To All
LEARNING and UNDERSTANDING are not the same thing. Many here are building circuits because thay LEARNED how to do it. Untill you build it and play with it for a while, without changing it, you will not truely UNDERSTAND how it works. It is thru finding out why it does not work and going over everything again and again, as well as checking every item in the circuit off on another diagram as you go, that you begin the UNDERSTANDING. Then when you UNDERSTAND how it works, build another one and change that one, not the first one. Go slow, take notes and do every test you can at each level. It is thru UNDERSTANDING your circuit and going over your notes that you will be able to modify and improve what you have. When you put everything you have into one build and change it, when it goes up in smoke you will be at the begining and starting over again. That is stress----- as you now have nothing and no notes to get back on track. Keep up the good work guys.
Dana
Dana
