an art form. From the PCB layout to specifying the components to testing the component batches to see that they meet the specifications.
            What is needed is a good PCB circuit designer. The only one I know of is hydroxy researcher Bob Boyce and he is booked doing his own designs such as his Hex-controller.
            - For example, Bob would test a component manufactured from different countries and found huge differences in quality control and parts actual performances vs what was spec'd out.
            - ExpressPCB to prefab the PCB and can use their software program to upload the design and have them made and shipped worldwide.
            ExpressPCB - Free PCB layout and schematic software
            ExpressPCB have sales going on for qty discounts.
            - Isolating the PS board from high voltage by using Opto-isolators.
            - surface mounted components SMT for short pathways.
            The list goes on and on, designing high performance Power Supplies one really needs a circuit designer specializing in PCB designs.
            Cheers Mike
              Hello Cinan,
              I have not tried with a transformer...or a power source, actually I am looking for a good one @ 36-72 Volts and up to 20 Amps...
              You mentioned your transformer is 24V but how mant amps?
              Besides, I think your diodes-rectifiers are not doing their job...
              You never mentioned what kind of diodes you are using, or I do not recall reading it from you...must be fast switchers, and since you are using higher voltage...rated accordingly.
              One thing you could try is to put two diodes in series in each line...one of them to be a 1N4148 (Germanium diode) after the big voltage rectifiers, or will blow them up.
              One that I have been using is the NTE576 (400V), but a higher one would be the NTE577...rated 1000V
              Your RIGOL will never give you a good trusting reading my friends...although you could try insulating it by using an inverter to supply the Voltage...
              The best way to measure Hz in this case I have done it with my Two EXTECH or a Radio Shack Clamp Amp Meter they sale for like 50.00, they are pretty good. And Amps go up to 40A.
              I see you are 'driving blind' my friend, need meters to tell you what is going on...
              P.D: Once you connect the 1N4148 small diodes you will not read nothing at output, but will obtain better filtering...
              Hallo Ufo,
              my power supply is 24VAC * 1.4142 = 34V / 10A. Only trafo, bridge and huge capacitor 150000uF . Battery replacement...
              Diodes are fast rectifier, 15ETH06FP or similar. Often used in my other power projects. I thing there is problem with diode, power supply (battery) or coil itself. I will buy NTExxx diodes and see how. I also want to wind new coil. Parallel bifilar as you have mentioned.
              Can you help me with dimensions ? I want to do pretty much same copy of your coil, as its will be best. Can you please give me measurements ? Its 3 layer coil right ? One piece of wire right ? Or or relevant info...
              Last think is winding direction... Bit messy. if coil is sitting on the table, vertical direction, and you start wind turns clockwise, downwards (as you have mentioned it somewhere in thread and you have it same way on your color picture of coil with diodes and mosfet), then according right hand rule, N will be below !!! And there is no way how to connect this coil with N and plus connection on one side. N and Plus will be always opposite ways.
              If you wind coil same way, but ccw, then you have plus on the top and N facing up too. Can you please make detail photo of your coil or clarify windings ? I don't want just wind coils and and trowing them coz they are wrong. We need to move on and I have a lot things in my head
              Usually old oscilloscopes, when you have disconnected grounding wire, system was isolated, stand alone as multimeter. I was measuring this way big industrial eguipment. But Riggol is messing somehow.... I will buy freq meter and other multimeter as I get new coil and will do other test.
              Your help will be much appreciated.
              cheers,
              Cinan
              • Coil Spec's
                Originally posted by cinan View Post
                Hallo Ufo,
                cheers,
                Cinan
                Hello Cinan!!
                Ok, yes you are right about the right hand rule...I always check my coils with the tool I made (The Brass handle and coin shape PM rotating freely and centered) for polarity, ...so there are no mistakes.
                My Coils range from 1 1/2 Inch (1.5) to 2 1/2 Inches OD.
                In my latest video (Anti-gravity EM Effect) I used 200 Turns of Bifilar Parallel, no layers, straight all the way through end, and 18 gauge (awg) it gave aprox 1.4 Ohms resistance.
                Now, the length on that one is like 2-3 Inches.
                I will provide a pic of my coil in detail, later on (do not have them available right now)
                I wind my coils in order to get both terminals above, opposed 180 degrees apart...I will definitively check them out again tonight and I will get back to you on it to-nite or tomorrow morning.
                But, do not sweat that much over the winding...as long as you are clear where North-South are and have your terminals defined correctly.
                I do not know what to tell you about the power supply Cinan, it sounds ok to me...and like I told you, I have not tried with a transformer, I will eventually, but am looking for the right Power Source, I want it Digital metered and ability to adjust Fine to Coarse output...
                The Diodes must be super fast switchers, NTE 576 is also a short timed recovery spec's and goes up to 400 Volts and 150A peak forward current.
                I tried cross referencing the number in your diode with NTE and nothing came up...I have here the other reference for the NTE576, is like UF505...search it.
                I do also, want to move forward...I am developing a Motor and Generator of Radiant Energy that will get your socks down (not to say your panties... )...so get ready and fasten your seat belts...I will open another Forum for that Info...just to keep it separate and strictly to that field of Motors and Generators...
                But I will moving forward to also open another forums in other sites like ATS and Overunity.com...even though I don't like them that much...but am looking to get over the 100 to 1000 million views...We need big time exposure for this to go world wide.
                • Hello Dave
                  dave
                  I have also been looking at your thread and your videos are excellent...
                  I know exactly what you are referring to...and I understand it quite well...but there is more to it..See we tend to dedicate more time to just "one event" when there are like other two going on at the same time...
                  For example : some people (must I will say) dedicate more time to electrical polarities, ignoring magnetic ones in a given Coil...
                  You have brought out a very interesting field, The Electric Field of a Magnet, and it is awesome!
                  I have figured out also what is going on inside the core of a Coil, right on the center, according to my experiments...I post it here a couple of pages back...
                  There is a center part that has been ignored by physics on any given Coil...an structure of opposed magnetic polarity that actually attaches 'internally' to the externally disposed one we all are familiar with...in every magnet or electromagnet in the world.
                  In my book you are also a great and respected experimenter Dave!!
                    Hello Cinan!!
                    Hallo Ufo,
                    very good. I will wait for details before I start winding... Regarding power supply. Once new coil and diodes will be collected, then I will test
                    this stuff together with battery and power supply too. To see difference. I just buy battery, no big deal. I will go fon NTE then, we knows its working with them.
                    It looks like you like rotating parts, do you ? Motor generator sounds very good to me, as I am involved quite heavily in diesel generator protection and control systems.
                    But I like solid state systems. And your discovery hopefuly can help to build one...
                    Ufo, before you start this big activity on other forums, please share here missing infos (you have said video nmbr.3) about how to boost her. Or only rough
                    sketch and info will do too. Lets cooperate on that. Based on that I will design some control system for that.
                    cheers,
                    Cinan
                    • PICgen software
                      Dear all,
                      yesterday after whole day of hard work, firmware and software for PICgen was made. Its v1.0 and i am expecting some issues there, but we need to start with something. I will release it soon. If anybody is interested, jst let me know.
                      Cinan
                      • I have been following this thread and will be watching for your progress.
                        Dana
                        Nikola Tesla
                        • Coil Spec and fabrication
                          Hallo Ufo,
                          cheers,
                          Cinan
                          Hello Cinan,
                          Ok, here are the spec's of the latest Coil on my last video, that outputs power to five 120V/23 Watts CFL's, to my believe it is a good Coil for you to start winding...
                          Outer Diameter of Core =2.0 Inches
                          Height of coil= 2.0 Inches
                          200 Turns 18 awg wire (double strands), connected in parallel start with start, end with end.
                          After finishing winding the outer wire diameter gets very close to three inches.
                          The way I wound it:
                          1-I make my own spool ends or caps with fiberglass sheets, in a fiberglass tube that I also mold/make...now, this one was made over acrylic clear tubing just for video purposes...but I like fiberglass better since it can stand better the heat. (I use Polyester Resin with Methyl Ethyl Kethol (MEK) Hardener. The end caps prevents from wire to slip out of control and could result in a loose winding that will make too much noise and vibrations...
                          2-I start on top turning Clockwise and tight going down, at bottom start coming up, and so on...200 turns.
                          3-Now the Orientation, I really do not want to confuse you, but my start wire is my positive...and end is negative...still North is on Top, next to Positive (You've said is not possible, I will re-check this coil again..to make sure, maybe my compass is "shifted"...lol)...but like I told you before, this concepts of magnetic poles are relative for the purpose you are going to be testing, magnetic polarity does not matter, and you could test it with a compass or a defined polarity magnet.
                          4- Just define the positive above, at the starting wire, so install diodes according to that set-up.
                          I will prepare a set of pics and maybe a short video to show you my coil polarity and magnetic poles. However, on my latest video Coil, could be seen pretty well.
                          Ok, any more you need let me know
                          Sorry for the delay to respond.
                          P.D: I will keep posting here, I meant, I will also go on other sites Forums...
                          Definitively you will see video 3 here soon, I am kind of swamped with work...but eventually will make it pretty soon...and yes there are a lot of ideas I have in order to set controller for the secondaries to run-perform better.
                          So, I will be here
                            Hello Cinan,
                            The way I wound it:
                            Definitively you will see video 3 here soon, I am kind of swamped with work...but eventually will make it pretty soon...and yes there are a lot of ideas I have in order to set controller for the secondaries to run-perform better. So, I will be here
                            Hallo Ufo,
                            thank you for info. Video 3 will be good to have. I still have problem to get Her. Your lamp flashes green during start, but my not... They go just flashes to white. I have to try NTE diodes, as they are last part different. Yesterday I've bought compass, so coil should be correct.
                            Last thing to ask for, can you send schematics of double power stage N-P you are using now ? Just configuration of diodes, coil and transistors is ok.
                            Once you'll sign up another web groups, let us know here, so we can follow too.
                            regards,
                            Cinan
                            • Hello Cinan
                              Hallo Ufo,
                              regards,
                              Cinan
                              Hello Cinan,
                              I am sorry that the Lady does not want to date you...
                              Just have to be patient man...women are like that sometimes...
                              Ok, the system should work perfectly well with just the N-Channel arrangement I have posted here...it does, trust me.
                              Now, I do not have a schematic of the actual dual channel, but I will load here where I got the idea from...A MOSFET Tester for P and N Channels below in pdf...
                              I used my same Old N-Channel circuit (I had made two of them) just added a second level small board just for second 555, 4.7 K and the 100 Ohms Resistors to 330 Ohms to gate of P-Channels and connectors for 555 ground and positive derived from same first 555...that's it...and of course added a bus bar to mount P Channels and respective connections of Source-Drain-Gates individually, I used a 4.7 K from Gates to Positive to Bias Gates...and it works fine, I know you would be able to make it just from this explanation, however I will try...not promising any soon- that I will make the diagram..and post it here.
                              Related to Diodes Coils and Transistors I have it...I will load it later...
                              • Hi all
                                Hey Torpex, I am glad you are making this replication, that is great!
                                Now, are you "slowly" dialing Up?...or are You rushing it as potentiometer turning means?
                                On this occasion did not touch the pot, was a rough shortcut.
                                Purple light shows at low pulses...and is like playing on a thin ice for it to disappear on you, as you keep going up...
                                I'm still working with 12v,but I have decreased the frequency of the circuit (at 208 Hz) and I see the effect of purple neon light, also some white flashes (ball shaped).
                                This is my circuit:
                                L1.- 100 turns air-core 32 mm. OD
                                Q1 y Q2.- IRF822DFI
                                R4.- Adjusts the frequency. (less R increases freq.) Start at 30% of the pot
                                R7. - Sets the pulse width. (less R decreases the duty cicle) Start at
                                20% of the pot
                                C1.- 22nF (Frequency range 90-400 Hz)
                                C1.- 15nF (Frequency range 138-576 Hz)
                                Only Q1.- Not see the purple glow
                                I adapt the circuit to your specifications slowly . Thanks Ufopolitics for his explanations .
                                http://Cacharreo.com.es/foro
