Performance
Hey Torpex,
I think that can be solved by either matching the impedence between the input/output or modifying the oscillator circuit for less on time (TH) in the duty cycle. I know that experimenting with this circuit that the R1+R2 in the astable timer/PWM circuit play a larger role in the current draw than the Rb and when I changed the base resistance exponentionly higher the current draw was not linear. Did not even change as only the R1+R2 seem to affect it.
I have seen the 2 parallel lines with the plasma arcs on the legs and this effect in my build seems to start at low Hz and when you back it off slighly and turn off the lights you obtain the strobing effects along with the Radiant blight pulses/flashes that can be seen easier as I'm sure you have noticed my friend.
Speaking of blackened glass. I have a neon that is a short circuit due to only one of the legs and the whole side of the glass burnt out when I blew that and a transitor charging a sulfated battery with the SSG.
That was to express how damaged it was and I do not want to get off topic here. This is about UFO's circuit.
Therefore, I placed this on the output of the PWM circuit and the single leg lights up via Tesla's single wire transmission/impulse tech. I think this was amazing by itself since I know that this neon is a short and will not work in "ANY" other hot circuit and thus is an aspect that needs further exploration.
Other cool effect was the Radiant field that is only generated by the single leg and I will make a clip tonight to show the electromagnetic/magnetic levitation or attraction/repulsion properties.
Can also get magnets to jump in the air by the repelling effect of the Radiant field. Is NO iron used, thus has to be the Radiant field interacting with the magnetic particles in a constant state of flux in the magnet and the bloch wall of the coil. North pole of the magnet against the coils north will produce the coolest effect
Hope to have it made and on youtube in a few hrs and thanks again UFO more providing more amazing things to experiment with another Radiant energy circuit.
Any and all things Radiant would take up 24hrs of my life if I had anything to say about it
Zero
Zero
